Old 08-15-2023, 05:22 PM   #29
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
5k launches are one thing, but I've seen people just simply not care.
People roll into grid with cold engines and head out there romping on it at barely 100F oil temps. I always take mine for a short drive around to get the gear oil up to temp and coolant/oil up to where it should be. Minimum you should do.
I've also seen cars idling in paddock nearly all day too. That can't be good to be doing that for ~8 hours.
I think if you do a lot of these things over and over, adding in romping on it on the street when it's not fully warm too as an example, it can cause issues down the line.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Ultramaroon (08-15-2023)
Old 08-15-2023, 09:11 PM   #30
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by ZDan View Post
No reason not to ask.
Except being an adult that knows the rules, and a jackass that doesn't.
I prefer to not be an idiot.
Old 08-15-2023, 09:16 PM   #31
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If done properly, yes. I do them and I know what to expect.
edit: I can't say that I've seen "all" of his vids, and by no means do I worship at the altar of CSG.
Oh that was a comment about my driving, not csg.
I drop it to 4500 on asphalt though…
ineedyourdiddly
Old 08-15-2023, 09:44 PM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
Lemme guess, first-born. In LOVE with *rules*!
In the real world, rules are *often* bent. There is *no reason* not to ask a manufacturer if they might take care of an issue even if outside of warranty based on goodwill. And sometimes it happens. Buddy of mine got his Honda Civic's bottom end replaced after the block cracked way way WAY outside of warranty for next to nothing, as Honda recognized it is a "design defect".
Doesn't hurt to ask, even if likelihood is low. Mighty uptight of you to consider someone a jackass just for asking. IMO!
The Following 2 Users Say Thank You to ZDan For This Useful Post:
22R (09-02-2023), RT-BRZ (08-16-2023)
Old 08-15-2023, 10:06 PM   #33
Ah, well.... actually, I don't pay much attention to the tach. I also don't have much of a competitive urge. I just enjoy mastering the machine. FRS is fun to toss around. If I was more serious, I'd probably get a shifter kart.
soundman98 (08-15-2023)
Old 08-15-2023, 10:54 PM   #34
Oh, come on. The OP reeks of not-my-fault-so-disappoint bullshit. That is the spirit in which the reply was made.
Sapphireho (08-16-2023), villainous_frx (08-22-2023)
Old 08-16-2023, 12:37 AM   #35
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Nope. Second born that takes responsibility for his actions.
Old 08-16-2023, 07:19 AM   #36
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
There's no shame in asking, so long as you don't act like you're owed a positive answer
As for OP, that's a weird failure mode. But these engines don't like heat, and autox is not great for allowing heat to dissipate. Based on what I read, looks like a "no luck that day" situation.
I'm awaiting a quote for a rebuilt M96, so I can empathize !
alex87f is offline   Reply With Quote
Old 08-16-2023, 07:28 AM   #37
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Personally I think I would have searched for a racer mod friendly dealer local to me. Gave them a ring knowing they would say get lost just so I know at least I tried.
I see zero reason wrong with trying your luck but yeah Subaru has no reason to cover your car outside of warranty raced or not. You could try fighting with SOA if you have some free time but even if you got some sort of discount it will still be the most expensive option and probably net you the worst results.
Those techs are not really used to swapping motors or rebuilding them. Look at all the valve spring recall issues from motors rebuilt by dealers.
I hope you can get back auto xing soon and sorry you lost the motor.
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
Ultramaroon (08-16-2023)
Old 08-16-2023, 10:05 AM   #38
ZDan
ZDan's Avatar
Drives: '23 BRZ
This x1000. No reason whatsoever not to *ask*. Also no reason to expect coverage outside of warranty, but IMO give them an opportunity to give you some "goodwill" coverage even if it's unlikely.
I don't know if these engines so have so much a problem with heat. IMO they are marginal for oil delivery to bearings in the first place, combine that with effects of machining tolerances, random boogers and worms of RTV, plus some loss of oil-pressure under high lateral loads, and failures do happen...
Gotsta ask, IMS bearing?
alex87f (08-16-2023)
Old 08-16-2023, 11:31 AM   #39
alex87f
Meow
alex87f's Avatar
Swapped 150 miles before failure for a reinforced unit. It looks like a possible culprit, but not in the conventional way.
Will know more next week ..
Old 08-16-2023, 03:31 PM   #40
CSG Mike
CSG Mike's Avatar
Pro racing no, they don’t put that many miles on a car.
Grassroots racing off a production engine, sure, which I think is what many people wanted when Toyota came out with an affordable 2750# rwd coupe.
https://mazdaracers.com/topic/5099-engine-reliability/
And then you have csg putting tens of thousands of track miles on their car, far more abusive than the average autoxer. Which many cars can’t even make it through a 20 minute session without heavy modification. You’re right, Motorsports is a risk and ten years on we’re learning how FA20’s hold up after 100k+ miles of use.
I’m not shocked or angry, it’s just what the reality is, no point in trying to hide it.
With a healthy heaping of supporting mods, tons of preventative maintenance, and non-abusive driving habits. Lets not ignore how many engines were lost on the very first 2013 BRZ. Yes, plural.
I can all but guarantee you that even intermediate level autoxers are more abusive to an engine than I am.
The car is 100% not track ready in stock form; this goes for virtually all production street cars.
For the guys who think FA20 failure rates are high, you guys should check out the failure rates of Corvettes, Lotuses, Porsches, etc., on track.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
bcj (08-17-2023), EAGLE5 (08-16-2023), G_Ride (08-18-2023), soundman98 (08-16-2023), Ultramaroon (08-16-2023)
Old 08-16-2023, 03:40 PM   #41
WildCard600
WildCard600's Avatar
Drives: 2020 86
WildCard600 is offline   Reply With Quote
The Following 3 Users Say Thank You to WildCard600 For This Useful Post:
EAGLE5 (08-16-2023), NoHaveMSG (08-16-2023), Ultramaroon (08-16-2023)
Old 08-16-2023, 04:14 PM   #42
Right? Doesn't matter how prepped it is. Abuse is abuse. I know you know because your vids speak for themselves.
I'm trying to walk that line between game recognizing game, and sounding like a fanboi.
Autocrossing in Frederick (Md) White64Goat Tracking / Autocross / HPDE / Drifting 0 10-06-2016 10:04 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
Autocrossing a BRZ rusty959 Tracking / Autocross / HPDE / Drifting 10 10-07-2012 01:34 AM
Anyone autocrossing next weekend? theredtape New England 11 10-02-2012 10:42 PM
Autocrossing in my FR-S (bneale) bneale Tracking / Autocross / HPDE / Drifting 10 09-14-2012 02:13 PM
