Old 06-23-2023, 04:12 PM   #1597
Lantanafrs2
Drives: 2013 frs red
Nothing new here (as the article even alludes to) but like it or not it's an "offensive stereotype" that shouldn't be tolerated, and I don't.
So stop it, and get off my lawn.
It's OK to wear a tiger suit all day and shit into a "dignity tube" though.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Dadhawk (06-23-2023)
Old 06-23-2023, 04:34 PM   #1598
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Is California doing anything to their electrical grid over the next decade?
They can't even sustain their current electrical load
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Lantanafrs2 (06-23-2023), soundman98 (06-24-2023)
Old 06-23-2023, 04:44 PM   #1599
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Don’t try to censor me. No one likes cancel culture. I can say what I want
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 06-23-2023, 05:11 PM   #1600
Sasquachulator
Pavement Grey
Especially not until there is any kind of standardization throughout the industry on battery packs. They have standardized other things before though so not out of the realm of possibility.
Not to mention the size and scale of a CAR battery swap.
This isnt a garden mower and electric trimmer sharing a 20v battery the size of a tissue box or AA/AAA/C/D batteries that fit in the palm of your hand.
This is a battery pack for a car.......a battery pack that probably weighs a thousand pounds and is the size of a king sized mattress...
No one is gonna have the capability to store and move around this thing in their house without some kind of lift/trolley, and any kind of swapping stations would need to be the size of a warehouse and fully automated....with electricity running through it 24/7 to store keep charging depleted batteries.
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
new2subaru (06-23-2023), NoHaveMSG (06-23-2023)
Old 06-23-2023, 06:04 PM   #1601
new2subaru
Weight Weenie
Drives: 15 FR-S
Sounds awesome
Old 06-23-2023, 06:09 PM   #1602
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
A cope trailer
Arthur-A is offline   Reply With Quote
Old 06-23-2023, 06:13 PM   #1603
Irace86.2.0
Those were just examples that could cause the path to branch. What if, for example, someone could figure out how to pull Hydrogen directly from the atmosphere through some magical process that doesn't exist yet? It's not like "magical" processes don't get developed all the time. Heck, we're using one to have this conversation. No one 100 years ago would have thought we'd be doing this Internet thing.
As far as battery swapping, I know you're an enthusiast but I still think that won't be happening, at least not in the US.
If bacteria could digest food and release hydrogen then maybe, but they would still need a substrate like wood, plastic, etc; would it be renewable? Could it be done at scale? It could happen. Maybe we could genetically engineer or use an evolutionary process to evolve a bacteria to produce hydrogen. Outside of that, I see no other way to produce hydrogen without using something that could produce electricity or doesn’t require electricity. Can you?
NIO looks to enter the US market in 2025. Swapping will be popular in the future unless batteries see a huge bump in power density and charge rate. Until then, I’m a bull on swapping, especially if your scenario of a materials bottleneck and supply dependence pushes the market towards batteries that favor swapping. Hopefully we are both wrong.
Old 06-23-2023, 07:33 PM   #1604
Irace86.2.0
Yes. Millions of new homes with solar and dozens of large scale projects in the billions.
https://www.renewableenergyworld.com...ables-by-2023/
We have rolling blackouts during windy conditions to avoid fires certain times of the year. Occasionally a heat wave with high use that occurs during times of low supply can require rolling blackouts. This year we had less heat and more hydro, so we didn’t need much. There are times the state ran completely on renewables too during low usage and high supply moments.
Old 06-23-2023, 07:48 PM   #1605
Irace86.2.0
NIO has done millions of battery swaps. Their third gen stations can perform a swap in four minutes and do 408 swaps per day. Not as huge as a warehouse.
https://asia.nikkei.com/Spotlight/El...-swap-stations
Old 06-23-2023, 08:01 PM   #1606
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I could see in the future doing many smaller manageable cells that could be interchangeable if they could settle on a standard. They would still likely need a lift to get out still. An overseas company in my industry tried doing a hot swap battery setup with a smaller lithium pack instead of opportunity charging but it is like 40lbs and tougher to manage by hand then it looks on paper. I don't see hot swapping on EV's as something you would be doing at home, it would have to be like a gas station.
Another issue is different chemistries need different charge parameters. So if you have NCM's, you'd need all NCM's. Or you would also need an identifier in the BMS for the chemistry so if you were to charge these at home you are getting the correct charge profile for the chemistry of that particular pack. Current packs are modular cells already that are series/paralleled together to get desired voltage and capacity.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (06-24-2023), Wally86 (06-28-2023)
Old 06-23-2023, 08:32 PM   #1607
and Washington (state) joins the NACS band wagon.
Irace86.2.0 (06-23-2023)
Old 06-23-2023, 08:33 PM   #1608
OK, "Z"ero....
Old 06-23-2023, 08:35 PM   #1609
If bacteria could digest food and release hydrogen then maybe, but they would still need a substrate like wood, plastic, etc; would it be renewable? Could it be done at scale? It could happen. Maybe we could genetically engineer or use an evolutionary process to evolve a bacteria to produce hydrogen. Outside of that, I see no other way to produce hydrogen without using something that could produce electricity or doesn’t require electricity. Can you?.
Wll no, but that was my point. I can also see there could be solution no one has thought of yet.
Old 06-23-2023, 09:34 PM   #1610
Irace86.2.0
OK, "Z"ero....
FWIW, I’m at the transition year of gen X and Y (Millennial).
I’m not talking about the specifics. I’m talking fundamental physics/chemistry. Where is the energy coming from that would process this reaction because it would have to be from something that could generate hydrogen while not being a usable form of energy like electricity?
The only example I have seen is using bacteria. Sometimes their requires small amounts of energy or chemical reagents. The idea of using bacteria isn’t new. The problem is rate of production, purity of the product, consistency, and scale. The cost is a secondary factor along with the efficiency of the process along the supply line from generation to capture to transport and delivery.
https://www.rechargenews.com/energy-...ss/2-1-1322589
Dadhawk (06-24-2023)
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 01:46 AM
Does anyone know why pansontw got banned? Soloside Off-Topic Lounge [WARNING: NO POLITICS] 17 10-26-2018 04:20 AM
Got banned from gf's complex jdmblood Other Vehicles & General Automotive Discussions 11 07-12-2015 12:46 PM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 02:23 PM
Banned Toyota GT 86 Advert Banned Nevermore FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 11-16-2012 07:27 PM
