Old 09-25-2023, 04:12 PM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Can a sequential transmission be driven like a "normal" transmission? If so, the rest of the drivetrain would last a lot longer. (IMHO)
Old 09-26-2023, 12:05 AM   #16
eyeballs
Drives: '22 BRZ
Originally Posted by Opie View Post
Toyota pulls data from every car after every on-track session including practices, qualifying and races. Speaking with the lead engineer at one of the larger, more successful teams...the data that has been pulled from the few engine failures has shown it was not an oil pressure, or mechanical issue....but from driver mistakes that exceed the limitations of the engine and/or from teams not running the recommended oil.
There were zero engine issues at Sebring, a few clutch issues, axle & diff issues and a bunch of bent wheels....
Do you know what oil they are running?
eyeballs is offline   Reply With Quote
Old 09-26-2023, 08:59 AM   #17
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Toyota recommends Mobil 1 Supercar Synthetic Motor Oil 5W50. But teams have been known to try other, "lighter", weights/brands, etc to try and improve performance...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
eyeballs (09-27-2023)
Old 10-01-2023, 02:48 AM   #18
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
I had a few questions about the cup cars - someone here may be able to enlighten me.
Is there no front/rear brake bias adjustment? The version in iRacing doesn't have that, and they tend to be pretty faithful to the actual cars. Back end really kicks on me under braking, and I do tend to move the brake bias forward in most front engine cars I race in the sim.
The website also says there is "Stratasys bodywork" i.e. 3D printed. I'd be curious what bits are 3D printed. There's something online about a hood vent, but not much else. I'm curious if its on the R&D / rapid prototyping side or actual "production" (however limited that is) parts.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 10-09-2023, 12:31 AM   #19
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Have you tried tweaking your front toe setting to be a little out? Might increase breaking stability a bit. Not that I know if you can do that in iRacing.
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
22 BRZ (10-10-2023)
Old 10-09-2023, 07:58 AM   #20
Opie
Opie's Avatar
Correct, no bias adjustment. But your problem is likely due to the sequential transmission. On downshifts the transmission is always engaged, unlike a standard manual that is disengaged when the clutch is pressed. Try left foot braking, and downshifting later than you normally would (to match the speed). Also as mentioned, toe and castor can help alot with braking stability.
As far as the 3d printed stuff, I know the hood vent is, don't recall seeing any other noticable body work.
The Following 2 Users Say Thank You to Opie For This Useful Post:
22 BRZ (10-10-2023), Blighty (11-03-2023)
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 04:52 PM
2022+ Subaru BRZ & Toyota GR86 Arctic Series Oil Cooler Kit ColorFittings Engine, Exhaust, Bolt-Ons 0 03-02-2022 02:26 AM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
EverydayDriver Series on Youtube Th3rdSun FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 01-20-2017 09:05 PM
YouTube Series FRSNewb Off-Topic Lounge [WARNING: NO POLITICS] 1 04-04-2014 04:26 PM
