Old 10-26-2023, 01:58 AM   #1
007LeBRZ
Drives: slow
Acceleration problems.
Hello!
I have a 2016 brz modded with tomei uel header, perrin 2.5 catback, and is tuned on delicious tune stage 2.
Car has been driving great specially as a daily driver but recently (past 3 months) I got my clutch done, a month after clutch was done, i've had acceleration issues.. local shops couldn't figure out what was wrong with car.. no CEL or anything but the car is not 100% .... last week I found out I had a broken v-band on my exhaust, replaced it, drove around it seemed better but still seems having acceleration issues. I'm hoping it would be just a minor exhaust leak this time. or maybe spark plugs?
any help would be appreciated!
007LeBRZ is offline   Reply With Quote
Old 10-26-2023, 03:06 PM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by 007LeBRZ View Post
Hello!
Odd. Would be nice to get some data logs for the people that can understand them on this forum, might be able to notice something that would point to an air or fuel issue. Leak is definitely possible considering you've already started off poorly with the broken v-band. But having no CEL does seem interesting in that case, unless maybe the leak is small enough?
Dzmitry is offline   Reply With Quote
Old 10-26-2023, 05:15 PM   #3
007LeBRZ
Drives: slow
*drove car around today, accelerator seems to respond better but there's still a delay with rpm needle going up from time to time. RPM drop during idle isn't as terrible
I thought it'd be spark plugs since I haven't changed them and I'm almost at 90,000 km
and I'm trying to get in contact with my local tuner about the logs.
Old 11-07-2023, 03:02 PM   #4
Dzmitry
Dzmitry's Avatar
Yeah I would start with the local tuner to see if he notices anything unusual in the logs. Bad spark plug(s) would certainly cause misfires and poor driving/acceleration. But that should at the minimum show up on a scan of the car. It may not throw a CEL but it would still count up misfires.
Old 11-07-2023, 03:22 PM   #5
alphasaur
friendly
Drives: 17' 86
Post logs
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Ultramaroon (11-08-2023)
Old 11-10-2023, 10:35 AM   #6
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I'm having a similar problem which I haven't been able to diagnose. (14 FR-S) My OBD reading tells me that I'm only getting 80.1% absolute throttle. AFR when I give it WOT is 11.4. I have an ESC on my car but I don't think that's related. I cleaned the throttle body intake and the butterfly is positioned full open, but the car just doesn't feel as strong as it should. Not sure what to do next
Qwimby1 is offline   Reply With Quote
Old 11-14-2023, 10:46 AM   #7
Dzmitry
Dzmitry's Avatar
The absolute throttle reading is completely normal from what I recall. You can do some reading from past posts about this. Here's a quick link from the first google search.
https://www.ft86club.com/forums/showthread.php?t=88069
Old 11-14-2023, 06:26 PM   #8
Qwimby1
for those who use an ESC, you'll know there's at is a two- position switch that most set at 60% and 80% throttle. That's what I did using my OBD reader. At that time it would also show 100% throttle when I floored it. The OBD was showing 100% absurd throttle, until I swapped out some new batteries for the ESC. I had run the car for a few hundred miles with the ESC turned off. That caused the batteries to go bad. Once I replaced the batteries and turned the ESC back on, I'm getting 80.1% ATP reading. Talked to the folks who make the OBD reader and they told me it's telling me what the ECU is telling it. I have a butterfly valve that's wide open and I'm wondering if there's something else in the throttle body assembly that's telling the car it's only supposed to get 80%.
Noise on acceleration of a A/T car alone1i Scion FR-S / Toyota 86 GT86 General Forum 6 08-18-2020 04:03 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
Does the A/C cut off upon hard acceleration? brillo Scion FR-S / Toyota 86 GT86 General Forum 13 03-26-2013 10:31 AM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 07:56 PM
