Old 10-31-2023, 02:53 PM   #1
Subielove1
Drives: 2019 Subaru BRZ Limited w/ PP
Perrin Oil Cooler Issues with 2017+ BRZ M/T
Clearance Issues While Installing Perrin Oil Cooler in a 2019 BRZ M/T
Having fitment issues with the gigantic stock airbox where the fittings screw on below the oil filter.
Perrin emailed me back saying that most of their customers get a heat gun and gently massage back forward that small portion of the offending area of the airbox to get the slight clearance needed.
Not wanting to install an aftermarket intake due to MAF rescaling. Already running an OTS Stage2+ Openflash tune with catless JDL UEL Headers. Don't have the time to do the datalogs for the custom tune.
Will I need to rescale MAF even if I just swap a 2013-16 air intake tubing and airbox?
Or should I just take the heat gun and run with it?
What have you guys done to solve this problem?
Subielove1 is offline   Reply With Quote
Old 11-01-2023, 08:28 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'd probably go with the heat gun option. The 13-16 box may be worse. It's a little more square. I had a JR sandwich and the lines were rubbing the box. It was a pain getting to the filter.
The Following User Says Thank You to blsfrs For This Useful Post:
norcalpb (11-01-2023)
Old 11-01-2023, 07:25 PM   #3
Grady
Grady's Avatar
Other option is to switch to Banjo fittings. Just make sure they are torqued correct and safetied.
The Following User Says Thank You to Grady For This Useful Post:
blsfrs (11-02-2023)
Old 11-01-2023, 10:22 PM   #4
Subielove1
After reading user steve99's posts on the Grimmspeed cold air intake, I have decided to go with that route. Apparently the MAF placement on the Grimmspeed Intake is so similar to OEM that MAF rescaling is not required. I gave the Perrin Intake a look at too, but no way in hell am I going to remove the bumper just to clean the air filter. Will datalog after to verify that the engine is running optimally.
Spent almost all day reading. Really got sucked into the rabbit hole today haha
The Following User Says Thank You to Subielove1 For This Useful Post:
blsfrs (11-02-2023)
oil cooler, perrin oil cooler
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
2017 BRZ and Perrin Oil Cooler Install JSube Tracking / Autocross / HPDE / Drifting 18 04-29-2017 07:49 AM
FS: Vortech Supercharger, Perrin Oil Cooler, Perrin Overpipe MrTranxD Engine, Exhaust, Bolt-Ons 14 08-17-2016 11:20 AM
Perrin Oil Cooler Issues deange Engine, Exhaust, Transmission 137 01-29-2015 06:47 PM
aftermarket oil cooler, pressure issues? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 05-05-2014 10:36 AM
