Old 06-21-2023, 05:01 PM   #15
alphasaur
friendly
Drives: 17' 86
Direct injectors removed anddddddddddddddddd
they look perfect.
fuck me.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-21-2023, 08:57 PM   #16
alphasaur
friendly
Drives: 17' 86
So replaced injectors, started up without the driver side injector cover. PRETTY sure I can isolate the noise to the DI pump using my stethoscope.
When revving noise appears to disappear?
Going to take it for a short drive tomorrow/friday and see how it is
edit:
Sounds EXACTLY like this, with a VERY similar cadence
https://www.skyroadster.com/threads/...jectors.97189/
also no codes
Old 06-22-2023, 08:30 PM   #17
edit:
also no codes
It absolutely does, but I've never heard another fa20 make that noise. If it's the SCV, then I think something is off, like it's sticking. Crickets are the sound of DI rail pressure being properly regulated.
Old 06-22-2023, 08:50 PM   #18
alphasaur
friendly
Drives: 17' 86
Think I can just replace the hpfp if so? Maybe bad gas? Has been sitting for close to a month
Old 06-22-2023, 10:59 PM   #19
Meh. A month is nothing. If you can log, I wouldn't throw parts at it just yet. Log the DI rail pressure while it's idling. I wonder if the SCV current, or duty cycle can also be logged.
Or maybe it's no biggie.
edit: https://gt86stuff.onrender.com/t3Por...00PG7039X.html
Old 06-23-2023, 09:11 AM   #20
alphasaur
friendly
Drives: 17' 86
https://docs.google.com/spreadsheets...Bak0Mc/pubhtml
log
Link super helpful, thank you!
Old 06-24-2023, 04:45 PM   #21
Nope. Surprised this isn't throwing some sort of code. 10 secs of yours vs ten of mine. For me, fuel sys modes 2 and 4 are closed loop and fuel cut respectively.
edit: I mean "fuel system status" codes. I don't know how it would be possible for yours to be in fuel-cut mode so I'm not really sure what any of it, including my own, means.
Old 06-24-2023, 10:45 PM   #22
alphasaur
friendly
Drives: 17' 86
well definitely looks drastically different than yours
I drove today and it seems mostly okay? No codes. Didn't get super into it since it's base tune. Clicking seems to have decreased drastically so not sure what it was but it definitely still seems present, just not nearly as loud. I did order a new HPFP off of ebay from a 19' with 15k miles.
Sent logs to tuner so we will see what he says.
Also have a super slow leak from the area in green unfortunately. Tried tightening but no luck. Going to try an Earl's 10an seal and some permatex high temp thread sealant IDK
this oil drain location is honestly not my favorite due to proximity to header and belts (it is not touching manifold, it's the angle of the photo. It is close at it's closest though at probably 1/4-1/2 of an inch)
Old 06-24-2023, 10:59 PM   #23
It's clearly having trouble regulating rail pressure. If you enable the PI ratio graph you can see that your keeps trying to kick in but flops. That might even be the sound we hear.
Old 06-25-2023, 12:52 AM   #24
alphasaur
friendly
Drives: 17' 86
in your picture it matches the cadence of the sound (about 1 click every 10 seconds) so maybe
IDK
Not sure what I could have fucked up
@AussieBRZ, any thoughts?
@tomm.brz you seem smart too IDK if you can help lolol
Old 06-25-2023, 05:42 PM   #25
tomm.brz
Drives: brz 2017 hksv2
i m not following quite good this thread
what kind of injectors are installed and what is the settings of them in the tune?
Old 06-25-2023, 07:41 PM   #26
Started up today successfully!
I do have this odd noise that I don't remember having before?
https://www.youtube.com/shorts/hlNV1sVt-_I
you hear it once the camera gets lowered. It's louder/more noticeable in person. It sounds like it's near driver side injector area/head
Am I crazy?
@DarkPira7e @Ultramaroon
Haven't driven yet waiting for a part for my bumper
Hi, Tomm. Maybe less confusing if you only start reading at the post I quoted. Strange ticking sound. A few in more rapid succession but mostly about one tick per second.
Old 06-25-2023, 08:19 PM   #27
alphasaur
friendly
Drives: 17' 86
Hi yes thank you!
See youtube video for clicking
Then see that fuel system status fluctuates between 2 and 4 and di fuel pressure seems to be very inconsistent
OEM injectors, di injectors recently cleaned. 3 bar omni map. K00c tune.
Old 06-26-2023, 08:01 PM   #28
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
IDK
Yes seems strange usually di fuel pressure failry steady 3 to 4 MPa at idle
Check the grounds on the DI computer under Bonnett all three bolts in and tight
Also it might be the di fuel pressure sensor feeding the di computer weird info then the di pump tries to follow that.
My guess would be di pump or di pressure sensor if the di computer is correctly earthed/grounded unless there is something very weird in tune
AussieBRZ is offline   Reply With Quote
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full blown Stage 1 premium turbo kit vs JDL v2.1 Greenbean Forced Induction 11 09-05-2019 04:10 PM
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
Help full blown stage 1 turbo h22mike Engine, Exhaust, Transmission 40 12-07-2014 11:31 PM
Full Blown, stage 2 turbo kit Ironsquid User/Vendor/Sponsor Reviews, Feedback, Comments 4 02-17-2014 11:22 PM
