#491 |
Famous Potatoes
Drives: '15 ultramarine
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | soundman98 (08-15-2023), whataboutbob (06-25-2023) |
#492 |
Drives: GR Corolla
Disassembled the old wicker patio/California room furniture since the wicker parts were cracking and coming off. No before pics. Assembled the new, better looking furniture (pictured). I can actually use these comfortably. Lol.
| The Following 4 Users Say Thank You to Kaotic Lazagna For This Useful Post: |
#493 |
AutoX-10/10ths every run
Zestimate right now is $813,200, with a range of $740K to $878K. LOL
| The Following User Says Thank You to whataboutbob For This Useful Post: | humfrz (06-25-2023) |
#494 |
The Dictater
Drives: '13 Red Scion FRS
I guess I'm learning how to install head flashing over my new basement door today. Contractor tried just caulking it, and that all pulled off so now water comes in from above the door. You would think someone who does this for a living would know better.
Should I be worried about mold/rot underneath inside the drywall after like 3 storms?
Also: "Build Thread" |
#495 |
Drives: 2018 Subaru BRZ
I opted, for now, to use a water filtration system for the whole house. Basically set up two filters right after our well water pump that would feed directly to the water heater, the external water connection for the yard was also benefited from the filters.
I gotta say, PEX is incredibly easy to work with, had to spend some money on the crimping tool but I feel it would help on future projects, like the water softener. Scaling must had been pretty bad because as soon as I lined up the isolation valves and restored water flow, the first filter almost instantaneously turned a light shade of red, and the second one turned black, so I'll need to replace the filters soon.
#496 | |
ProCrastinationConsultant
#497 |
The Dictater
Uhhh, if you are referring to the exterior, I don't think I do actually. I did call the contractor last week and I got a call back about 20 minutes after my post lol. It is mostly fixed now, I just need to paint over stuff.
I have sections of concrete(?) for basement walls, there is a rectangular hole in the concrete, with a wood frame inside the hole. The door frame mounts to the wood. The caulk they initially installed the door with peeled up the old weathered paint on the wood and, being on the windward side of the house, rainwater just poured in. They cut out the old caulk, applied some adhesive sealing stuff in the crack, then re-caulked. It worked with some pretty intense rain and wind this afternoon at least. I'll get some paint on it this weekend and it should be good I think.
#498 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (08-15-2023) |
#499 |
The Dictater
I suppose taking a picture would clear things up lol. No siding around the door.
| The Following User Says Thank You to Spuds For This Useful Post: | NoHaveMSG (08-16-2023) |
#500 |
Famous Potatoes
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#501 |
Drives: 2013 frs base
Back during covid, I had some extra time, so I re-did the faux wicker on our porch chairs with craftcord. Almost sweat shop quality, if I do say so myself.
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | bcj (08-16-2023), Ultramaroon (08-16-2023) |
#502 |
The Dictater
What do you mean?
#503 |
Drives: Crapcan
Yeah, no idea on my end how they seal that.
#504 |
Those are sweet! 10/10!
| Tags |
| diy, home, living |
| Brought my BRZ home today | Smokinbuffalo | Northwest | 8 | 05-31-2012 11:49 PM |
| WRB-Got it home!!! | jaytaurus | BRZ First-Gen (2012+) — General Topics | 28 | 05-29-2012 11:33 AM |
| #64 brought home today. | FujiwaraTofuShop | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 09:04 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
