Old 07-30-2023, 01:51 AM   #43
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Got a box from Japan on Friday. Immediately forgot it at my desk. JDM Toyota black interior and another shift knob.
Lent the BRZ to a friend from Ontario, he took it to see some dinos and the mountains.
villainous_frx is offline   Reply With Quote
The Following 4 Users Say Thank You to villainous_frx For This Useful Post:
jongers (07-30-2023), KMA KiCKz (07-30-2023), RedReplicant (07-30-2023), Teseo (07-30-2023)
Old 09-04-2023, 01:54 PM   #44
villainous_frx
Off to the track!
Hard to beat the views of the mountains.
The Following 8 Users Say Thank You to villainous_frx For This Useful Post:
Code Monkey (09-04-2023), gt5759 (09-05-2023), KMA KiCKz (09-11-2023), Racecomp Engineering (09-07-2023), RedReplicant (09-04-2023), RToyo86 (09-04-2023), Tatsu333 (09-04-2023), Ultramaroon (09-04-2023)
Old 09-07-2023, 09:40 AM   #45
Those STI wheels just look so darn...classy in silver.
- Andrew
alex87f (01-20-2024)
Old 09-08-2023, 06:38 PM   #46
villainous_frx
Off to the track!
- Andrew
They're definitely a sharp wheel, probably one of my favorite OEM 5x100 wheels. Unfortunately the previous owner of them in Japan parked by feel, so all 4 have 3-6" of rash on the outer lips :/
Old 10-13-2023, 10:52 PM   #47
villainous_frx
Off to the track!
Swapped in an FRS cluster face and needles. The day I picked up the car was the first time I ever noticed the BRZ cluster and I haven't liked it ever since. With this swap I retained the factory BRZ cluster, so my odometer is still the original and the red backlighting remains. Also noticed that the BRZ face didn't even have a cut out for TMPS like the FRS does, weird that the "base" model car has what the top trim does not. Not really complaining though!
The Following 5 Users Say Thank You to villainous_frx For This Useful Post:
Prodigalson (12-11-2024), RedReplicant (10-16-2023), RToyo86 (10-21-2023), whataboutbob (12-31-2023)
Old 12-30-2023, 07:32 PM   #48
villainous_frx
Off to the track!
Picked up a used set of TOM'S tail lights for the car, and an auto-dim mirror from https://hachielectronics.com/. I should do an oil change soon...
Happy New Year to the 3 people who got this site to load lol.
The Following 6 Users Say Thank You to villainous_frx For This Useful Post:
alex87f (12-31-2023), Overdrive (01-01-2024), RedReplicant (12-30-2023), RToyo86 (12-31-2023), Tatsu333 (12-31-2023), whataboutbob (12-31-2023)
Old 01-18-2024, 12:40 AM   #49
villainous_frx
Off to the track!
Too cold to do any exterior work and ice could damage the parts. Did an oil change and swapped steering wheels with a Toyota Japan red side steering wheel. Matches nicely with the STI push button and other red accent lights. Potato photo, but it is what it is lol.
The Following 3 Users Say Thank You to villainous_frx For This Useful Post:
NoHaveMSG (01-18-2024), RedReplicant (01-18-2024), RToyo86 (01-19-2024)
Old 01-19-2024, 09:11 PM   #50
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You currently dealing with that nasty -40 business out west?
How does the twin like that?
Old 01-24-2024, 12:39 AM   #51
villainous_frx
Off to the track!
Car was fine, driver did not enjoy it. It was pretty dry at those temperatures, no new snowfall. The week after we got ~7" and now it is all slush.
Old 05-09-2024, 10:09 PM   #52
villainous_frx
Off to the track!
Hit 200k km. Decided having a sensible stock height daily is silly. Kics spacers on order and will be installing the Ohlins off of the 86. Also got a set of BRZ PP wheels for super cheap, though the guy who I bought them from seems to have attended the same park-by-feel driving school as the previous STI wheel owner.
Now to install parts and decide on some tires for the PP wheels. A bit torn between a sensible daily driving tire and something cheap to take drifting.
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
KMA KiCKz (05-17-2024), Ultramaroon (05-16-2024)
Old 05-16-2024, 11:00 PM   #53
villainous_frx
Off to the track!
Drivers rear caliper expired right at 200,003 km lol. Rockauto replacement installed, brakes bled, and Endless MX72+ installed.
Code Monkey (06-11-2024), KMA KiCKz (05-17-2024), RToyo86 (05-19-2024), Ultramaroon (05-16-2024)
Old 06-11-2024, 01:49 AM   #54
villainous_frx
Off to the track!
Got some cheapo tires mounted for a drift day, now just need my calendar to clear. Also swapped AC condensers, just need to get the system filled now. Unfortunately the car decided that with the new condenser, a wheel bearing would die. I blame the mechanic. He definitely broke this unrelated system.
Spuds (06-11-2024), whataboutbob (06-11-2024)
Old 06-11-2024, 01:40 PM   #55
RToyo86
RToyo86's Avatar
Rear bearings might be one of the few things I won't tackle my self. Everything I have read suggest it'll be a royal PITA.
Ps mix and match wheels!
Old 06-11-2024, 09:44 PM   #56
villainous_frx
Off to the track!
Fortunately I have spares for every corner on the car, and already have a new bearing in a knuckle to bolt right onto the car. (Un)fortunately I will also be doing the coilovers and new toe arms at the same time.
Quite easy when you have 8 wheels that are all 17x7.5 +48!
Mim's daily driver Mim Member's Car Journals 13 09-05-2017 12:55 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 09:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
