Old 07-09-2023, 08:20 AM   #99
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We are finally looking into a bolt-on solution for both 1st and 2nd gens. I have no idea if it will come to fruition yet or not, but we are finally looking into it!
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
callisto (09-08-2023)
Old 07-09-2023, 01:52 PM   #100
churchx
churchx's Avatar
Drives: 2014 GT86
@VerusEric If you are redesigning your brake cooling kit .. please as alternative make one with inlets behind radgrill, for those that don't want to loose foglights.
Also due wide boxer engine width already limited max wheel steering angle, would prefer something thought out to not have to limit steering angle even further. Wonder if hose connector plastic body can be relocated somewhere else for that purpose.
Jdmjunkie (07-09-2023)
Old 07-15-2023, 10:18 PM   #101
VerusEric
VerusEric's Avatar
Some have used our inlets in the grill opening. It has worked well. As for the pancake duct, only people with wide tires need to run the steering rack limiters.
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 07:43 AM
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 07:40 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
