Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
11-03-2023, 04:31 PM | #1 |
Drives: 2022 GR86
Which wheels clear the Brembo B-M4 BBK
Similar to my earlier thread which was a huge success, I'm starting a new thread to figure out which wheels clear the Brembo B-M4 BBK which is a somewhat common recommendation. Here's my review of that kit.
Please contribute with photos and wheel specs of cars you know run this kit! Also attached is a template you can use to check your own wheels. In alphabetical order: Apex Wheels ARC-8 17x9.0 +42 FIT SM-10RS 17x8.0 +40 require a 5+ mm spacer (claimed by Apex, evidence needed) VS-5RS 17x8.0 +40 FIT (claimed by Apex, evidence needed) VS-5RS 17x8.5 +44 FIT (claimed by Apex, evidence needed) VS-5RS 17x9.0 +48 FIT (spacer was used for non-BBK reasons) Enkei RPF1 17x8.0 +35 DO NOT FIT RPF1 17x9.0 +35 DON'T EVEN ASK Titan 7 T-S5 17x9.0 +37 FIT T-S5 17x9.0 +47 require a spacer (10 mm seems to work)
Follow the build thread for my GR86!
11-03-2023, 04:38 PM | #2 |
Drives: 2022 GR86
It looks like Enkei RPF1 17x8.0 +35 won't fit without a massive spacer.
11-26-2023, 02:37 AM | #3 |
Drives: 2013 WRB BRZ 6MT
I can add the following fitment details.
I'll note that the space from the caliper to the barrel on many 17 inch wheels is very tight, such that I don't recommend placing balancing weights here because they're liable to get torn off if even a small pebble gets caught. Konig Hypergram 17x9 +40 - fits, no spacer needed. Phatfux Ballzy 17x8 +35 - spoke interference, 3mm spacer required. Unknown 6 spoke 17x6 +48 - spoke interference, 5mm spacer required. OEM space saver spare - complete wheel interference, 55mm spacer required. |
01-14-2024, 10:59 PM | #4 |
Drives: 2022 BRZ
Both the 6UL 17x9 +48 and the Apex 17x9 SM10RS +48 fit with the Brembo BM-4 calipers. The 6UL fits without a spacer. I never tried the Apex w/o a spacer.
05-05-2024, 03:08 AM | #5 |
Drives: BRZ 2023
Can anyone send me copy of the template?
05-05-2024, 07:14 PM | #6 |
Drives: 2022 BRZ
It’s attached as a PDF to the first post
The Following 2 Users Say Thank You to Wangspeed For This Useful Post: | Lynxis (05-05-2024), ruturaj001 (05-05-2024) |
05-05-2024, 10:12 PM | #7 |
Drives: BRZ 2023
05-07-2024, 02:13 AM | #8 |
Drives: BRZ 2023
Heard back from konig, ultragrams 17x8 and Heliograms 17x8.5 both fit
Similar Threads | ||||
Do stock non-pp BRZ wheels clear 17+ BRZ PP rear Brembo | graywzc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-21-2020 10:47 PM |
SSR GT2 17x7.5 +48 clear BRZ brembo brakes? | artongdou | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-23-2018 06:28 PM |
Help : Enkei RPF1 Clear STi Brembo's?? | yoonjin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 10-19-2014 11:45 AM |
Brembo GT Kit Fitment on Enkei Wheels | Parikh1234 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 07-17-2014 09:12 AM |
Does anyone know if TSW Nurburgrings clear STI brembo's? | SkAsphalt | Wheels and Tires | 0 | 05-14-2014 04:04 PM |
