Old 06-01-2023, 03:47 PM   #85
StraightOuttaCanadaEh
Wes
Originally Posted by Koba View Post
Who's your tuner? Looking for someone local. Thanks.
Definitive Tuning
Instagram: @gt86ws
Old 06-13-2023, 11:13 AM   #86
magbrz
Drives: 2020 BRZ w/ PP
It looks like CAN bus is the answer. Delicious Tuning and Geralds Projects both have CAN bus flex fuel kits for the 22+ models.
Delicious Tuning pre-order page:
https://www.delicioustuning.com/canflexfuel
Gerald:
https://www.geraldjustprojects.com/p...flex-fuel-kit/
Gerald says the CAN bus kits for 13-20 will be available soon:
We will be soon discontinuing this kit for the 13 to 20 cars. This issue is because ecutek has dropped support for the O2 sensor/evap inputs. We will have a updated kit that is CANBUS based that will work with the new upcoming changes in ecutek like how our GEN2 kits are. But with the appropriate connectors for GEN1. Once these go out of stock they will not go back into stock.
Hopefully DT can get one out for 13-20 as well.
Hope springs eternal!
~Mark
magbrz is offline   Reply With Quote
The Following User Says Thank You to magbrz For This Useful Post:
DocWalt (06-13-2023)
Old 06-13-2023, 03:48 PM   #87
geraldjust
Drives: MR2, Sliver BRZ
Gerald:
~Mark
Technically already have it ready. We are just waiting for ecutek to support it. Just yesterday ecutek also released canbus support for all sti and wrx 07+ cars. So im very sure that the 13-20 will be coming up soon. We also added a new box that will support added sensors like oil pressure, PI pressure.. etc.. so will be useful!
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 06-19-2023, 09:58 AM   #88
alphasaur
friendly
Drives: 17' 86
Has this been fully implemented?
Just finished up installing my turbo kit and was hoping to keep my flexfuel kit
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-19-2023, 01:30 PM   #89
tomm.brz
Drives: brz 2017 hksv2
well yes you can t change region if you updated it and cpc seems blocked, together with other tables
Old 06-19-2023, 10:27 PM   #90
geraldjust
not yet but its coming from what i know. they recently added the canbus support for their entire WRX/sti from 07+. So now the twins are the last subis that are needed i think...
Old 07-13-2023, 11:44 AM   #91
magbrz
Any update from EcuTek on the twins?
Old 07-31-2023, 03:09 PM   #92
Pro60modman
Drives: Too many
Can I flash my 2015 FRS with an EU tune from my Tactrix then relicense the car as an EU and pick the flex fuel and cel disabling features back up?
Pro60modman is offline   Reply With Quote
Old 07-31-2023, 05:58 PM   #93
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Yes that would be possible but if car already has ecutek licience you will loose licience and need new one doing rom change.
Can help you retain licience or get those ecutek features send me a message
AussieBRZ is offline   Reply With Quote
Old 08-03-2023, 10:01 PM   #94
Pro60modman
Drives: Too many
I PM'd you back
Old 08-20-2023, 02:04 AM   #95
kev0
Drives: '14
Can someone PM me with a download link to an older Ecutek version? A version before the upgrade. Thank you.
kev0 is offline   Reply With Quote
Old 08-20-2023, 03:58 AM   #96
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Won't work unfortunatly even if you find it.
The install version info is stirred on the deskey and won't let you go backwards or reinstall old versions
Old 10-19-2023, 11:29 PM   #97
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Originally Posted by tomm.brz View Post
For untuned people who wants to tune, buy also a tactrix and convert to euro before using ecutek so you can have non limited tunes
I have a 2020 USDM BRZ, currently stock, planning to do a catless UEL and an Ecutek tune on pump gas. Not planning to go E85 or FI. Should I also switch to a EU map with a tactrix prior to having the car tuned with Ecutek?
Could you please elaborate more on issues with the US maps?
Arthur-A is offline   Reply With Quote
Old 10-20-2023, 02:21 AM   #98
tomm.brz
you can t delete some dtc and change some tables, ifnyou have the chance convert it...
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Arthur-A (10-21-2023), DocWalt (10-20-2023)
Open Flash Tablet Manager Software (problem after internet update) SloS14 Software Tuning 6 10-31-2013 03:33 PM
86 Software Update v3rgil AFRICA 121 10-04-2013 01:45 AM
Gopro 3 Software Update Released Yruyur Electronics | Audio | NAV | Infotainment 1 05-13-2013 06:17 PM
So what ECUtek software do you need to make changes to the ECU yourself? seven Engine, Exhaust, Transmission 30 01-04-2013 11:58 AM
EcuTek preparing to release PRO ECU software for BRZ Visconti Engine, Exhaust, Transmission 335 08-13-2012 11:34 PM
