#897 | |
The Dictater
Drives: '13 Red Scion FRS
Also: "Build Thread" |
#898 |
Drives: Q5 + BRZ + M796
I don't see how. Drilling into the roof seems unnecessary in most situations where a bracket system could extend over the top of the roof and extend to the edges of the house and drill into the siding instead.
#899 | |
Drives: Crapcan
That only addresses roof penetration. If you are replacing a roof you still have to pay to have the system disconnected and removed, then reinstalled. You would also never drill into modern composite siding to mount something that needs much support. Modern siding like Cemplank/Hardyplank are not structural. You would need to cut it away and mount to the sheeting.
#900 |
Seems that still has to be moved to reroof the house, and will add a ton of labor cost.
Frankly, if forced, I prefer the Tesla method where the shingles are the solar panels, even if they are less efficient.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#901 | |
Drives: 2013 frs base
They would not put panels on a roof that was more than 12-15 years old. Ours is 6-8 years old. |
#902 | ||
![]() ![]() Quote:
I'm more of a DIY type of person, so I would have no problem removing the solar system, and I would probably have installed it myself too. I get that most people would not feel able-bodied to be on a roof or comfortable removing panels, in which case, it would be more expensive to replace their roof every 15 years. This is a more traditional install. Seems like everything would unbolt and unclip. The glued parts could be removed from the shingles without concern of damage if a new roof was going to be installed, but in the event of the boltless system, there is no concern for the bulk of the project--just unbolt and unplug the panels.
#903 |
Drives: 2013 frs red
Oh my God
#904 |
Drives: Crapcan
Uh, if you are attaching to the fascia board what are you mounting your gutters too? You also are not using a table style pinch clamp, soffit is not structural. It just nails to the underside of the fascia board and the runner on the wall as pictured.
#905 |
Drives: Crapcan
![]() This picture also damn near gave me an aneurysm. Why would you vent on the fascia and up under the sheeting instead of just running soffit vents? If you are not running enclosed soffit the back side of the fascia board is open anyway and it isn't doing anything
#906 | |
Again, this would prevent the need to drill into the roof, reduce the risk of leaks, reduce the labor to install and make removal by a DIYer fairly straight forward. The downside is look of extended brackets. ![]() ![]() ![]() ![]()
#907 | |
Drives: Crapcan
![]() Not all homes, especially older ones have the same size facisa, mine are barely gutter height which causes issues trying to get the right slope for gutter drainage. I think this idea will work with some homes, but just saying "this will work" is not feasible in a lot of situations. I've remodeled over a dozen homes, and I can see issues with this type of install on most of them. A lot of what you are saying sounds okay in practice, but from what I have seen in practical use would be a massive headache.
#908 | |
Outside of ornate/victorian homes or something with complex fascial faces or something, I can't think of a situation where this would be a problem. The brackets under the panels would have feet that will raise like under a table, so everything fits tight against the roof. There would be an extension over the top of the roof to the other side with two to three (depending on the length of the solar panels) anchoring point that C-bracket to the side of the fascia board and gable truss or G-bracket to the underside of the fascia board and gable truss. Bolts would probably be fine in either case, but a pinching mechanism would be fine too, either pinching the house or the gable truss. If you install a horizontal/parallel rail system on the side of the roof into the truss on the gable side and into the facia board then you could have a clamping system to lock onto in a very similar way that a car roof wrack pulls the rack into the roof. Hook one end into the rail and then slide the bolt up through the solar panel bracket and bolt down. That should clamp it down to the roof. It wouldn't be too hard to make something that works with existing overhangs to drill into the wood or to grip onto trusses or to the underside of the fascia. This isn't complicated engineering to figure out, and it wouldn't be expensive and would probably appeal to DIYers and would lower installation/removal time/costs for a minimal change in aesthetics. All bracketry can be paint matched to the siding and roof, so I don't really see this as an issue for me. ![]()
#909 |
Drives: Crapcan
You are assuming everything to be in good condition. I don't think I have ever done a roof that didn't have some rotted rafter tails, rotted fascia, or sections of either failing. I wouldn't have much issue going to the gable end but I don't think I would want to mount anything to the fascia like that without going under and adding some runners to distribute the load better. I'd personally be better off putting them on my shop roof, though that has it's own issues as the pitch is pretty mild.
#910 | |
| Tags |
| youguysneedlives |
| Planet Earth: The Car Enthusiast | sniffpetrol | Other Vehicles & General Automotive Discussions | 1 | 02-03-2018 10:54 PM |
| Planet Eclipse Geo2 | Gt86_nick | Miscellaneous | 0 | 11-01-2014 10:53 PM |
| Planet Audio 2250D amplifier | Noob4Life | Audio/Visual, Electronics, Infotainment, NAV | 1 | 09-16-2013 07:33 AM |
| Like saving the planet? read this | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 02-14-2013 06:09 PM |
