Old 08-07-2022, 11:49 PM   #15
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by blsfrs View Post
Just thinking out loud: I wonder if removing the cabin filter for track days would significantly help the air flow through the vents?
I don't think so. The HVAC system is aided by the high pressure zone behind the windshield. Like @Ultramaroon , you'll just get gunk in your HVAC system. If you have the blower motor going, it's going to have pretty good flow already at max setting.
One thing that I didn't think about but did notice at a recent track day was that if you have hood vents, you car is likely going to suck in the hot engine exhaust air. The HVAC intake is the grating on the windshield cowl on the driver side. I was wondering why it seemed hotter than ambient during some points of my drive
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
blsfrs (08-08-2022)
Old 08-09-2022, 02:11 PM   #16
Sgt.Gator
Drives: 2005 STI Race Car- 08 Spec B DD
New driver cooling ducts to be tested this weekend at Portland on my STI.
$7 each side in downspout parts at Lowes.
Sgt.Gator is offline   Reply With Quote
The Following 3 Users Say Thank You to Sgt.Gator For This Useful Post:
blsfrs (08-09-2022), NoHaveMSG (08-09-2022), RedReplicant (08-09-2022)
Old 08-09-2022, 04:14 PM   #17
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
lol, was looking for something a bit more integrated but beggars can't be choosers I suppose!
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 08-09-2022, 04:26 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
At this point I am thinking naca duct in the roof. Track car anyway so eff it
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (08-09-2022), soundman98 (08-09-2022)
Old 08-10-2022, 11:36 AM   #19
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I think our corner windows are a little too small to get airflow in compared to what can be replaced in a Spec Miata, buttt I'm thinking with some ingenuity and customization + 3D printing something could be made at a smaller scale, but I guess at what cost for looks? The drain spout is pure function and cheap, but probably not my favorite choice either
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 08-10-2022, 12:34 PM   #20
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I think you are right about the air flow over the 1/4 window. My first attempt at a duct was a failure as it did not direct any air into the car. I realized that the A pillar and mirror interfered with the flow of air across the 1/4 window. A NACA duct needs unobstructed air flow to work.
Old 08-17-2022, 10:06 AM   #21
GrandSport
GrandSport's Avatar
Hey Kelse! Funny running into you on the forums (we met at ECR). You're now officially not allowed to laugh if I zip tie a gutter drain to my car
The Following 2 Users Say Thank You to GrandSport For This Useful Post:
bcj (08-17-2022), soundman98 (08-17-2022)
Old 08-21-2022, 04:58 PM   #22
Sgt.Gator
My gutter downspouts worked pretty well. There was flow into the car, but not a hurricane. I think an extension on the front would probably improve the flow even more.
The Following 2 Users Say Thank You to Sgt.Gator For This Useful Post:
bcj (08-22-2022), blsfrs (08-22-2022)
Old 07-19-2023, 03:09 PM   #23
GrandSport
GrandSport's Avatar
So as an update, BSP made this as a solution for the DS and I just had them make one for the passenger side it worked so well. Lots of airflow.
Only thing I'm pondering is removing the rear "sail" glass. I'm thinking it would help air flow more. If not, I'm going to remove the factory vents/bleeder flap things in the rear to help get negative pressure behind the seats.
The Following 4 Users Say Thank You to GrandSport For This Useful Post:
bcj (07-19-2023), CSG Mike (07-19-2023), NoHaveMSG (07-19-2023), Ultramaroon (07-19-2023)
Old 07-19-2023, 07:35 PM   #24
soundman98
ProCrastinationConsultant
soundman98's Avatar
this gives me some pretty terrible idea's about making an old-style window that can flip around in that area...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
blsfrs (07-20-2023), GrandSport (07-20-2023)
Old 07-20-2023, 12:15 PM   #25
GrandSport
GrandSport's Avatar
It flows a lot of air. It made a big difference. There's just NO AIRFLOW in that car.
The more I think about it, the more I think it's because of a lack of an exit for the air rather than needing ducting.
The Following User Says Thank You to GrandSport For This Useful Post:
soundman98 (07-20-2023)
Old 07-20-2023, 01:15 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, you need a spot at a low pressure area of the body to evacuate the air from the cabin. Vent at license plate position on trunk?
Old 07-20-2023, 01:49 PM   #27
Careful! Vent location at the base of the rear hatch was a major fail for the first year 240Z. I spent years sucking exhaust gasses whenever I didn't force fresh air into the cabin.
GrandSport (07-20-2023), NoHaveMSG (07-20-2023)
Old 07-20-2023, 01:56 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Didn't even think of that. Good point.
Ultramaroon (07-20-2023)
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Water in AC/Circulation Fan yeah2311 BRZ First-Gen (2012+) — General Topics 14 07-09-2016 09:08 AM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
Canadian penny goes out of circulation today, but... chenshuo CANADA 16 02-12-2013 10:41 PM
