Old 04-21-2017, 09:55 PM   #127
reeves
Just swapped out my cabin filter today and realized I had the previous one oriented the WRONG way for the last 30K miles!
If you're using the FRAM filter, make sure the arrow is pointing DOWN! (Air flow goes downward)
Old 04-23-2017, 10:50 PM   #128
moonsun
Drives: red
Thanks a TON for the heads-up!
moonsun is offline   Reply With Quote
Old 06-20-2017, 06:52 PM   #129
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Just took out my Wix. Had on for 8k miles or so and it looks like it started melting!!! Well not literally. It's worn pretty well like if it had been rubbed on cement. Bought a MicroGard which is $15 cheaper. We shall see how it does in 8k miles. I recommend a carbon one if you live in big city. Otherwise, any cheap one above $10 works well and serves it's purpose!
Old 06-22-2017, 10:30 AM   #130
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
I buy a Mann 3 layer anti pollution filter. Not cheap 45€, but it filter bad smell from smoky cars behind you, great buy !
Envoyé de mon T6pro en utilisant Tapatalk
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 12-26-2018, 10:17 PM   #131
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
Couldn’t you just make your own DIY in-cabin filter with a home HVAC filter like Filtrete and just just it to size especially since they have different levels of filtration?
mikeg7827 is offline   Reply With Quote
Old 12-26-2018, 10:33 PM   #132
FirstWinter
Drives: Car
Yes, you can. Just make sure you have the same amount of area (number of creases/folds). But why bother considering they're cheap. It's still costing you, maybe not in the price but your time.
FirstWinter is offline   Reply With Quote
Old 03-06-2020, 11:53 PM   #133
Halo_2
Drives: 2014 MY15 86 GTS
My spring/gas hook on the side of glovebox fell off its pivot when removing....
Its has two holes I can see one of them clips onto in plain view, where is the other clip onto?
Halo_2 is offline   Reply With Quote
Old 05-08-2020, 07:34 AM   #134
Halo_2
Anyone, also the K&N air filter make sure arrow points down with direction of flow.
Old 08-11-2023, 01:39 PM   #135
Mr_Brian
Where is the actual intake for the fresh air to enter before the filter? I changed my filter but it still smells musty like there is some debris in the actual fresh air intake.
Mr_Brian is offline   Reply With Quote
Old 08-11-2023, 04:02 PM   #136
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Straight up. From the outside through the holes in the windshield cowling
EndlessAzure is offline   Reply With Quote
Old 08-12-2023, 06:32 PM   #137
Kaotic Lazagna
Drives: GR Corolla
That might be from the ducting now.
air filter, cabin air filter, diy
Safety Inspection Sticker Mount Philz0r Hawaii 13 06-12-2015 02:29 PM
brake pad inspection sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-05-2013 09:22 PM
inspection sticker question wallace03 Off-Topic Lounge [WARNING: NO POLITICS] 6 12-02-2012 04:48 PM
PIC 10K TRD Air Filter Inspection Yruyur Scion FR-S / Toyota 86 GT86 General Forum 8 10-07-2012 01:53 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
