| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#1177 | ||
Drives: GR86
I'm not saying it's a black and white thing every time (or even this time). I'm saying that if you as the owner/driver demonstrate a lack of common sense and abuse the car in a way that warranties don't cover, warranties don't cover your abuse. Quote:
#1178 | |
Drives: Crapcan
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#1179 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
#1180 |
Could this video be any more vague on just how big a problem this is? Terms like "a lot of owners" etc means nothing. Also, starting off the discussion by saying it "started happening with a couple of months of the car coming out" then immediately saying "it happens when tracked cars have 10K or 20K miles on them" doesn't help with credibility. Nor does saying it happens with "modded cars".
I get the point, there is an issue for some people with the vehicle and there have been issues with some of the warranty coverage, but like the valve spring issue they refer to, it's a small limited number of cases out of thousands of vehicles.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1181 |
Bullshit clickbait right from the title. Just say no.
#1182 |
Drives: '23 BRZ
Is it advisable to overfill the oil by 1/2-quart or even a quart to mitigate risk oil starvation at the track, or would that quickly result in frothing issues?
First track days with my '23 are coming up next Mon/Tue at NJMP Lightning! Only mods are lowered ~32mm on RCE SS-2 coilovers, SPC camber bolt at left front, hope to have at least -3 front camber, rear camber is -2.7/-2.1. This car is *way* more asymmetrical than my '17 was! Will be running 225 RT660s on 17x9 +37 wheels, and maybe also 225 A052s on 17x9 +35 if the RT660s do not rub... Fingers crossed! |
| The Following User Says Thank You to ZDan For This Useful Post: | fredzy (06-20-2023) |
#1183 |
Over an hour long, I watched 2 minutes.
| The Following User Says Thank You to Dadhawk For This Useful Post: | Ultramaroon (06-20-2023) |
#1184 |
Drives: Crapcan
I am listening to it now and it is pretty garbage.
So far: Lot of cars, mentions 3 that blew up. Claims thedrive is releasing an article on a blown up car every month. Doesn't believe RTV is the root cause, thinks it is lateral G. Thetopher believes frequent oil changes and adding liquid moly helps.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | DarkSunrise (06-20-2023), DocWalt (06-20-2023) |
#1185 |
Drives: Crapcan
It gets better. Zygrene doesn't think dropping the oil pan to check for RTV is worth doing. He advocates more frequent oil changes, adding liquid moly, and using 5-30. The others disagree on this. One of them being friends with the guy from CM Autohous who is in the bay area and regularly posts video of cleaning GR/BRZ oil pickups. I'm listening, not watching so I don't know who said this. Pretty sure if you have a dealer do this, and they find RTV, they will probably cover under warranty.
#1186 | |
Drives: '23 BRZ
| The Following 5 Users Say Thank You to ZDan For This Useful Post: | Dadhawk (06-20-2023), new2subaru (06-20-2023), NoHaveMSG (06-20-2023), Pat (06-27-2023), Ultramaroon (06-20-2023) |
#1187 | |
Mebmer
Drives: Sienna, GR86, TourX
![]() My first track day with the 23 is coming up this weekend as well. No mods except BBK. I never messed with the pan and I'm not concerned about the engine at all. Fresh-ish M1 0w20 and will avoid getting it near 260F. If it blows up and Toyota will cover it, I wonder if they could just give me a cash payout instead of fixing it? Solve the issue permanently by putting a non-Subaru engine in |
| The Following 2 Users Say Thank You to fredzy For This Useful Post: | ZDan (06-20-2023) |
#1188 | |
Drives: Crapcan
Back to the video: Again, I can't see who is saying what all the time but one of the claims is the car is only capable of doing 2-3 laps before overheating and modifications only help that a little bit.
#1189 | ||
Drives: '23 BRZ
#1190 | |
Drives: Crapcan
The whole video is like this. They seem to blame lateral force a lot but don't say what pressure numbers they consider starvation. The oiling system on the FA24 isn't that much different then the FA20. The routing from the pickup to the timing cover is actually nicer looking with less bends and passage changes but they keep talking about how tough the FA20 was. They are the same architecture I can see the FA24 maybe being less tolerant due to having more power output IF all other things in it's assembly were equal, but I'd like to believe things like rods and pistons were likely strengthened a bit.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | ZDan (06-20-2023) |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
