Old 08-03-2012, 11:34 PM   #57
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
Yah I'm sure it will work on a manual. I won't say it was easy it still takes a lot of force but it gives you great holding power on the pulley.
Sorry but I'm hanging on to the tool for now in case I ever want to switch back, or if any of my fellow local owners need to borrow it.
so with this tool your stock pulley did not rotate?
Sall is offline   Reply With Quote
Old 08-03-2012, 11:41 PM   #58
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
The tool is a special plate that attaches to a breaker bar and has different bolt patterns that you can use to fit the holes on the pully. It isn't an exact fit for this stock pully but it works. It fits perfectly on the Perrin pulley.
http://www.grimmspeed.com/catalog/pr...roducts_id=231
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
BabaYaga (03-05-2015), Sall (08-04-2012)
Old 08-04-2012, 11:22 AM   #59
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
so this bolt pattern wont let my stock pulley rotate?im guessing yes it wont rotate thanks
Old 08-08-2012, 10:57 PM   #60
Benzy
Drives: 2001 Camaro
Can somebody post a video of the car's tachometer while driving, showing an example of what it drives like with the pulley on?
I've searched around but I cant seem to find a video anywhere for this vehicle.
Benzy is offline   Reply With Quote
Old 08-09-2012, 06:37 PM   #61
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Since I have an automatic I had to get the Grimmspeed crank pulley tool. Worked like a charm.
Did you leave it on park and pull the hand break only to release it?
Old 08-09-2012, 07:06 PM   #62
neutron256
neutron256's Avatar
Well setting the parking break is always a good idea when work on any car, but that's not important when changing the pulley on an automatic.
When in "Park" on an automatic transmission the parking pawl is engaged locking the shaft. The engine itself is basically disengaged from the transmission, and has nothing to prevent the crankshaft from turning when you apply force to the pulley.
(Or at least that's what I remember about automatic transmissions in park)
You either need a tool that will allow you to hold the pulley still while you turn the nut, or an impact wrench that is bother powerful enough, and will fit in the limited space in front of the pulley.
Old 08-09-2012, 07:24 PM   #63
dem00n
dem00n's Avatar
Drives: Scion FRS
Thanks for the lesson, i'll be buying a crank pulley tool now! Thanks again.
Old 08-10-2012, 12:14 PM   #64
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
having the same problem. i cant get the crank bolt to loosen. and I tried over 175 ft lb.... wtf?
EDIT: got it!
Kuzuri is offline   Reply With Quote
Old 08-10-2012, 03:34 PM   #65
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
EDIT: got it!
What did you do differently? Breaker bar or impact wrench?
Old 08-10-2012, 04:11 PM   #66
Kuzuri
__(X)__
Kuzuri's Avatar
well i was using the breaker bar at first, but then switched to the torque wrench so i could see just how much force i was using. (how i knew i was over 175 ft lbs) i thought that was just nuts...
so my buddy came over and we were just talking about it for a little while and hes like "just let me try it, watch ill get it on the first try" and sure enough he did...
it was turned up to 200 ft lbs, and he kept going after it clicked... finally that sucker just broke loose. i guess i was just being to gentle on it... lol
Old 08-19-2012, 10:31 AM   #67
Foobar
SLO NO MO
Foobar's Avatar
Well add me to the list of folks who couldn't get the damned bolt off with a 24" breaker bar (gear in 6th, parking brake pulled so hard it snapped the boot assembly off).
with the 24" breaker, I had about half a foot of "sponginess" play, and it just wouldn't go further. I was afraid of snapping something (the bar was starting to bend pretty good) and causing some serious damage to the vehicle or myself.
Would the pulley removal tool help in this situation?
Old 08-19-2012, 10:51 AM   #68
neutron256
neutron256's Avatar
Most likely, zero sponginess when using the pulley tool. It still takes a lot of force but you have much better control.
Old 08-19-2012, 11:18 AM   #69
Calum
That Guy
Drives: 2013 asphalt FRS MT
unless you're talking about something else, the pulley removal tool is for removing pulleys that are press fit, and our pulleys aren't pressed on. The sponginess is most likely the sprung hub on the clutch, I ran into the same thing. Just keep hauling on the power bar, it'll come off.
Old 08-19-2012, 11:44 AM   #70
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
The pulley removal tool (from Company 23 or Subaru) will allow the pulley to stay put while you loosen the pulley's bolt. For a MT you can try putting the car into 6th gear. You can't do this with an AT and will need to somehow lock the pulley in place, therefore the pulley tool.
kwood9000 is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
