Old 04-13-2023, 06:52 PM   #15
Grady
Grady's Avatar
All if you are skilled enough.
Old 04-14-2023, 12:45 AM   #16
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
The door cards are obviously different but the doors look pretty similar. The windshields are different but does anyone know if any of the other glass pieces are interchangable? It wouldn't surprise me if the carpet was the same. The pedals and the trim piece behind the gas pedal also look similar. I'm too lazy to look up the part numbers for this stuff. I think the Whiteline transmission, rear subframe and diff inserts are all compatible if you're counting aftermarket parts.
Stephen02 is offline   Reply With Quote
Old 06-25-2023, 12:30 PM   #17
sftateofmind
Evening Primrose
sftateofmind's Avatar
Originally Posted by DarkPira7e View Post
The gas in the tank, transmission, seats all swap over.
Anyone here swap seats? Curious to see
sftateofmind is offline   Reply With Quote
Old 06-25-2023, 02:57 PM   #18
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Seats have been done, straight swap
Old 12-25-2023, 03:50 PM   #19
iag48st
Drives: 10Series 0945
Has anyone installed GR86 oem suspension on a first generation BRZ?
Ive read it should fit fine but just want to make sure.
thanks
iag48st is offline   Reply With Quote
Old 12-28-2023, 04:19 PM   #20
foshjowler
Drives: 2022 BRZ; 2014 BRZ
thanks
They'll bolt up no problem. I haven't tried that specific mix, but have a set of coilovers that have been on both my second and first gen, and the only difference was the first gen's bolts were a little crustier. It's possible there are small changes in damping and spring rates, but those won't change how it bolts in.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
The Following User Says Thank You to foshjowler For This Useful Post:
Teseo (12-29-2023)
Old 12-29-2023, 12:38 PM   #21
Teseo
Drives: frs
I bet 2nd Gen are in softer side. Wonder if 2nd Gen seats are more comfy than 1st Gen
Old 12-29-2023, 03:03 PM   #22
foshjowler
I can only compare brand new 2nd gen seats to 130k mile 1st gen seats, but I do find the 2nd gen to have a little softer seats and the 1st gen bolsters to be a little more aggressive. They're very similar though, and it's minor differences.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Teseo (12-29-2023)
FS: BRZ Parts - tS Shift Knob - 2013 OEM STi Front Lip - 2013 Front Bumper chermo12 Canada Classifieds 2 09-19-2020 11:47 AM
FS: Interior parts out of two 2013 Scion FRS' and interior out of a 2013 BRZ Limited Dave-ROR Interior Parts (Incl. Lighting) 22 01-08-2020 07:50 PM
FS: 2013 FRS | Whiteout | 6MT | top shelf quality parts & OEM parts included | SOCAL 8R6 Cars for Sale/Trade 5 03-11-2017 11:32 AM
FS - 2013 FRS Parts GYNXxx Canada Classifieds 5 03-10-2017 04:45 PM
