Old 08-16-2023, 01:24 PM   #505
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
I suppose taking a picture would clear things up lol. No siding around the door.
Yeah that's not ideal. Caulking will not solve water seeping in through surrounding porous stone/brick.
Typically you would have a metal flashing that tucks in behind the brick/concrete and extends out to allow positive drainage away from your wall framing. Only then would caulking be suitable against the metal to complete the seal to the door frame.
Ideally there is building wrap/paper/membrane that can lap over the metal trim... much easier to do if siding can be removed and reinstalled. Not the case here unfortunately.
Without knowing the actual assembly of your wall, it's hard to make a firm suggestion. But that door needs to come out to do it properly in any case.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Dadhawk (08-16-2023)
Old 08-16-2023, 09:23 PM   #506
soundman98
ProCrastinationConsultant
soundman98's Avatar
Uhhh, if you are referring to the exterior, I don't think I do actually. I did call the contractor last week and I got a call back about 20 minutes after my post lol. It is mostly fixed now, I just need to paint over stuff.
I have sections of concrete(?) for basement walls, there is a rectangular hole in the concrete, with a wood frame inside the hole. The door frame mounts to the wood. The caulk they initially installed the door with peeled up the old weathered paint on the wood and, being on the windward side of the house, rainwater just poured in. They cut out the old caulk, applied some adhesive sealing stuff in the crack, then re-caulked. It worked with some pretty intense rain and wind this afternoon at least. I'll get some paint on it this weekend and it should be good I think.
i see and understand what you have now. i believe that's officially called an "oopsies" when they poured it oversized.
the first/normal way to repair that would be to strip it out and use a vapor barrier(like this), and pressure treated lumber.
but pressure treated lumber still rots out over time. it's not helped by the difference in expansion rates from the door, and the concrete around it.
the way i would fix it is to strip out the old opening, then add rebar into the existing foundation, then pour new concrete to make an appropriate opening size. still need a gasket like above between the door and concrete, but no longer need flashing.
another alternative here would be to build a small roof overhang over the door opening to divert rain away from it-- then if you were to rebuild the opening with pressure treated lumber, it would last a ton longer.
Dadhawk (08-17-2023)
Old 08-16-2023, 09:52 PM   #507
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The surrounding wood is already pressure treated lumber though. It was fine with the sliding door for 22 years. Then I had a new door/frame put in and the caulk pulled up the peeling paint at the top.
Also: "Build Thread"
Old 08-16-2023, 09:57 PM   #508
soundman98
soundman98's Avatar
i dunno, that day of science class about differing expansion rates of different materials is just screaming at me in that picture.
if it was my house, i wouldn't be able to let it go until i re-poured, or mortared the gap...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Spuds (08-16-2023), Ultramaroon (08-16-2023)
Old 08-16-2023, 10:37 PM   #509
Spuds
The Dictater
Spuds's Avatar
Here goes nothin'!
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Lantanafrs2 (09-03-2023), soundman98 (08-17-2023), Ultramaroon (08-16-2023)
Old 09-03-2023, 03:34 PM   #510
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Helping a friend pull wire from the house to the shop. The string broke while trying to pull the ride through the conduit. Tried to suck a new string through and getting nothing but dirt. So now…
Old 09-03-2023, 04:47 PM   #511
Doh!
will you find out where it hung?
Old 09-03-2023, 05:57 PM   #512
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Doh!
Yeah we got it. Coupler came apart he thinks when he used the excavator to pack it. Luckily the mini was next door since my buddy is building his neighbors house. The water and communication was over 2ft down with main power conduit 12”-18” deeper.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Spuds (09-03-2023), Ultramaroon (09-03-2023)
Old 09-03-2023, 06:18 PM   #513
soundman98
soundman98's Avatar
do you need some of this?
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
i've got about 2500ft yet...
NoHaveMSG (09-04-2023), Ultramaroon (09-03-2023)
Old 09-04-2023, 01:08 PM   #514
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The pull wasn’t too bad. Lots of lube and grunting but we got it. The run was a little over 120ft.
soundman98 (09-04-2023), Ultramaroon (09-04-2023)
Old 09-04-2023, 02:05 PM   #515
Spuds
The Dictater
Spuds's Avatar
We're still talking about wiring right?
The Following 4 Users Say Thank You to Spuds For This Useful Post:
NoHaveMSG (09-04-2023), pope (09-09-2023), soundman98 (09-04-2023), Ultramaroon (09-04-2023)
Old 09-04-2023, 03:08 PM   #516
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Skeet! Skeet! 120 Feet!
The Following 2 Users Say Thank You to bcj For This Useful Post:
NoHaveMSG (09-04-2023), Spuds (09-04-2023)
Old 09-04-2023, 05:14 PM   #517
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That's one hell of an incline.
Old 09-04-2023, 07:38 PM   #518
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, living on the edge of the earth creates some building issues.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Sapphireho (09-05-2023), Spuds (09-04-2023), Ultramaroon (09-05-2023)
diy, home, living
Brought my BRZ home today Smokinbuffalo Northwest 8 05-31-2012 11:49 PM
WRB-Got it home!!! jaytaurus BRZ First-Gen (2012+) — General Topics 28 05-29-2012 11:33 AM
#64 brought home today. FujiwaraTofuShop Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 09:04 AM
