Old 06-22-2023, 08:19 AM   #1
LS1M
Drives: 2015 BRZ
Bypassing the Rotrex
My JRSC is sick, but I still need to get to work. Is there a way I can bypass it so it won't spin? I don't want to cause even more damage.
Thanks
-Mark
LS1M is offline   Reply With Quote
Old 06-22-2023, 11:39 PM   #2
Grady
Grady's Avatar
Put stock belt on and not go around the SC?
Old 06-23-2023, 11:38 AM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Surely you’ll need to go back to the NA tune as well.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 06-23-2023, 01:28 PM   #4
LS1M
Drives: 2015 BRZ
I looked it over & I think I can just remove the s/c, put the idler pulley back, and run off of the stock belt. If I don't touch anything else, I should be able to use the s/c tune. I mean, it'll just stay on the part of the map where there's no boost, right?
Old 06-26-2023, 08:48 PM   #5
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Yes if it makes no boost you still fine on the SC tune
AussieBRZ is offline   Reply With Quote
Old 06-28-2023, 07:42 AM   #6
LS1M
Drives: 2015 BRZ
Well, that was the most depressing Saturday ever.
Spent several hours making my car slower.
I was able to put some stock parts back & get it running while I send the blower back for a replacement.
I think it might be slower than stock now, since it has to suck air through all that tubing and the intercooler.
http://ls1m.com/demo/SCGONE1.jpg
http://ls1m.com/demo/SCGONE2.jpg
Old 06-28-2023, 12:58 PM   #7
alphasaur
friendly
Drives: 17' 86
Just have lag now
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-28-2023, 05:54 PM   #8
CSG Mike
CSG Mike's Avatar
Remove rotrex assembly.
Replace stock pulley and belt
Replace stock intake
Flash stock rom.
Leave the intercooler and everything else in place, for minimum re-assembly/installation. Tape up/cover up all the hose/pipe openings so you don't get contamination.
What's the official solution to bypassing the VSS + e-brake sensor for videos? [Cyanide] Electronics | Audio | NAV | Infotainment 37 05-05-2015 02:51 AM
Bypassing the navigation activation ??? Sabretooth Electronics | Audio | NAV | Infotainment 15 02-24-2015 12:32 PM
Bypassing your NAVI without moving out your NAVI 8987846 CANADA 0 12-24-2012 03:20 AM
