#15 |
Drives: Toyota GT86
Do you happen to know if there is any info on the JR race when it comes to pressure drop ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#16 |
Drives: '23 BRZ
FWIW I ran 50 track days with my '17 BRZ PP, hitting upwards of 275F indicated at every single one of them. Usually ran 5w30 but also 0w20 for a few events. Never any issues. Friend's '17 with similar street/track miles as mine had his fail at Palmer MA last year, and he ran an oil cooler.
I think the indicated temperature is a calculated/adjusted value, not straight reporting from the sensor. I can't find it now but somewhere in these forums someone reported that 275F indicated corresponds to 255F measured sump temp. That's down to where you'd be ok with non-synthetic even (not that I would recommend it). Synthetics are good for sump temps up to at least 300F. Obsession with lower oil temperatures in these cars is IMO misguided. It would be one thing if high track oil temps correlated with failure rate, but as near as I can tell as many failed tracked engines have had oil coolers as not. I researched that obsessively for months before I bought my first BRZ in Dec. 2017 and then again after I started tracking it. No correlation between failures and cooler vs. no-cooler. |
#17 |
Drives: Toyota GT86
Any information on why your friends motor failed ?
#18 |
Drives: '23 BRZ
#19 |
Drives: Toyota GT86
Oh okay. I wonder if logging oil pressure could help catch something like that before it’s too late. Thanks for the info
#20 | |
Drives: 2013 frs base
https://www.ft86club.com/forums/showthread.php?t=153935 I had a huge drop as well. https://www.ft86club.com/forums/showthread.php?t=153186 |
#21 |
Drives: Toyota GT86
Thanks for the links. I will be logging oil pressure for my next track day. Hopefully I don’t need to remove the oil cooler
I won’t be buying the jr dual that’s for sure…I have a first gen fyi so not sure how much of the info is the links apply. Either way it was a good read
#22 | |
IMHO: The oiling systems in the 2 engines are similar enough where the pressure drop due to cooler restrictions should be comparable. As I understand it, the issue with the Gen 2 is with right turns due to pan and pickup configuration. If you are comfortable with @ZDan's research, a cooler is a waste of time and money. |
#23 |
Drives: '23 BRZ
Yup. I am 0% worried about running Redline 5w30 (or even Subaru 0w20 really) at 275F indicated oil temp. But I am strongly considering an Accusump for the '23, as pressure drop in right handers is a known real thing, and failures are happening. Ansix Auto has a great vid documenting pressure drops before and after Accusump, goes from being frankly quite worrying, to meh, prolly no big deal...
#24 |
Drives: Toyota GT86
I’m more worried about pressure than temps. I will just see what the data shows after my next track day and go for there.
#25 | |
Weight Weenie
Drives: 15 FR-S
It's cheaper and more beneficial to just drop the oil. I drop it every 2-3 track days. It's about $35 CDN without filter. It's not worth getting an analysis done. Yes, it could be overkill but it's cheap insurance. |
#26 | |
#27 |
Drives: '23 BRZ
#28 |
| Tags |
| haha |
| Full Race external oil cooler kit | duqx | Engine, Exhaust, Bolt-Ons | 1 | 01-20-2019 08:41 PM |
| External mic placement | Shark_Bait88 | Tracking / Autocross / HPDE / Drifting | 22 | 06-13-2016 06:39 PM |
| Anyone have info on the BRZ OEM external oil cooler (Japan only)? | mav1178 | Engine, Exhaust, Transmission | 5 | 04-22-2016 12:20 AM |
| External Wastegate Question | TurboBRZ | Forced Induction | 23 | 07-22-2015 12:38 PM |
