Old 07-11-2023, 09:34 PM   #5979
johnnyeisu
After consulting with a highly reputable mechanic, I've decided to get my C38 warrantied and hopefully replaced with a less noisy unit.
Do you guys think I should ask for a C32 unit as they are known to make no noise? If so, would my current flex fuel tune work on a C32 or would I have to get that done again?
johnnyeisu is offline   Reply With Quote
Old 07-12-2023, 08:02 AM   #5980
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Do you mean c30? I say if you aren't running a smaller pulley go for it.
Old 07-12-2023, 08:09 PM   #5981
Cstond151
Drives: 2020 Toyota 86 Hakone Edition
Originally Posted by wheelhaus View Post
I made a bracket to relocate the reservoir to the center between the strut braces at roughly the same height as its original location on the driver's side. Getting some extra 15-20' of Gates hoses in whatever IDs you need, 3/8, 5/16, and 1/2," is really handy to cut whatever lengths you need to get the CCs and reservoir placed and routed happily.
I also had an issue with the CCV side fouling my MAF sensor and installed a CCV CC at Zach's recommendation. With an OEM intake tract, the CCV is after the MAF, with the JRSC it's ahead of it so it can develop a faint film from oil vapor. I have the Radium CCV oil can on the driver's side, PCV can on the passenger's side. Routing the PCV and CCV pickups to a single collector can turn into a whole bag of fuckery with check valves and tricky routings to ensure the airflow is going in the right direction and flowing properly when all the various hoses are in vacuum or are pressurized. Two separate cans is the way to go because it keeps things functionally simple; each can does one job.
Thanks for the info. Do you have a picture of your bracket/mounting point for the CCV catch can?
Cstond151 is offline   Reply With Quote
Old 07-13-2023, 08:43 PM   #5982
johnnyeisu
Bingo.
Had my mechanic take off the Rotrex to return for warranty and he's found the problem.
The impeller had been scratching the housing every rotation. Now multiply that by however many RPM and you have the crickets in my video.
Hopefully this guarantees my warranty and helps some other people with the cricket noises.
https://www.youtube.com/shorts/qlHTXcmw0m8
The Following User Says Thank You to johnnyeisu For This Useful Post:
Ignore Your Doctor (07-17-2023)
Old 07-28-2023, 03:03 PM   #5983
Cstond151
First start on my C38. I don’t think this sound is normal from everything I have read…supposedly the Rotrex is really quiet. I installed everything by the book and primed the Rotrex as instructed. Any ideas/advice?
https://youtube.com/shorts/SJeC07PL9p8?feature=share
Old 07-28-2023, 05:30 PM   #5984
Teseo
Drives: frs
Tried loose up the belt? If not give it a try
Old 07-28-2023, 07:24 PM   #5985
Cstond151
How do I loosen up the belt? To get the belt on I just rotated down the belt tensioner and then it popped back up into position
Old 08-02-2023, 05:31 PM   #5986
wheelhaus
wheelhaus's Avatar
Yes I do, sorry I've been out of town, I'll take a photo. It was just some 2024-T3 aluminum that i sprayed with black primer. The only quirky thing was getting the angles right so it rested flat, but in hindsight, bending a couple steel L-brackets could do the job just as well.
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
CSG Mike (08-07-2023), Teseo (08-02-2023)
Old 08-06-2023, 10:55 AM   #5987
Cstond151
Thanks, nice set up. I ended up keeping the oil reservoir in the recommended place but moving the CCV catch can by attaching it to the intake manifold
The Following 3 Users Say Thank You to Cstond151 For This Useful Post:
CSG Mike (08-07-2023), tomm.brz (09-02-2023), wheelhaus (08-15-2023)
Old 09-01-2023, 10:15 AM   #5988
AndreC
Drives: Fast track beast
How many of you have belt slippage with the smaller pulley on the C30? The smaller pulley has less contact area.
AndreC is offline   Reply With Quote
Old 09-16-2023, 04:05 PM   #5989
Breadman
Breadman's Avatar
What is the consensus on belts? I just ate one today in autocross and wondering if there are better brands to replace it with.
Old 09-25-2023, 01:35 PM   #5990
CSG Mike
CSG Mike's Avatar
The provided Gates belt should be enough.
Check your pulleys for play and/or wear if you're losing belts.
Old 09-26-2023, 09:29 AM   #5991
Breadman
Breadman's Avatar
I just got a gates belt, I wasn't sure if there were better belts than ones designed for 25 year old vans. I think my issue was just hitting limiter and shocking the belt. I have video of it and i hit limiter and then pieces of the belt exit my hood vents. I'm guessing it skipped and chewed the outter rib off from the shock.
Old 09-26-2023, 09:20 PM   #5992
CSG Mike
CSG Mike's Avatar
The shock of slamming into your limiter can definitely caused the belt to skip, as the tensioner won't be able to keep up with that.
It's also really, really unhealthy for the supercharger's main shaft, so do try to avoid hitting the limiter!
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
