Old 02-15-2023, 03:58 PM   #1555
Zombiecidal
Zombiecidal's Avatar
Drives: 2018 BRZ Ts
yeah they are rare thats for sure, maybe with the lack of support its not a good idea to get one at this point
Zombiecidal is offline   Reply With Quote
Old 02-15-2023, 06:42 PM   #1556
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I would say the lack of support in terms of tuning, no. But if you have technical issues with the supercharger itself, like the intercoolers, the blower, or even piping, it may get tricky. If you are savvy with working on that stuff, I'm sure you could make do.
MS, CSCS, TSAC-F, CPT
Old 03-01-2023, 12:58 PM   #1557
Koba
Drives: 2020 BRZ
I may consider selling mine if the price is right. Brand new, still on the original shipping crate and box, stored in a climate controlled environment.
Koba is offline   Reply With Quote
Old 03-08-2023, 11:28 PM   #1558
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
I am looking for a Cosworth kit if anyone is willing to part ways with theirs. I've been looking for ages! Thanks.
drew_kar is offline   Reply With Quote
Old 05-20-2023, 04:31 PM   #1559
eMCee
eMCee's Avatar
Drives: GT86
Hi guys,
Quick owners update regarding the kit.
As I was doing some annual maintenance around the car, I've noticed (sine some time ago to be honest)a thin sweating of oil going on both sides and on the back the SC, where it's connecting to the manifold. See photos for details.
What do You think, should be this an easy fix as replacing the liquid seal around the sc, intercooler cores and manifold?
My guess is, the only place the oil can go from is the sc gears on the front, so I'm wondering how is it looking inside.
Matt@Cosworth can You provide some hints to that? Are those assembled with some three-bond liquid seals (similiar as oil pan)?
Front right side, just after engin get into temperature.
Back of the ICs
Wet screws on the back of the IC assembly.
Some oil even accumulated on top of the engine
Cheers
eMCee is offline   Reply With Quote
Old 05-20-2023, 04:33 PM   #1560
tomm.brz
Drives: brz 2017 hksv2
write him directly... matthew.feasey@cosworth.com
eMCee (05-20-2023)
Old 07-04-2023, 09:29 AM   #1561
TurboBRZ_UAE
Drives: 2015 GT86 SC; 2014 BRZ turbo (sold)
Hi Folks,
Anyone have any details on the Idler pulley replacement (part number 20047175 in the manual)?
The bearing has gone on mine and I need to replace it. Trying to get to a track day this Friday and am looking at any alternatives that I can source locally if possible.
Thank you
TurboBRZ_UAE is offline   Reply With Quote
Old 07-04-2023, 11:14 AM   #1562
TurboBRZ_UAE
Update: Matthew from Cosworth has been incredibly helpful.
If anyone is having a similar issue and is googling this in 10 years time, here's what I found: The bearing on Cosworth supercharger kit idler pulley (part number 20047175) is 17mm Inner Diameter, 40mm Outer Diameter, and 12mm wide
Old 09-19-2023, 05:24 PM   #1563
ajc209
Drives: GT86 Cosworth
Originally Posted by eMCee View Post
Hi guys,
Back of the ICs
Cheers
Did you ever get to the bottom of this? Mine is doing this too.
ajc209 is offline   Reply With Quote
Old 09-19-2023, 05:29 PM   #1564
ajc209
Originally Posted by botbs View Post
I changed the PCV and it worked all the blue smoke are gone. Also make sure not to overfill engine oil
I have the blue smoke when starting the car, particularly after tracking. After looking into it I don't see how the upgrade PCV valve will help as its connected pre blower so shouldn't ever see boost?
Old 09-23-2023, 06:09 PM   #1565
eMCee
eMCee's Avatar
Drives: GT86
Hi, @ajc209
Yes I did. Update for the story is pretty short and not so difficult.
The o-ring cord between the SC and inlet manifold (nr.5 on the drawing below) had enough. We replaced it with a 2mm one, but Matt advised 1,6 or 1,75 should be also fine.
I'm just not sure if that's a garage job since You need to take out all the SC assembly and take it apart to get to the screws (nr.8) hidden behind the intercooler cores.
In my case it came out that one of the seals under the inlet manifold was starting to let go so I've ordered a new pair from Cosworth, and we replace both of them as a precaution.
<Unrelated to the previous post>
As car was already in the workshop a few other parts was installed (14mm oil pump rotor from Reimax, Cossie baffle plate, KillerB oil pickup line, thermo plate with oil coller, and a TRD sensor sandwich plate for the oil temp and pressure sensors). Oh man 12AN oil lines will be fun to go around when replacing the air filter .
Cheers
Old 09-24-2023, 12:54 AM   #1566
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Did you also check the oil level? I changed both (PVC and oil) at once so it may be the overfill for my case.
botbs is offline   Reply With Quote
Old 10-04-2023, 05:23 PM   #1567
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Hello All
I should say I'm happy to support anyone whom has fitted a kit and needs a tune
just PM me if required I'll try and remember to check in more regularly from now on
plus we still have some parts in stock ( just not chargers) so if folks need spares we can help although to be honest the issues to date have been replacement seals and idler bearings
all of which can be sourced locally for most
Matt@Cosworth is offline   Reply With Quote
The Following 8 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (10-16-2023), botbs (10-24-2023), Code Monkey (10-04-2023), DocWalt (02-01-2024), eMCee (10-04-2023), sly (06-16-2024), TurboBRZ_UAE (10-10-2023), weederr33 (01-26-2024)
Old 01-26-2024, 01:53 PM   #1568
botbs
botbs's Avatar
Originally Posted by Matt@Cosworth View Post
Hello All
Hi Matt,
Nice to see you here and continue to provide support to us!
Just wondering did you help this person to retune his SC? It appears he swapped the 2400cc engine in his BRZ
Thanks!
The Following User Says Thank You to botbs For This Useful Post:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
