Old 08-15-2023, 08:58 PM   #2143
tomm.brz
Drives: brz 2017 hksv2
it s not the end of the world if you have -10% ltft, open loop pull seems good anyway
tomm.brz is online now   Reply With Quote
Sideways (08-16-2023)
Old 08-17-2023, 07:20 PM   #2144
73TORANA!
Drives: Orange GTS
Originally Posted by Sideways View Post
Hello all,
Can someone please have a look at my logs? Car feels good, but I am getting negative LTFT. Checked for leaks and can't find anything. Thinking of playing with MAF scaling.
2nd gear WOT log:
https://datazap.me/u/sideways/log-16...1&data=1-7-8-9
Perrin intake, OFH, Perrin OP, Invida Q300 CB
Thank you.
If I could get an AFR log like that with ZERO knock and only -2.34 LTFT constantly across the RPM range I would be rapt. Not sure about the -10 LTFT on over run, do you have a pop tune or similar? Trouble with changing the MAF scale is its gunna effect WOT AFR due to a change in LTFT.
73TORANA! is offline   Reply With Quote
Old 08-19-2023, 05:19 AM   #2145
boundaras
Drives: BRZ Blue MY17
Hello everyone
can anyone give me some suggestions for improvement?please
3rd gear WOT log:
recorded using Tactrix(tuned using RR)
HKS highflow filter;72mm TB;red intake manifold;tomei UEL header withnot cat;FP with 2res and highflow cat
curious about tip-in-enrich i got all the time,even idle……
https://datazap.me/u/boundaras/log-1...&data=11-12-21
thanks~
boundaras is offline   Reply With Quote
Old 09-14-2023, 03:09 AM   #2146
freerunner
freerunner's Avatar
Drives: GT86
Adjust your logcfg.txt to grab data for tip-in instead of tip-in-enrich. T-I-E is a constant IIRC.
The correct tip-in is zero almost all the time and only spikes down occassionally on accelerator movement.
freerunner is offline   Reply With Quote
Old 09-14-2023, 09:36 PM   #2147
boundaras
thanks!
Old 10-21-2023, 09:03 AM   #2148
softail
Drives: GT86 2013 E85
Hi,
It's an 86 from 2013, stock air filter and stock header.
I'm on Wayne's rom E85, lean -2.
I don't understand my IAM remains at 0.98 while my ethanol is around 80%. This is the first time that my IAM has fallen. It has always remained at 1 even with Ethanol at 65%.
Does anyone have an idea?
Here are two logs, one a wot and one normal.
https://datazap.me/u/visclo/log-1695232857?log=0&data=1
https://datazap.me/u/visclo/log-1697888228?log=0&data=1
Thanks.
softail is offline   Reply With Quote
Old 10-21-2023, 11:47 AM   #2149
tomm.brz
Originally Posted by softail View Post
Hi,
Thanks.
remove some ignition timing from table Base timing B
under 2000rpm and over 7200rpm and sjould be good
tune looks good on your car i wouldn t touch anythjng else
anyway it s not a big deal 0.98 you still get basically full timing everywhere you could easily ignore specially if you are running e85 could not even be a real knock
Old 10-23-2023, 01:57 PM   #2150
softail
Thanks, ok I will do that.
Old 07-26-2024, 10:47 AM   #2151
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
No physical log at the moment but is it normal common for LTFT to change quite a bit in heavy traffic?
Warmed up LTFT sits around +3 to +5 but jumped to +12 in traffic then ended up back down to +5 range once I was able to get moving again.
Old 05-26-2025, 03:20 PM   #2152
mkodama
86 Challenge
Drives: 2017 BRZ
Anyone have any ideas why I'm a bit down on power?
Rebulit my 2017 FA20 in April 2025 with higher compression ratio, had 3 track days already without issue, but did a dyno yesterday and I'm down double digit power compared to before the rebuild(stock compression ratio). E85 freeway mileage is as good as 91AKI mileage, and cold starts happen first try now, so that's good. I'm trying to learn the software/tuning part of things now, so any good links for reading appreciated.
13.5:1 CP Carrillo pistons
Open Flash Tablet E85 tune
JDL headers, over pipe, front pipe, no cats
https://datazap.me/u/mkodama/log-174...4?log=0&data=1
mkodama is offline   Reply With Quote
Old 06-19-2025, 05:16 AM   #2153
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Hello, I am learning to read the data of the logs to be sure that everything works correctly, the only "problem" I see is a LT fuel trim of -10 for a long time.
Anyone who knows more than me can tell me if it's normal?
-Oft stage 2+
-tomei EL headers
-fp hks
-catback miltek
-k&n filter in oem box
-custom carbon intake tube
-new oem spark plugs
https://datazap.me/u/ruben-saiz/lanz...=0&data=1-2-10
thanks
Ruben_86_ is offline   Reply With Quote
Old 06-21-2025, 08:26 AM   #2154
tomm.brz
ltft is ok
just take maf scaling from 0v to 3v and reduce it of 5% everywhere
but remove those knocks (flkc) see what rpm and load they are present (negative flkc i mean) and remove timings from Base timing B table
Ruben_86_ (06-30-2025)
Old 06-21-2025, 08:28 AM   #2155
tomm.brz
make it leaner and raise ignition advance
mkodama (06-21-2025)
Old 06-21-2025, 01:23 PM   #2156
mkodama
86 Challenge
Drives: 2017 BRZ
Sounds scary, but I’ll try. Thanks!
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
