Old 10-30-2023, 02:42 PM   #1
KiK
KiK's Avatar
Drives: 20’ GT86
Help me decide: KW V3 vs KW V3 Clubsport
Hello, here I am with another indecision since the last post I created about suspensions.
Since I want to order the coilovers next month the deadline to make a decision is approaching, last post I was settled on the V3cs but I obtained new information that may shift the decision.
So, the new information I have:
KW V3: Front 4K-200mm spring / Rear: 5K-200mm spring
KW V3 Clubsport: Front: 6K-170mm spring /Rear: 7K -170mm spring
Both coilovers also feature a helper spring and valving to match.
Both can be revalved and rebuilt according to KW Europe
The clubsport top mounts can be bought and installed into the standard V3.
This means that the total cost of the setup (incl. shipping) will be:
V3 + CS Mounts = 2776 €
V3CS = 3492€
A total difference of 716€
Now, facts about the planned build route:
- Coilovers will be professionally installed with corner balancing and alignment.
- The car will be, eventually, on 18" with 235 Eagle F1.
- Although I still haven't made my mind yet, I am considering also installing them alongside with SPL RLCA.
My use case:
-Car is daily driver (Location Europe: lot of cobblestone roads in sh*t condition)
-Car sees the track infrequently (1-4 times a year)
-Car sees a lot (weekly, sometimes multiple times a week) spirited canyon runs and backroad fun.
My goals are (sorted by priority)
1- Improve handling and overall car behavior both on track and on my canyon runs (I understand that this is heavily tune dependent).
2- Retain or improve ride quality and comfort (I don't want to drive an S class, but I also don't want to feel like the car is about to fall apart every time I ride on cobblestone road)
3- Achieve a 0.78" - 1" drop for looks (20mm to 25mm)
Based on these, I am asking the internet to decide how I will spend my money .
Last edited by KiK; 10-31-2023 at 07:30 AM. Reason: Wrong conversion from mm to inches
KiK is offline   Reply With Quote
Old 10-30-2023, 04:34 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
V3CS = 3492€
My use case:
3- Achieve a 1-1.15" drop for looks
Neither. RCE Yellows and B6s.
Unless drop is actually #1 on that list then the non clubsports.
Old 10-30-2023, 07:15 PM   #3
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
If it helps you, I have KW Clubsport with 7kg / 8kg custom springs, for the city I wish it was a little softer, but it is not a very hard suspension, and on the track it works very well.
Nor do I think you are wrong with a normal V3.
Ruben_86_ is offline   Reply With Quote
Old 10-30-2023, 07:45 PM   #4
CSG Mike
CSG Mike's Avatar
Your drop means you'll want the CS spring rates to not bottom out.
CSG Mike is online now   Reply With Quote
Old 10-30-2023, 10:02 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
Achieving those three goals simultaneously is awfully difficult. Keep your expectations low in that regard.
Sent from my Pixel 7a using Tapatalk
Old 10-31-2023, 07:34 AM   #6
KiK
KiK's Avatar
Drives: 20’ GT86
Hello, I am locked on the KW because they feature the required certification for the car to be road legal here.
I see that you are based in Spain,we are neighbors by a few hundred KMs.
How does the suspension handle in cobblestone roads?
I am an idiot and somehow managed to screw the conversion from mm to inches. What I actually want is to lower it 20mm to 25mm or 0.787 inches to 0.984 inches. Does that change anything in your answer?
Don't break my heart like that
The Following 2 Users Say Thank You to KiK For This Useful Post:
J95 (11-24-2023), x808drifter (10-31-2023)
Old 10-31-2023, 09:08 AM   #7
Racecomp Engineering
KW V3 with 5k/6k rates and OEM top mounts would be my recommendation. Or just the front camber plates if you want more than -2.2 degrees camber in front.
I'm on a similar set up right now with KW based coilovers and it's very good. I live in Baltimore city and the next street over from me is cobblestone. The roads are really bad here too. This set up is the right balance for me and how I use my car right now. About 20mm lower and comfort is important to me.
- Andrew
KiK (11-01-2023)
Old 10-31-2023, 09:39 AM   #8
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
In Paris I had to stop and adjust the suspension because it was terrible😅
The Following 4 Users Say Thank You to Ruben_86_ For This Useful Post:
J95 (11-24-2023), KiK (11-01-2023), MrSkubi (11-02-2023), Shark_Bait88 (11-07-2023)
Old 10-31-2023, 09:45 AM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
Yes
Old 10-31-2023, 01:31 PM   #10
CSG Mike
CSG Mike's Avatar
V3 with slightly higher spring rates.
KiK (11-01-2023), Racecomp Engineering (10-31-2023)
Old 11-01-2023, 01:06 PM   #11
KiK
KiK's Avatar
Drives: 20’ GT86
- Andrew
Thanks for the answers guys! What exactly is the point of retaining OEM top mounts? Reliability? Noise? Wont it make the adjustment window more narrow?
Regarding the spring rate, so the plan is to order the KW V3 and swap the springs from the rear coil to the front and buy this for the rears:
I believe this setup conforms to the setup you guys suggested.
J95 (12-20-2023), MrSkubi (11-02-2023)
Old 11-01-2023, 01:26 PM   #12
OEM top mounts just improve comfort and will be quiet. The KW camber plates are pretty good in that regard, but nothing will be as good as OEM.
You could also use the Pedders top mounts that are like OEM but add camber and caster.
Yes 60-200 will work great.
Edit: 60-170 is better.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (11-02-2023), J95 (12-20-2023), KiK (11-03-2023), Ruben_86_ (11-10-2023)
Old 11-02-2023, 02:39 AM   #13
CSG Mike
CSG Mike's Avatar
Based on your stated use case, it is for comfort.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
J95 (12-20-2023), KiK (11-03-2023), Racecomp Engineering (11-02-2023)
Old 12-20-2023, 05:57 PM   #14
J95
J95's Avatar
Hey man, did you end up mounting that setup? Can you share your impressions? I think about doing the same, or even going 5/7 or 6/7, with the KW v3.
@Racecomp Engineering if you don't mind my question what length of springs should I choose? You recommend 60-200, but I saw that KW CS have originally 170 instead of 200.
The oem top mounts vs KW CS top mounts would make any difference in the length decision?
PS - I would love to go for RCE suspensions, but Im in EU and we have huge overprice due to importing and taxes
J95 is offline   Reply With Quote
KW Clubsport 3-way Valving TRAKRAVN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-20-2019 10:45 PM
Using KW Clubsport top mounts for KW V3 thpark93 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-20-2019 11:39 AM
Tein SRC vs. KW clubsport 86wtywly Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 04-02-2017 04:55 PM
