Drives: 2017 BRZ w/PP
AC delete pulley that works with JRSC kit
Title says it all. I got the JDM delete kit because my ac was 150psi on both sides and decided to install it since i shredded my belt at autocross. The pulley is too big. Mad an ass out of myself not measuring first
#2 |
Rust bucket enthusiast
I wonder what size pulley the Raceseng delete uses?
#3 |
I guess i could just measure the pulley size with calipers. I'm going to call jackson racing tomorrow to see what they say. Also to see if i can get a new spacer since i had to hit it with a belt sander to clearance it because the delete kit isn't perfectly flush. |
#4 |
use a marker to mark the difference in length of belt it takes to wrap halfway around each of them. Add it to the length of your current belt. Get the closest match.
Or do the pulleys actually interfere with each other?
#5 | |
![]() it interferes. I don't remember if the belt hits the brace or the pulleys touch but it cant even mount flush if it wanted. I had to clearance the spacer with the 14mm nut on it maybe 1/2 a mill on one side too for it to sit flush with the delete. I was going to try and remove the compressors pulley but that one is splined. Now that I cut the lines it probably would be a bad idea to slap the compressor back on until I can get a solution I would assume. At least all the belt pieces washed out of the filter pretty easily. Is a belt lasting an autocross season now a reasonable expectation? |
#6 |
It would be fine to just use the compressor installed. Nothing would engage without pressure in the system and even so, leave the clutch solenoid disconnected and "poof" instant idler pulley.
#7 | |
The worst part was since I was in there and already crossed the rubicon by disconnecting the hardline from the compressor I started to prep for hardline removals and found a connector with a damaged wires near the fuel lines. Not sure what it does but it connected to an AC hardline. I wonder if it controlled some kind of valve. That project car life :\ |
#8 | |
#9 |
Thanks but i already have it saved on my tablet. I guess my point was up until i disconnected the hardlines, i could have just refilled it up, but i noticed the connector after it was out and i started cutting. Pretty sure the compressor was shot but this one might have been self inflicted
#10 | |
#11 | |
I just looked it up and it was labeled as AC Pressure sensor on the diagram. Im guessing that is why I would hear it click on and off but it just make heat. I must have snagged it removing the old block/installing the new block. I'm sure if that didn't break it trying to run the AC on max multiple times broke whatever was still working. I have a few parts numbers for pulleys +/- 5mm of the AC's and going to see if any parts store has them. The newest being the idler from an s10 so I'm not holding my breath. |
#12 | |
I just got off the phone with jackson racing and this is what they recommended. I thought it originally sounded too dumb to work but that's 2 parties that said its good so that is what I'll do. I'm not sure if i looked this up or not before buying but for anyone searching, the JDM ac delete kit is confirmed to not work with the JRSC kit. |
| The Following User Says Thank You to Breadman For This Useful Post: | Ultramaroon (09-22-2023) |
#13 |
Famous Potatoes
Drives: '15 ultramarine
https://www.ft86club.com/forums/show...&postcount=333
Several years ago I remember seeing a video of guys building a car that put a delete with jrsc. They did some machining to the mount. If course, can't find it now. Last edited by Sapphireho; 09-23-2023 at 11:58 AM. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (09-23-2023) |
#14 | |
Pretty interesting idea but I'm just pulling out the hardlines and heat exchangers and slapping the old compressor back on |
| JRSC C38 with an RS Pulley | majixmatrix | Forced Induction | 62 | 03-10-2020 08:42 AM |
| Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) | DarkSunrise | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-30-2017 11:39 PM |
| Works ab-r muffler delete | Gofrs | Engine, Exhaust, Transmission | 5 | 08-11-2014 06:16 PM |
| WTB: Works AB-R or Berk Dual Delete; UEL | drummer261982 | Want-To-Buy Requests | 3 | 02-19-2014 12:32 AM |
| WTB Berk Dual Exit Muffler Delete or Works AB Delete | Admired | Want-To-Buy Requests | 2 | 09-10-2013 04:20 PM |
