Old 11-07-2023, 11:24 PM   #24473
I replaced the battery in my 2013 FRS. Replaced with an Interstate.
I hated to part with the original battery, but it was getting old and tired.
Sorta like me -
I still occasionally look for a new Panasonic online. It was a great battery.
humfrz (11-08-2023)
Old 11-08-2023, 12:56 AM   #24474
Yep, that Panasonic battery served me well. All I had to do was give it a drink of water about every year and in its last year, give it a spark about once a month.
Back in the day, I would have just nursed it along for another year and just push started the car if necessary. Today, I couldn't push start a lawnmower.
can one push start these cars if they have a dead battery?
Ultramaroon (11-08-2023)
Old 11-08-2023, 12:28 PM   #24475
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Couldn't count on bump starting my x386 game computer.
That only dented the corners on the case.
Old 11-08-2023, 12:43 PM   #24476
Spairo
Drives: 2013 FR-S 6 spd in Halo
After leaving the key on and the radiator fans going during the lunch break at a track day, I can definitively say that you can push start these things. Granted, I had to think through the process since it has been at least 30 years since I last push started a car.
Go fast, take chances.
Spairo is offline   Reply With Quote
The Following 3 Users Say Thank You to Spairo For This Useful Post:
Dadhawk (11-08-2023), humfrz (11-08-2023), Ultramaroon (11-08-2023)
Old 11-08-2023, 01:04 PM   #24477
As long as there's enough juice to hear the fuel pump prime the rails, it's good to push.
humfrz (11-08-2023)
Old 11-12-2023, 09:42 PM   #24478
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Pulled trans today. New exedy OEM clutch+flywheel, battle garage TOB, verus fork+pivot, and front bearing cover.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
Bonburner (11-26-2023), Jdmjunkie (11-13-2023), MJones_RB (11-14-2023), Ultramaroon (11-14-2023), Wally86 (11-14-2023)
Old 11-14-2023, 09:34 AM   #24479
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Did the strap trick help to make installing the trans easier?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 11-14-2023, 11:52 AM   #24480
RToyo86
RToyo86's Avatar
I haven't tried without it to compare, but it certainly went together pretty easily. Wiggled it for about 2-3 minutes and it slide in most of the way. Was able to snug it to the block by gently tightening bell housing bolts cross pattern a little bit at a time.
Gently rotated the output shaft at the back of the trans to help line it up better to the clutch.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
MJones_RB (11-14-2023), Wally86 (11-14-2023)
Old 11-14-2023, 01:15 PM   #24481
Be careful about tweaking that AC hardline! Just noticed it.
RToyo86 (11-14-2023)
Old 11-14-2023, 02:07 PM   #24482
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
When I did mine, I used a scissor jack (trailer leveler) to prop up the front of the engine to keep it from leaning forward, helped a lot.
Great job!
MJones_RB is offline   Reply With Quote
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
RToyo86 (11-14-2023), Wally86 (11-20-2023)
Old 11-14-2023, 02:49 PM   #24483
RToyo86
RToyo86's Avatar
Not sure if I actually touched it but thanks for the heads up! I very much appreciate my AC during the summer
Great job!
I borrowed a friend's lift which didn't leave me many options for supporting the engine. He had a tall spinny arm jack that I used to help support the transmission while we wiggled it in and out.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
MJones_RB (11-15-2023), Ultramaroon (11-14-2023), Wally86 (11-20-2023)
Old 11-19-2023, 08:42 PM   #24484
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I removed my Verus front wheel air deflectors and reinstalled the oem ones. I couldn't hardly drive anywhere without finding something to scrape.
And how about that 1/4" composite aluminum piece between the splitter and engine cover and wheel wells? I bet it gets me 0.0000002% less drag and lift.
I dropped her off at a tire shop for a set of Conti Extremecontact dws. Can't wait to get her back.
The Following User Says Thank You to blsfrs For This Useful Post:
Wally86 (11-27-2023)
Old 11-26-2023, 03:42 PM   #24485
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Had it PDR'd completely following some light hail damage, and took the opportunity to correct the 50+ door dings and small impacts the car had gotten in its first life.
All are gone save for one on the wheel arch. It looks like a new car. They also polished it a little bit and corrected some small paint repairs that had been done approximately.
Also, installed the updated facelift door stoppers (sooo much better), and a knock-off MC brace.
alex87f is offline   Reply With Quote
The Following 4 Users Say Thank You to alex87f For This Useful Post:
blsfrs (11-27-2023), Stephen W. (12-01-2023), Ultramaroon (11-27-2023), Wally86 (11-27-2023)
Old 11-26-2023, 08:46 PM   #24486
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I've been curious how that throwbout bearing feels. I'm planning on swappinmg clutch, flywheel, fork, and pivot in a few months, debating adding that on or sticking OEM.
They're pretty pricey too, and I'm kind of expecting it to have only a 20% longer life time than oem's throwout bearing .. but who knows.
