Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-05-2023, 11:16 AM   #1
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
How to Unlock Steering Wheel w/o Electricity?
In a normal car you'd stick the key in and turn it to "on" to unlock the wheel so while pushing the car you can turn the wheel to maneuver it. With this push button system is there any way to turn the wheel with a completely flat battery?
Lelandjt is offline   Reply With Quote
Old 07-05-2023, 04:03 PM   #2
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
No. Kinda niche scenario. Any reason you can’t just give it some juice?
removedonut is offline   Reply With Quote
Old 07-05-2023, 04:40 PM   #3
Lelandjt
Battery is flat and won't take a jump. I was able to push it straight out of the garage and the tow truck was able to maneuver into a good enough positon, but in a normal car I would have turned the car on the way out of the garage to get it in a better position for the tow truck.
Old 07-05-2023, 05:48 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Buy a jump pack, one with a real battery (not one of the little thing with 16ga cables) and keep it around for situations like this
soundman98 (07-05-2023)
Old 07-05-2023, 08:03 PM   #5
Lelandjt
My running T150 with dual batteries was connected with thick jumper cables to the BRZ's terminals and the dash wouldn't even come on. I don't think a little battery jumper would have done anything. The dealer replaced the battery so when I pick it up I'll get whatever info I can on why it died and why the car had no power when connected to 14.2v.
The Following User Says Thank You to Lelandjt For This Useful Post:
DarkPira7e (07-05-2023)
Old 07-05-2023, 08:13 PM   #6
DarkPira7e
DarkPira7e's Avatar
I have jump started dual battery diesel trucks at -20f with one of these- https://www.jbtools.com/booster-pac-...-cranking-amps . Jumper cables can only charge progressively, they don't carry a charge as soon as you connect them. With that said, you should get at least something after a minute or two, there's definitely more wrong than just the battery if it wouldn't receive some sort of power
Old 07-06-2023, 03:37 AM   #7
OldBiker
Drives: 2023 Gray BRZ
The battery has/had a short. Disconnect the red lead from the battery... attach to jumpers from running truck, essentially feeding your BRZ and bypassing the dead/short battery... car should get good voltage.
OldBiker is offline   Reply With Quote
The Following 2 Users Say Thank You to OldBiker For This Useful Post:
pope (07-06-2023), soundman98 (07-06-2023)
Old 07-06-2023, 01:04 PM   #8
Lelandjt
Dealer said the battery had a bad cell, they've been seeing this some on recent new Subarus. Also, he agreed that if I'd disconnected the battery, then attached the jumper cables only to the BRZ's battery cables I would have had power and been able to jump it and drive it to the dealer. If you have a newish Twin remember this.
Old 07-06-2023, 09:10 PM   #9
pope
has a funny hat
Drives: 2014 BRZ Limited
This is a bad idea. Without the battery in the loop, the voltage regulator is unlikely to function correctly and you’ll get spikes that fry electronics.
Using the trick to power the car and unlock steering, okay; starting it without the battery in the loop, not advisable.
pope is offline   Reply With Quote
The Following 2 Users Say Thank You to pope For This Useful Post:
OldBiker (07-06-2023), soundman98 (07-06-2023)
Retaining steering wheel controls w/ aftermarket steering wheel on +17 BRZ/86 DDavid Electronics | Audio | NAV | Infotainment 8 04-22-2021 05:37 AM
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 06:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Static Electricity Lunatic Scion FR-S / Toyota 86 GT86 General Forum 33 02-06-2015 01:06 PM
