Old 10-06-2021, 01:32 AM   #85
AndMsc
Drives: MY2018 GT86 EU
Hello guys,
Which one between Hypergram and Dekagram do you think is more performant (as in more durable)? In 17x9 +40 they are the same weight and cost the same.
For GT86 with PP Package.
Thank you,
Andrei
AndMsc is offline   Reply With Quote
Old 10-15-2021, 11:32 PM   #86
jflogerzi
jflogerzi's Avatar
I am partial to the hypergrams. Currently they are my track tires
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 10-21-2021, 12:10 PM   #87
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by AndMsc View Post
Hello guys,
Thank you,
Andrei
That sounds like a very complicated question to answer. May be worth a shot to ask Konig how the wheels differ in stress levels and which ones are more likely to give at various loads. Otherwise, at the same size, weight, and multi-spoke design, they are probably about equally durable. Just based on their design looks, I would think Dekagrams can provide that extra bit of durability based on their spoke attachment points.
Have you confirmed that the Dekagrams will fit over your PP package? I know Hypergrams will, but I know Dekagrams aren't designed for big brakes necessarily, so they may be cutting it close.
Dzmitry is offline   Reply With Quote
Old 05-02-2022, 12:04 AM   #88
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I got a set with the machined lip for track use. I'm lowered about 1.25 inches on RCE SS1.
Lynxis is offline   Reply With Quote
Old 05-03-2022, 10:15 AM   #89
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
17x9 +40 lowered on coilovers
SuperTom is offline   Reply With Quote
Old 05-03-2022, 08:15 PM   #90
___LUNK
Drives: Laguna Seca Blue GR86
My 2nd gen with 17x8+40
___LUNK is offline   Reply With Quote
Old 05-04-2022, 11:53 PM   #91
Rcode
Rcode's Avatar
Drives: Ford Fiesta ST, 2022 Subaru BRZ
The second gen looks pretty good with the Hypergrams! 17x8 is probably the way I'll go as well. I think I've narrowed down my track wheels to these, RFP1's or Dekagrams. Thanks for posting this!
Rcode is offline   Reply With Quote
Old 05-06-2022, 05:37 AM   #92
Kingg
Drives:
They looks good. Still looking for a set
Kingg is offline   Reply With Quote
Old 11-27-2023, 08:36 PM   #93
Vangfrs
Drives: Argento Frs
What are your wheel and tire specs? How many inch drop? Camber?
Fron reading the csg tein flex a and rcc ss1 forum +40 offset has rubbing issues?
Vangfrs is offline   Reply With Quote
Old 12-01-2023, 11:02 PM   #94
Lynxis
Lynxis's Avatar
Wheels are 17x9 +40
Alignment is -3f/-2.2r camber, 0 toe
Tires are Falken RT660 245/40r17
No rub at all, even under hard track driving.
Old 12-12-2023, 11:52 PM   #95
Vangfrs
Drives: Argento Frs
Wheels are 17x9 +40
Thanks, appreciate the reply. Do you have any pics of ur car by chance?
Old 12-15-2023, 06:50 PM   #96
Lynxis
Lynxis's Avatar
I've got a few.
Old 12-15-2023, 07:40 PM   #97
RippedManiac
Jedi
Drives: Pikachu BRZ
If you go 245 you need coils or you might have tire rub on the oem spring perch.
RippedManiac is offline   Reply With Quote
Konig Rims- what do you think? KatrinaR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 01:35 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 12:27 AM
WTB- Konig Daylites solort Want-To-Buy Requests 0 01-07-2014 11:07 PM
Konig Wheels pghfan19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-25-2013 12:24 AM
Konig deception oaroyale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2013 09:02 PM
