Old 04-13-2023, 07:28 PM   #1037
tomm.brz
Drives: brz 2017 hksv2
i did what you need to know?
you removed the sexondary o2, disable it in tune, and connect the wideband to the blu cable of secondary o2 plug in engine
Do not use the ground of the sensor plug, just use the blue cable that is the input
Take ground for sensor and power from another source, i took it in the fuse box under the steering wheel
If you put ground into the ecu in the secondary o2 plug, it will give bad readings
Mackizzle86 (04-13-2023)
Old 06-15-2023, 03:22 PM   #1038
Apolllo
Drives: 2018 Subaru BRZ Limited
Quick questions...I have the opportunity to get the HKS GT2 full system With ECU Upgrade for a really good price. From what I have gathered, older HKS superchargers had reliability issues but the GT2 was rebuilt and is supposed to be more durable, correct? If so, I am not too worried about durability.
The big issue that comes up for me is installation. I went through the installation guide and it has cutting a lot of pieces to make this kit fit. It isnt too big of a job for me to do, and I'm confident I can complete the installation by myself, but I don't have any rotary tools or anything like that, so I would have to buy them to get this to work. Has anyone installed the GT2 kit, and does it still require all the trimming of the brackets? Just want to factor in buying of the tools into the cost.
Also, the ECU package says it comes with pre-loaded tunes, has anyone run with this pre-loaded 91 octane tune, and how does it run?
Thanks everyone!
Apolllo is offline   Reply With Quote
Old 06-16-2023, 04:34 AM   #1039
tomm.brz
100% you need to trim metal parts with a rotary tool
hks tune are maf based and lambda-offset, so they run leaner than 14.7 afr during closed loop, then in open loop section they run quite rich and low timing
they are ok, very safe , not so powerfull, quite reliable
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
Apolllo (06-18-2023), new2subaru (06-17-2023), Teseo (06-16-2023)
Old 06-27-2023, 12:34 AM   #1040
Mackizzle86
Mackizzle86's Avatar
the cutting isn't too much of a task. I used an oscillating tool with variable speed and it was quicker than a rotary tool.
I just bought a Mishimoto slim fans too so I skipped cutting the fan part, LoL.
One advice tho, cut your oil cooler hoses at least a half inch longer than what it says in the instructions.
Mackizzle86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mackizzle86 For This Useful Post:
Apolllo (06-27-2023), Teseo (06-27-2023)
Old 08-22-2023, 06:10 PM   #1041
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
Hi HKS S/C gurus,
Can anyone tell me if the JDM spec GT2 kit will work with my USDM spec BRZ? The part numbers are different but the parts look the same as the V3 kit if I'm not mistaken. I have an opportunity for a friend to mail one of these to me and it would be much cheaper than buying a kit here. TIA
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 08-22-2023, 06:35 PM   #1042
tomm.brz
v3 is a different kit than the V2 sold in japan
v2 is also sold in US anyway
you have to choose between v2 and v3, otherwise kits are the same for all cars, besides the hks flash editor unit that no one buys anyway
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
FT86Z (08-23-2023), Teseo (08-23-2023)
Old 08-23-2023, 03:14 PM   #1043
FT86Z
Drift noob
FT86Z's Avatar
I did some reading on V2 vs V3. The kit in question is the 12001-AT012
https://www.hks-power.co.jp/en/produ...arger/db/20246
Do you know if this would be V2 or V3? I see you have the V2, how has the ownership experience been? And which tuning solution did you go with?
FT86Z
藤原とうふ店
Old 08-23-2023, 07:35 PM   #1044
tomm.brz
at012 is a v2 standard kit
it comes out with restrictor 39mm and 90mm pulley
v3 has no restrictor but 110mm pulley so less boost overall, but has also a bigger intake pipe which gives more airflow
Old 08-26-2023, 11:19 AM   #1045
FT86Z
Drift noob
FT86Z's Avatar
Only on pcv side
Recirculated
The typical Radium setup for your dual cans I assume?
FT86Z
藤原とうふ店
The Following User Says Thank You to FT86Z For This Useful Post:
tomm.brz (08-26-2023)
Old 09-03-2023, 09:13 AM   #1046
zachseidy39
Drives: 2014 base manual Raven FR-S
Hi guys I recently bought a used GT2-7040L kit and of course when I got it I wanted to see how it worked and spun it by hand back and forth a few times. I then was doing some reading and it appears that some older models came with a disclaimer not to spin it in reverse. Do you think I did any damage or can I stop being paranoid? Thanks
zachseidy39 is offline   Reply With Quote
Old 09-03-2023, 09:30 AM   #1047
wbradley
Sarcastic SOB
wbradley's Avatar
I have a V2 dyno tuned and with the intake restrictor removed. I think this will be the 8th year and at least 50K km on it trouble free. Stop being paranoid. The oil wouldn't pump internally if spun in reverse at high speed, which would destroy the unit. Also, there's a small spring-actuated mechanism that disengages the internal rollers to some extent at lower to idle speeds. Almost like a centrifugal clutch. This is unique to the HKS system compared to a regular Rotrex based design. It's probably ok, but don't mess with it just to be safe.
The Following User Says Thank You to wbradley For This Useful Post:
Teseo (10-14-2023)
Old 10-12-2023, 01:41 PM   #1048
zachseidy39
Hey guys couple of questions, I got my kit installed and is currently being tuned and running pretty well. Do you guys check the sc oil with the cap screwed in or just resting on the threads? Also it seems like there’s a belt squeal noise that lasts 5-10 minutes every time I drive until the oil heats up, is that normal or will it go away eventually?
Old 10-12-2023, 09:03 PM   #1049
wbradley
Sarcastic SOB
wbradley's Avatar
Let it heat up a bit before pushing it. I dip without screwing. Make sure you use cold weather traction fluid if driving in cold conditions. That squeal is probably the TOB,not related to your SC.
Teseo (10-14-2023)
Old 07-04-2024, 05:44 PM   #1050
gpvecchi
gpvecchi's Avatar
I'm planning to buy a V2 kit, but I read about reliability. Can you please elaborate on it?
Is the problem solved now?
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
