Old 11-20-2023, 03:43 PM   #113
redlined600
redlined600's Avatar
Drives: Fr-s
Are you planning on running multiple ABS and TC maps?
redlined600 is offline   Reply With Quote
Old 11-20-2023, 05:25 PM   #114
gt5759
Drives: 2017 BRZ
Thats the plan! TC is two fold adjustable and the abs is just on/off sadly since I don't have the budget for the big dollar Bosch unit. Will have no lift shift and autoblip as well.
gt5759 is offline   Reply With Quote
The Following User Says Thank You to gt5759 For This Useful Post:
redlined600 (12-01-2023)
Old 11-28-2023, 01:19 PM   #115
gt5759
Drives: 2017 BRZ
Splitter starting to come together now. Still need to finish the mounts behind the facia and clean up some edges (little nit picky things) but overall looks pretty good.
The Following 5 Users Say Thank You to gt5759 For This Useful Post:
DocWalt (11-28-2023), Pat (11-28-2023), RedReplicant (11-28-2023), RT-BRZ (11-28-2023), Ultramaroon (11-28-2023)
Old 12-01-2023, 10:47 AM   #116
redlined600
Drives: Fr-s
Nice! I'd be curious to see what you end up with for a TC strategy?
The Following User Says Thank You to redlined600 For This Useful Post:
gt5759 (12-04-2023)
Old 12-04-2023, 12:20 PM   #117
gt5759
Drives: 2017 BRZ
I will be using cut percentage and desired slip level. It's the easiest, at least for me, to dial in and control as needed.
The Following 2 Users Say Thank You to gt5759 For This Useful Post:
DocWalt (12-04-2023), redlined600 (12-04-2023)
Old 12-04-2023, 04:05 PM   #118
gt5759
Drives: 2017 BRZ
Finished up the mounts for the splitter. Nothing magic, just a couple thin wall tubed uprights.
I also did some comparing of wheels and tires this weekend, no weird deep dive or anything just some basic checks while I was mounting tires on the new wheels and had my scales out.
The Apex SM-10RS is a little over 1lb lighter than the Koya's drift and Konig ultragram's (friend of mine is running those at this time). All three of them being the 17x10.
Also, a side note the toyo rr 255/40r17 is about 2-3lbs heavier than a hoosier 225/45r17 R7 (accuset scales are not the most accurate for numbers under a lb). I'll get a maxxis rc1 to compare eventually, but I bet it's about the same? The toyo also clears the nasa 266mm rule by about 9mm, as a person would guess.
Finish on the SM-10RS is absolutely fantastic and I feel it goes with the car's exterior color scheme better. (I still like the red though) Brake caliper clearance is more than ample, the knurling on the inside of the barrel is unpainted and has much deeper and sharper edges than the Konig, Koya didn't have any at all. lug nut clearance is also greater, big impact sockets are not an issue.
Suspension and body clearance is perfect. The 45et offset is a great compromise front and rear, the fronts could use a 5mm spacer to get more spring to tire clearance or just a small offset in the coilover to knuckle mounting pill. With the coilover centered in the knuckle it clears with about 3mm. Rolling of the fenders and quarters isn't needed if running race camber settings, less aggressive and a person would need to roll the rears at the minimum. (just thoughts towards other applications)
autoracer86 (12-05-2023), DocWalt (12-04-2023), JeffForSale! (03-16-2026), RedReplicant (12-04-2023), villainous_frx (12-04-2023)
Old 12-04-2023, 07:01 PM   #119
RedReplicant
Drives: None
Any chance you can whack a 257mm template on one of the 10s with the RR?
RedReplicant is offline   Reply With Quote
Old 12-05-2023, 10:29 AM   #120
gt5759
Drives: 2017 BRZ
You bet. I don't have the template cut for the 257mm but I do have a 3d printed piece that uses my dial calipers for a measurement at the required height.
RedReplicant (12-05-2023)
Old 12-11-2023, 11:35 AM   #121
gt5759
Drives: 2017 BRZ
Well, my digital calipers are not big enough, but I got you pretty close and they won't work for a 257mm rule.
RedReplicant (12-12-2023)
Old 12-11-2023, 11:42 AM   #122
gt5759
Drives: 2017 BRZ
Lucille got to hang out in the sun with my son's 86
Side note: get the alignment closer to straight before putting fresh slicks on and trying to push it around, otherwise you will hate life and it will feel like pushing a 1 ton truck As soon as it went back on the lift I corrected that!
blsfrs (12-11-2023), DocWalt (12-11-2023), JeffForSale! (03-16-2026), RedReplicant (12-12-2023), Ultramaroon (12-11-2023)
Old 12-12-2023, 11:26 AM   #123
RedReplicant
Drives: None
Oh, wow, that is kinda surprising. Thank you much
Old 12-13-2023, 11:04 AM   #124
gt5759
Drives: 2017 BRZ
I was surprised as well, on a 9.5" rim I bet these clear the 257mm rule same as the RC1, versus the 10".
RedReplicant (12-13-2023)
Old 12-28-2023, 04:51 PM   #125
gt5759
Drives: 2017 BRZ
Profile shot while moving vehicles around. Having had time to set back and look at the car for once from a distance I'm probably going to redesign the wing mounts again and give them and arc that follows the A pillar/roof arc vs the more angular design, should flow with the car a little better I think. That will be at a later time though as I don't feel like throwing more money at that right now!
The Following 4 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (12-29-2023), RedReplicant (12-29-2023), RT-BRZ (12-28-2023), villainous_frx (01-03-2024)
Old 01-15-2024, 01:22 PM   #126
gt5759
Drives: 2017 BRZ
Slowly chipping away! Diff and trans cooler in final location, rear plumbing in cabin done, fire system is plumbed (i didn't get a complete pick of that for some reason ) . Hopefully I can get the hardlines under the car for the accu sump and fuel done this week, waiting on fittings. Coolant hoses are sized and assembled in the engine bay, can't see it but the fire bottle nozzles are in the firewall on each side of the motor, I really like how they go away. I'll get some better pics of the fire system this week.
blsfrs (01-15-2024), DocWalt (01-15-2024), Jdmjunkie (01-16-2024), RedReplicant (01-18-2024), villainous_frx (01-16-2024)
Jensen NASA ST4 race build thin2win Member's Car Journals 18 04-14-2021 12:15 AM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
Car 986 Scion FR-S NASA PTD Race Car Build phastafrican Member's Car Journals 70 01-03-2015 09:32 PM
