Old 08-24-2023, 08:46 AM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Dap your finger in to spot and take a whiff. Gear oil will usually smell like pine or cedar. Motor oil will smell like vasoline.
Old 08-24-2023, 09:02 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Stevedave View Post
Is that gap anything to be concerned about?
nope, that gap is where there ought to be fluid leaking out if the output shaft seal was bad.
Ultramaroon (08-24-2023)
Old 08-27-2023, 09:56 PM   #17
soundman98
soundman98's Avatar
blsfrs, it definitely smells like gear oil.
I went to clean the 3 spots in the driveway, but the rain took care of the two smaller ones. I’ve driven the car 3 times since Friday and no leaks on the concrete. I’ll continue to monitor.
it wouldn't be condensation from running the a/c would it?
because speaking from experience, rain does not normally remove transmission fluid, or engine oil stains. at least anything less than torrential downpours resulting in at least 5-6" total rainfalls in less than 2 hours...
Old 08-27-2024, 08:16 AM   #18
Tokay444
Ever get this fixed?
Transmission Synchro/Output Shaft Noise After a Concerning Sound Rybot Engine, Exhaust, Transmission 7 07-01-2022 11:06 AM
Leaking diff. At pinion seal, after replacing Throwout Bearing dc2stud Engine, Exhaust, Transmission 7 02-19-2020 05:23 PM
Any DIY fix for leaking window seal? lupindub DIY (Do-It-Yourself) Guides 9 04-03-2018 09:28 PM
Output shaft bearing mhiscott Engine, Exhaust, Transmission 10 08-09-2016 06:04 PM
AT Transmission rear seal leaking. CircuitJerk Issues | Warranty | Recalls / TSB 6 10-31-2013 03:41 PM
