Old 07-29-2023, 07:17 PM   #4873
Decep
Drives: 2013 FR-S Series 10
Originally Posted by ABQautoxer View Post
Have any of you sold your supercharged twin? I've put mine up for sale but being a niche item I'm not sure I'm advertising it in the right spots.
return it to stock and sell it. i sold my 2013 with 75k for almost 20k on carvana. the used car market is a sick joke and has been for a few years
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 07-30-2023, 08:36 PM   #4874
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
I’ve been getting some hesitation and stumbling only when I tip in the throttle a bit more than normal like trying to take off at a light fast. No other issues. It stumbles and then goes…
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 07-31-2023, 03:06 PM   #4875
I know it must be happening, but I find it astounding that Carvana is selling an 11 year old $25,000 when new car for $20,000 or more.
By the way, the current offer from Carvana on mine (2013, 221,000 miles) is $545. A year ago it was around $5,000 with 205,000 miles on it.
Old 08-01-2023, 11:03 AM   #4876
Hikari1
Hikari1's Avatar
Drives: 2016 BRZ Hikari
So a quick update for anybody running Gates RPM belts. I’ve been searching for one for a while and after speaking with someone directly at Gates, they’ve discontinued that line. The HD line is still being manufactured but is heavily backordered at the moment.
Anybody else have any belt recommendations? I’ve been running the Continental Elite 060995 and am having a rib sheared off about once a track day. I’m going to try an 060990 which is a bit shorter to see, but what I’m seeing happen is under heavy load the tensioner is pushing the stretched belt up into the pulley above…
2016 BRZ Hikari Edition
@BRZHikari1
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=107326
Hikari1 is offline   Reply With Quote
Old 08-01-2023, 11:44 AM   #4877
StraightOuttaCanadaEh
Wes
you should do solid engine mounts and bushings is what you should do
Instagram: @gt86ws
Old 08-01-2023, 01:21 PM   #4878
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Sounds like you may need a new tensioner. I'm still using the 995 with my 2.70 pulley and never sheared off any ribs. I replaced the tensioner at 60k miles when the original engine blew. Tons of track days and no problems to report.
B T is offline   Reply With Quote
Old 08-01-2023, 01:27 PM   #4879
Hikari1
Hikari1's Avatar
Have one on the way already as well, hopefully that helps. Glad to hear you haven’t had any issues
@BRZHikari1
Build Thread:
Old 08-02-2023, 09:11 PM   #4880
Unplugem
Drives: Cayman R 6MT
How old are your spark plugs? If you are running a PD supercharger, you will need to replace spark plugs quite often, as superchargers are known to use up spark plugs much faster than NA cars. Some people I know who own FI cars, replace spark plugs once every year, as faulty spark plugs can really make FI cars lose power and run poorly.
Unplugem is offline   Reply With Quote
Old 08-05-2023, 11:59 AM   #4881
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Reposting for visibility:
I have an Edelbrock E85 BRZ and recently on the highway, the Shaft Select Lever Pin sheared off and misaligned my shifter H pattern. Here are photos:
https://imgur.com/a/aVicQQL
I drove the car again today and at high rpm's and the entire shifter rotated on me. Freaked me out... It feels closer to normal now but still in an odd spot where you can accidently shift into reverse
Did something internal break? I am concerned because I thought the transmission could handle the SC/E85 combo. I wanted to go to an 8/6 meet & drive tomorrow but now I'm feeling sketched out that I broke something major. Please help!!
GPhilly is offline   Reply With Quote
Old 08-06-2023, 06:19 PM   #4882
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Likely only damaged at the shifter base. Only pulling out the console and shifter will tell the story. But if it’s acting as funky as you say I’d not dare drive before resolution.
Good luck! The
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 08-12-2023, 12:53 PM   #4883
xeroshoes
Drives: 2017 BRZ Limited, White
2017 BRZ with idle problems (CEL and Traction)
I've got a 2017 BRZ. Put the Edelbrock supercharger in July 2019. Used their tune with no prob.
Tried the Delicious tune. Also no prob.
UNTIL about 2 years ago.
At some point after I reflash the ECU -- could be 10 minutes, could be 2-3 months -- these happen:
* Car won't hold an idle RPM -- goes between 500-1000
* Throttle response is crazy in 1st -- sometimes it's non-responsive, sometimes RPM drops as I add throttle. I need to rev the car to about 2k RPM to start moving
* At some point after that, the CEL and Traction lights come on
Reflashing temporarily solves the problem (with either tune). As does pulling the battery for 10 minutes.
And, the problem will be intermittent... some drives are fine, then 5 minutes later the throttle response is totally out of whack.
My usual mechanic spent a month with the car as was stumped.
ANY suggestions? Thanks.
xeroshoes is offline   Reply With Quote
Old 08-12-2023, 02:21 PM   #4884
JoeS
Drives: 2016 BRZ Hyper.Blue
Throttle position sensor?? What code are you getting?
Sent from my Pixel 7 Pro using Tapatalk
JoeS is offline   Reply With Quote
Old 08-14-2023, 12:16 PM   #4885
Hikari1
Hikari1's Avatar
You were right, new tensioner put on and over the long weekend did 2 days at the track, about 57laps total. No issues with the belt.
I noticed even putting the belt back on, the spring on the new tensioner was much much stronger.
@BRZHikari1
Build Thread:
Old 08-14-2023, 12:17 PM   #4886
xeroshoes
ENGINE:
P0172 - System Too Rich Bank 1
P050A - Cold Start Idle Air Control System Performance
P117B - Direct Injector Fuel Performance Does Not Come On DTC
ANTILOCK BRAKING SYSTEM:
C1201
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
