09-06-2023, 07:27 PM | #155 | |
Drives: Toyota GT86
Would you not look into something like the AP racing kit ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
09-07-2023, 12:43 AM | #156 | |
Drives: Fr-s
I think the AP kit is a decent option but I'm leaning toward the factory Brembo kit for a few reasons; OEM design, no brackets Larger rotor dia. F/R should lead to cooler brake temps Pads are relatively inexpensive Rotors are inexpensive, especially compared to AP (or any 2pc) rings
The Following User Says Thank You to redlined600 For This Useful Post: | autoracer86 (09-07-2023) |
09-18-2023, 05:30 PM | #157 |
Drives: Fr-s
Here is what I ended up with. In terms of effort for value, we'll see...
There are several OEM 4 cylinders that use manifold braces so I think it's probably a good idea, especially with the counter balancer removed.
The Following 4 Users Say Thank You to redlined600 For This Useful Post: |
09-18-2023, 05:53 PM | #158 |
Drives: None
Damn. Nice work, that looks great.
The Following User Says Thank You to RedReplicant For This Useful Post: | redlined600 (09-19-2023) |
09-29-2023, 05:42 PM | #159 |
Drives: Fr-s
Engine out. Don't mind the oil slick, I forgot to drain the trans.
Lots of cleaning to do. Mating the trans the to K24 and one bolt didn't make it to spec. I measured the bolts and they are indeed 70mm Now it's just waiting on the helicoil kit. In the mean time I can do all the engine bay mods.
The Following 2 Users Say Thank You to redlined600 For This Useful Post: | gt5759 (10-03-2023), villainous_frx (09-30-2023) |
10-08-2023, 08:01 PM | #160 |
Drives: Fr-s
Small update before the engine goes in.
Tunnel modified, I decided to cut and weld rather than just bash it in. grinder and paint...... I've since cleaned and painted it. I opted to move the harness a bit by cutting and modifying the plastic guide. This moved the harness where it moves up the firewall by a few inches. Hopefully away from the exhaust heat. Where I have the ground bolted to right now is where the plastic guide used to attach. 3d printed a cover for the AC. It's petg/CF so I'm hoping it will hold up to the heat I'm really just waiting on some rivnuts and a tool to put in some wire holders and clamps and I'm ready to drop the engine in.
The Following 3 Users Say Thank You to redlined600 For This Useful Post: |
11-02-2023, 11:35 PM | #161 |
Drives: Fr-s
I should have a few updates coming as things move along.
Engine is in! Since I damaged the oem zip ties for the main harness I have been unsuccessful in finding replacements. I finally gave up and put rivnuts in the holes and had these made to secure the main harness. M6 button head secures the bracket to the firewall and then zipties on either side secure the wire harness. On the topic of the wiring harness, I really didn't like how the engine harness plug just hangs out. I had this bracket made to secure the plug to the engine, The plug snaps onto the left tab and the injector harness is secured by the right tab. I'll post the final setup once installed. Going through this really gives one an appreciation of how much effort oems go though to ensure robust designs. Another item that's been on my mind is the driveshaft. I originally planned to shorten the oem driveshaft, and that is still on the table. However, I also picked up the Kpower aluminum unit from Irace to experiment with. It's 12lbs lighter which would be nice but there are numerous complaints about vibration. My theory was that the repositioning of the engine screwed up the trans output to diff input angle. I was able to measure both and the difference was about 1*. Not as bad as I thought it might be, but a few driveshaft sources claim less than 0.5* is optimal for least vibration. My plan is to shim the front of the diff down to get the difference between the diff and output close to zero. I'll probably still have the oem one shortened over the winter as a back up.
11-03-2023, 12:53 PM | #162 |
Drives: None
I see you've got rivnuts ready to go for a header heat shield or similar. I ended up ordering some of this https://www.pegasusautoracing.com/pr...asp?RecID=7267 but haven't installed it yet.
The passenger floor area seems to get really burned up.
