Old 08-09-2023, 09:13 AM   #1
sam1
sam1's Avatar
Drives: GT86
Transmission leaking?
Is this leaking from the gasket?
Had this look towards the back of the transmission pan. Was told it was the gasket and had it replaced. About over a year later seeing the leaking again.
It just seems to be around the back of the pan, could it really be the gasket again? As far as I can tell I don't see it coming from anywhere else. Just didn't expect the gasket to go bad again.
sam1 is offline   Reply With Quote
Old 08-09-2023, 11:30 AM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Are you confident the gasket was replaced? Looks like a bead of orange RTV along one edge.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 08-09-2023, 12:17 PM   #3
Is there any fluid above the gasket line? If so, it's not the pan.
Most likely it was shoddy surface prep before applying the RTV.
Old 08-09-2023, 01:18 PM   #4
sam1
sam1's Avatar
Drives: GT86
I don't see any above, and it's only on the back side of the back side where you see it in the pic. Everywhere else is clean. I'm thinking you're right about the bad prep work.
The RTV is connecting the other part, I know it looks like it's on the pan but if you look closely on the pan edge you can see the black gasket.
I had this done at Toyota, was hoping they would have done a better job.
Old 08-09-2023, 02:27 PM   #5
Bummer. Squeezing extra hard is only going to warp the pan or strip the threads. Pan seals are tricky because oil is constantly oozing/wicking down the inside surface of the upper component. It takes a long time for that to slow enough for the sealant to set before more contaminant gets into the joint.
If it was mine, I'd pull the pan, let the transmission drip onto a tray for a couple days, and only then clean really well. I don't know how the job could be done effectively in an hour.
Old 08-09-2023, 04:44 PM   #6
Muskoka800
Why not take it back to Toyota for resolution. They should stand behind their workmanship. There’s no harm in asking.
Old 08-10-2023, 09:59 PM   #7
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
That much in a year, that is not a leak. Clean it up and move on with your life.
Transmission lessons learned: (McLeod & FA24 transmission upgrade) GrandSport Tracking / Autocross / HPDE / Drifting 7 07-15-2023 11:09 PM
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 07:14 PM
Oil leaking oil pan? Astroboy Engine, Exhaust, Transmission 9 01-30-2015 03:32 PM
Car leaking davebrus Issues | Warranty | Recalls / TSB 4 03-21-2014 11:23 AM
AT Transmission rear seal leaking. CircuitJerk Issues | Warranty | Recalls / TSB 6 10-31-2013 03:41 PM
