Old 09-30-2023, 10:58 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Imaginary Rev Limiter Intermitantly? / oil temp?
Hey Guys,
Have experienced this a few times at the track(Drifting).
I'll clutch kick the car and get right back into it and it seems to have almost like a clutch activated rev limiter(dont quote me on exact RPM).
The car was pretty stock when i bought it but who knows could of been tuned and returned back to stock half assidly?
Just wondering if anyone has any kind of outlook on this.
Car is being driven with ABS removed as well so its not a traction control related thing or anything, had a pro driver hop in for some fun runs and he noticed it too and then drove around the car avoiding clutch kicks.
Also after quite a few hot laps got a flickering oil light, oil level ok but also hard to judge since im sure it can read high on the stick from sloshing around.
Any kind of thing I should be aware of on that? Assuming I may of just gotten the oil really dang hot and she was low on pressure, I killed it and parked up after that. Car seems fine now. I plan on dropping the pan this week.
2013 BRZ
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 09-30-2023, 02:02 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
your profile says your car is turbo'd, which would mean the car has a tune. have you ran a logging session during one of these times?
i really suspect your tune, likely something about the shock load to the motor is hitting some sort of software 'switch' that is triggering to attempt to protect the engine.
Old 09-30-2023, 04:37 PM   #3
nickmerronesucks
Ned flanders
I apologize, this is a new car.
Bone stock other than angle kit & coilovers
797Performance.com
Old 09-30-2023, 06:04 PM   #4
soundman98
soundman98's Avatar
how is the ABS removed?
i'm wondering if the system is still trying to trigger..
nickmerronesucks (10-01-2023)
Old 09-30-2023, 08:29 PM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I had a similar experience with a tune, "flat foot shifting" was enabled. Prior to shifting, a light touch on the clutch pedal dropped the spark advance to 0*. Hence: rev limiter.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
RedReplicant (10-02-2023), soundman98 (09-30-2023)
Old 10-01-2023, 07:49 AM   #6
nickmerronesucks
Ned flanders
I like to think this could be right but I’m unsure how to tell if this thing was tuned or not to be honest. It definitely doesn’t feel like it drivability wise lol.
797Performance.com
Old 10-01-2023, 07:50 AM   #7
nickmerronesucks
Ned flanders
Just removed fuses I think I had a brain fart typing and forgot a word Lol
It’s very inconsistent, for example I’m on the bank of English town and need a little UMPH So I give her a clutch kick and boom now I’m at 3500 rpm rev limiter aimed at the wall lol
797Performance.com
Old 10-01-2023, 09:44 AM   #8
soundman98
soundman98's Avatar
i would try the pedal dance to remove the vehicle slip corrective actions from the equation.
if the vehicle detects a slip, it typically activates ABS for individual wheels, as well as cuts throttle.
i think you're getting the throttle cut where the car is trying to 'correct' the situation, and would be activating ABS, except the power to the module no longer exists.
nickmerronesucks (10-02-2023)
Old 10-01-2023, 10:51 AM   #9
blsfrs
blsfrs's Avatar
When accelerating in 2nd or 3rd, 3/4 to full throttle, put your foot lightly on the clutch pedal. If the engine almost cuts off, FFS is working.
This is what I went through.
https://www.ft86club.com/forums/show...+foot+shifting
nickmerronesucks (10-02-2023), RedReplicant (10-02-2023)
Old 10-02-2023, 09:57 AM   #10
nickmerronesucks
Ned flanders
I run no ABS fuse all the time to avoid any of that
797Performance.com
Old 10-02-2023, 09:58 AM   #11
nickmerronesucks
Ned flanders
I'll try that as soon as I get the oil pan back on! Thanks man
797Performance.com
The Following User Says Thank You to nickmerronesucks For This Useful Post:
blsfrs (10-02-2023)
Old 10-04-2023, 11:32 AM   #12
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Any you are only pulling the single green fuse, right?
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
The Following User Says Thank You to terboboost For This Useful Post:
nickmerronesucks (10-08-2023)
Old 10-05-2023, 01:25 AM   #13
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
We
Hey Guys,
2013 BRZ
If car is ecutek tuned I'd say tuner has activated flat foot shift feature, whan you clutch kick it won't let the rpm increase of current rpm.
Fix will be to disable flat foot shift feature in tune or at least disable it on one or more of the map me des if you want to clutch kick to get wheel spin
FFS is engaged if throttle is over 85 percent and you press clutch
Flickering oil light is a worry it means oil pressure is dropping below about 3 psi.
It's just a simple pressure switch it doesn't go through ECU. So if that's real and pressure switch is not broken you oil pressure is dangerously low
I'd assume your running an oil cooler and at least 5w30 or 10 w40 oil and you oil temps are less than about 120C max if not I'd check that out asap before you need a new motor
AussieBRZ is offline   Reply With Quote
The Following User Says Thank You to AussieBRZ For This Useful Post:
blsfrs (10-05-2023)
Old 10-08-2023, 12:06 PM   #14
nickmerronesucks
Ned flanders
yes any more you think?
797Performance.com
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
Design Proposal for a New VW Corrado from the Imaginary World of "What If?" vh_supra26 Other Vehicles & General Automotive Discussions 2 02-13-2010 06:26 PM