The Following User Says Thank You to RedReplicant For This Useful Post: | Irace86.2.0 (11-08-2023) |
11-03-2023, 01:30 PM | #163 | |
Drives: Fr-s
I think you pointed the floor area out to me in the past, I put some gold foil tape in that area but am not expecting a whole lot from that. Since the S2000 header will require more work than I anticipated I have the option of placing the exhaust where I want it. Hopefully I can leave enough room for some sort of shielding.
The Following User Says Thank You to redlined600 For This Useful Post: | RedReplicant (11-04-2023) |
11-04-2023, 10:48 AM | #164 |
Drives: 2013 frs base
FWIW: You might want to read this post. Aluminum driveshafts have a low critical speed which accounts for the extra vibration and can cause sudden failure. https://www.ft86club.com/forums/show...=148537&page=4
The Following User Says Thank You to blsfrs For This Useful Post: | redlined600 (11-20-2023) |
11-06-2023, 01:25 PM | #165 | |
Drives: Fr-s
Here is what I actually know: 1. Multiple people have had vibration issues related to the Kpower AL driveshaft 2. Kpower stated that they later adjusted their balancing procedure 3. On my car there is a 1* mis-alignment between the Trans output axis and diff. input axis. When I calculate the max driveshaft speed based on a 130mph top speed (this is estimated based on the tracks I frequent) I get the following. Buckle up for a lots of speculation. I really tried to find a critical speed calculation but didn’t have any luck, however, based on extrapolating (dashed lines) this chart (https://pstds.com/critical-speed-chart), I’m making some assumptions for the 46” kpower unit If the aluminum driveshaft follows a similar trajectory as the steel driveshaft that would put the critical speed around 8000 rpm for a 3” (as is the Kpower DS) Based on the comment that DSS made to Blsfrs that their critical speed was indicated at 110mph, that calculates to about 6000 rpm, which roughly matches up with the extrapolation based on a 52” long 3” AL driveshaft. All this is to say I’m not still not sure if the critical speed of the Kpower unit is the issue. Shimming the front of the diff to match the angle is cheap and easy so I’ll start there. If there is still an issue I’ll swap to the shortened OEM unit. Maybe I’ll end up there either way as an extra margin of safety. In other news here is the engine harness plug bracket installed, it’s a bit hard to see among everything, but if you look at it for a bit you can figure out what’s going on.
11-11-2023, 02:55 PM | #166 |
Drives: Fr-s
Radiator is back in and the plumbing is done. Fuel pump relay, injectors and fuel rail are in. Lots of other little stuff completed.
The biggies left are modifying the S2000 header, pumping the remaining E85 out, finishing up the fuel lines and hooking up the ECU and wideband. Unfortunately the car has to go into storage Sunday and I'm busy today so this is the end of the road for this year. I probably win the award for slowest swap.
The Following 2 Users Say Thank You to redlined600 For This Useful Post: | gt5759 (11-13-2023), RedReplicant (11-12-2023) |
11-29-2023, 04:46 PM | #167 |
Drives: 2017 BRZ PP, 2004 WRX
@redlined600, do you remember generally what alignment you were running with the +35 Apex Arc-8's a few years ago? I was snooping through your thread for my STX build. Probably close to -4 degrees.
11-30-2023, 08:04 AM | #168 | |
Drives: Fr-s
Similar Threads | ||||
The Rebirth of an Italian | FlowForm_Wheels | Other Vehicles & General Automotive Discussions | 16 | 06-01-2014 11:46 AM |
Trackday GPS Recommendation | milhouse | Tracking / Autocross / HPDE / Drifting | 12 | 03-24-2014 12:19 PM |
Trackday at ORP | jblmr2 | Northwest | 6 | 02-21-2014 05:30 PM |
2nd trackday in FR-S | icemang17 | Tracking / Autocross / HPDE / Drifting | 4 | 09-24-2012 04:40 PM |
1st trackday in FR-S | icemang17 | Tracking / Autocross / HPDE / Drifting | 10 | 09-01-2012 10:02 PM |
