Old 12-05-2023, 05:47 PM   #71
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by autoracer86 View Post
Very helpful. What pads are you running in the rear ?
I'm running matching rear pads in OEM caliper.
Lynxis is offline   Reply With Quote
Old 12-10-2023, 04:17 AM   #72
Lynxis
Lynxis's Avatar
Also, my mistake, I wrote down that I'm on C21 but this is incorrect, I'm using the CSG CP compound which is basically their general purpose/dual duty pad.
Old 12-10-2023, 04:56 AM   #73
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
C21 front with cp rears
Or
Cp all around
Thanks for updating
autoracer86 is offline   Reply With Quote
Old 12-10-2023, 06:31 PM   #74
Lynxis
Lynxis's Avatar
Or
Cp all around
Thanks for updating
CP all around.
Old 12-11-2023, 05:32 PM   #75
CSG Mike
CSG Mike's Avatar
Or
Cp all around
Thanks for updating
CP all around.
C21 front with BM4 and CP rear would result in terrible bias!
CSG Mike is online now   Reply With Quote
Old 05-30-2024, 05:32 PM   #76
redlined600
redlined600's Avatar
Drives: Fr-s
Does anyone have replacement rotor part numbers for this kit?
Are the rotors the same dimensionally to the BRZ PP rotors?
I'm trying to get an idea of long term cost.
TIA
redlined600 is offline   Reply With Quote
Old 06-01-2024, 10:52 PM   #77
Lynxis
Lynxis's Avatar
I'm not sure of the specific part number but CSG has confirmed to me previously that this kit uses PP rotors.
Old 06-02-2024, 03:39 PM   #78
redlined600
Drives: Fr-s
That was my suspicion, thanks.
Old 07-01-2024, 08:16 PM   #79
Quadrozontal
Drives: 2023 GR86
Can I assume the BM4 doesn't have dust boots and therefore wouldn't be ideal for street use?
Quadrozontal is offline   Reply With Quote
Old 07-02-2024, 04:35 PM   #80
redlined600
Drives: Fr-s
The BM4 calipers have dust boots.
Old 07-02-2024, 08:35 PM   #81
CSG Mike
CSG Mike's Avatar
The caliper does have outer dust boots and is designed for mixed use.
Old 07-18-2024, 09:45 PM   #82
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
TIA
If you want the Brembo zinc coated slotted rotors that come with the kit, they run in at $330 each. These are what are listed on the BOM of my GT Kit, though I'm sure the BM4 uses the same:
  • LEFT: 19.7812.51
  • RIGHT: 19.7812.61
I don't have the part number for the drilled rotors handy, but I'm sure they cost about the same.
They're not easy to find, probably have to contact and order through a Brembo distributor:
Finally, I don't know what kind of Brembo rotor CSG used to offer with their CSG-spec kit (i.e., the Blank unfeatured one). They've never provided a clear answer on it, but it's probably a Brembo sourced rotor. Perhaps it's the same as the OEM Brembo PP rotor.
  • It seems that now they option all of their kits with the standard-kit Brembo drilled or slotted zinc plated rotors
In any case, the calipers should also take replacement 326mm rotors common to the PP caliper (which is the same ones WRX STi use); just make sure they come in the right bolt pattern.
  • OEM is pretty expensive, running in around $300-$400 ea as well (as they are also Genuine Brembo rotors).
  • Centric is what most people end up getting for affordable replacements (coming in around $130 ea)
EndlessAzure is offline   Reply With Quote
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
WTB: Rear Brembo STI caliper. grostoine Want-To-Buy Requests 2 07-16-2014 05:26 PM
STI Brembo caliper mounting bolts... SkAsphalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-13-2014 07:24 PM
The price of one Brembo Caliper. chuttney1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-18-2013 04:32 PM
