Old 06-13-2023, 10:42 PM   #463
warhawk03
Drives: 2018 BRZ
Check the factory camber bolt. If theyre both pointed "left" if looking at the car from behind, for example, this would make the camber plates uneven!
Alternatively, most cars do not have perfectly centered subframes, which can result in a slight deviation left/right, but not as much as shown in the previous picture.
Sorry to revive an old post, but looking at my camber plates, I'm seeing the same thing. I'm at about -2.8 and can't get anymore since one side is maxed out. Both factory camber bolts on both sides are pointed toward the front of the car, which matches the OEM direction. Maybe it's just the subframe being uneven?
warhawk03 is offline   Reply With Quote
Old 06-13-2023, 10:56 PM   #464
CSG Mike
CSG Mike's Avatar
Can you post a photo of both camber plates please?
CSG Mike is online now   Reply With Quote
Old 06-14-2023, 08:31 PM   #465
warhawk03
Drives: 2018 BRZ
Old 06-14-2023, 09:08 PM   #466
CSG Mike
CSG Mike's Avatar
@warhawk03
That's pretty extreme.
If you have camber bolts, check those to make sure one isn't accidentally in the wrong way, making you lose negative camber on that side!
Old 06-14-2023, 09:20 PM   #467
warhawk03
Drives: 2018 BRZ
Thanks, I'll check it out. Odd for sure.
Old 07-26-2023, 01:14 PM   #468
Dububster
Dububster's Avatar
I’m looking at a used set for a pretty good price but both fronts have tears in the dust boots. How difficult would it be to replace those? I’ve swapped the oem springs so would the process be fairly similar?
Dububster is offline   Reply With Quote
Old 07-28-2023, 06:53 PM   #469
CSG Mike
CSG Mike's Avatar
Quite easy.
Old 07-31-2023, 11:03 PM   #470
Dububster
Dububster's Avatar
Quite easy.
Do you know the part number for the front dust boots?
Old 08-07-2023, 04:46 PM   #471
CSG Mike
CSG Mike's Avatar
Negative, but if you call Tein directly, they'll be able to supply it for you. It's a common part.
Old 09-22-2023, 01:52 AM   #472
se7en_force
Drives: BRZ 2013
How cushy are these?
my bad if this has been answered in this thread. I've been diving into comfort opinions on the CSG Tien A's and someone said it could be as comfortable as a Lexus. I'm not mad at that, is that true? How comfortable can these "feel" if compared to cushy sedan?
se7en_force is offline   Reply With Quote
Old 09-25-2023, 01:07 PM   #473
CSG Mike
CSG Mike's Avatar
If you back the damping way off, it will literally drive like a luxury boat. It'll float over things, and also handle like doodoo, but feel quite cushy. Think Lexus ES or LS, not IS/GS. Or a Merc E class, non-AMG.
Old 09-26-2023, 12:16 AM   #474
fancymalard
fancymalard's Avatar
Drives: 2013 Scion FRS
You may have difficulty using a standard torque wrench, as you'll just spin the damper shaft (don't do that!)
What happens if you spin the damper shaft (mounted on the car) with a torque wrench? Asking for a friend...
fancymalard is offline   Reply With Quote
Old 09-28-2023, 02:24 PM   #475
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
On any other strut, it can damage the seals inside. Then you end up with a leaking strut. Keyword: "Can". Very likely the same with these.
cmiovino is offline   Reply With Quote
Old 09-28-2023, 10:23 PM   #476
fancymalard
I only turned the shaft a few times, so hopefully, I didn't ruin the seals. Did a quick inspection on them today and so far no leaks. I guess time and mileage will tell. Ugh, I'm kicking myself in the head for doing that.
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 12:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
