Old 12-07-2022, 02:38 PM   #1471
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Originally Posted by Falkon240 View Post
Happy to see you here. Perhaps we can wake up the sleepy drift community on this board.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 09-30-2023, 05:36 PM   #1472
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
Guys my sway bar end links are rubbing against my lower control arms on just one side. Do I just tighten that side to fix it?
rilagin is offline   Reply With Quote
Old 09-30-2023, 05:41 PM   #1473
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
Also thanks for all your help guys I have been drifting my pos around with the gk tech kit and its a ton of fun.
Old 10-01-2023, 04:51 PM   #1474
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Sway bar should be above the control arm, that end link needs to be like 3” shorter, I presume on both sides.
ineedyourdiddly
Old 10-02-2023, 10:01 AM   #1475
raspec
raspec's Avatar
Drives: 2017 Subaru BRZ
You could get a high-misalignment endlinks, Hotchkis makes some good ones
Hotchkis front swaybar end links https://www.hotchkis.net/product/hot...d=21598&sm=268 part no 25445F at Summit Racing or elsewhere
raspec is offline   Reply With Quote
Old 10-04-2023, 11:36 AM   #1476
terboboost
terboboost's Avatar
Use RSX endlinks and relocate to LCA. Prevents any binding as you move through steering angle.
Old 10-04-2023, 12:06 PM   #1477
raspec
raspec's Avatar
that also works, but requires drilling the LCA. Do you have a pic of your setup?
Old 10-04-2023, 03:30 PM   #1478
terboboost
terboboost's Avatar
Here you go
Old 10-14-2023, 09:10 PM   #1479
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
My lower control arms are already pretty fucked and I like the relocation idea I'll probably do that if tightening my current ones to the max doesn't work.
Old 11-18-2023, 02:09 AM   #1480
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
So what's the deal with the Megan Inners and swaybar endlinks binding? Do they hit the strut body with the added angle? I'm thinking of running these with a stock suspension and about -3 degrees camber in the front, will it exaggerate the issue? Will an adjustable endlinks help?
Arthur-A is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
