Old 06-17-2023, 05:53 PM   #197
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
New wheels on. I think I'm going to need mud flaps, and maybe go a bit lower...
Also: "Build Thread"
The Following 6 Users Say Thank You to Spuds For This Useful Post:
autoracer86 (06-18-2023), JD001 (06-18-2023), NoHaveMSG (06-18-2023), Racecomp Engineering (06-17-2023), RedReplicant (08-20-2023), Wally86 (08-22-2023)
Old 06-17-2023, 07:17 PM   #198
percussion, I mean persuasion.
I bet it still leaks from the v-banded joint. They can be real bitches. They suck at overcoming any force holding the faces out of parallel. Order of tightening operations can take that into account. If it was mine, I'd have loosely installed the collector to the overpipe and played with all the parts relative to each other. Have any grooves formed on the inside faces of the band?
Spuds (06-17-2023)
Old 06-17-2023, 07:24 PM   #199
Spuds
The Dictater
Spuds's Avatar
I bet it still leaks from the v-banded joint. They can be real bitches. They suck at overcoming any force holding the faces out of parallel. Order of tightening operations can take that into account. If it was mine, I'd have played with loosely installing the collector to the overpipe and play with all the parts relative to each other. Have any grooves formed on the inside faces of the band?
It's definitely the double slips. I checked with a handy dandy smoke pen.
Specifically it's the bottoms of the lower primaries. Might seal a bit better when really hot but I let the engine get up to temperature before testing. Vband seemed fine all around.
Order of fastening: header to engine, vband, front pipe to mid pipe.
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (06-18-2023)
Old 06-17-2023, 07:58 PM   #200
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Ride height looks good to me, I would leave it just like that. Congrats on the new wheels, they look stunning on red! Great color combo.
Originally Posted by humfrz
I'm old and lazy
Spuds (06-17-2023)
Old 06-18-2023, 02:01 AM   #201
Hey, that's pretty sweet! Oh well. So much for guesswork. I'm with Clipdat. Wheels look great.
Spuds (06-18-2023)
Old 06-18-2023, 07:33 PM   #202
Spuds
The Dictater
Spuds's Avatar
Autocross #3 with the current setup. Now with magic donuts of stiction. About 2 seconds off the STX leaders pace, but not bad for my first time on 200tw.
These re71rs tires are pretty amazing lol. Upped front camber to -3.4° from -3.0°. might be able to use some more, haven't checked tires yet. I can probably get 4 ish with the parts I got, but I think 3.4 is sufficient. Rear seemed happy with -2.1° for now. Still having some weird toes/thrust angle issues that I need to wrap my head around...
If I can get the alignment sorted I might play with stiffer damper settings next time out. Just been using recommended street settings from RCE, but the fast tires allow for much quicker transitions grip-wise.
Header is definitely better, as fuel trims stayed reasonable. But it's still definitely leaky
NoHaveMSG (06-18-2023), Racecomp Engineering (06-20-2023)
Old 06-18-2023, 07:47 PM   #203
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Loving the wheels on the red. Looks amazing
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
Spuds (06-18-2023)
Old 08-16-2023, 10:56 PM   #204
Spuds
The Dictater
Spuds's Avatar
Finally got my alignment where I want it, or at least it's close enough. Maxed out camber front and rear to -3.6 and -2.2 respectively. As close to 0 toe as I can measure all around. Still using RCEs standard recommended damper settings, which are nice to drive around in. Still having a bit of trouble with instability in quick slaloms but that might be next year's problem to figure out.
Best autocross result is 6th overall out of 60ish so far. Still about a second off the STX leader pace.
Now I need to work on the tune and figuring out ways to cool the engine bay. The front edge of my hood is literally too hot to pick up at times. I blame headers. Some options I'm considering:
1.The right solution is probably to wrap the already ceramic coated headers... or get new fully welded headers and wrap those lol. But that would mean taking the headers off again and I don't wanna.
2. Find an STX legal way to vent heat out the top. Too bad I can't do hood vents...
3. I wonder if removing the under-hood insulation would help. That is, if there isn't any other detrimental effect like killing my paint with heat.
4. Reflective tape everywhere I want to keep cool
5. Mess with fan settings in tune/better fans
NoHaveMSG (08-22-2023)
Old 08-17-2023, 11:40 AM   #205
gnarjunkie
Drives: '23 GR86, '17 BRZ
That smoke pen is neat!
How exactly were you using it to check for leaks? I've got a suspicion that my headers are a bit leaky too and was going to try to find a shop to do a smoke test. But that pen looks way more neater.
Also have the same thing happening with the underhood heat. It's crazy how fast headers on these things heat up. At least for me, the only detriment seems to be high IATs, so I'm going to try insulating the intake tube and putting reflective tape on it then getting some hood struts so I don't have to hold it open myself
gnarjunkie is offline   Reply With Quote
The Following User Says Thank You to gnarjunkie For This Useful Post:
Spuds (08-19-2023)
Old 08-19-2023, 09:27 PM   #206
Spuds
The Dictater
Spuds's Avatar
I lift the car onto 4 jack stands, remove the metal under tray, open the hood and turn it on. Light the pen/wick so there's a good stream of smoke coming off it, then move it around under the exhaust so the smoke stream goes around the joints. It should flow smoothly, if it gets really turbulent, that's a leak. Obviously doesn't work when the fan turns on.
I recommend sticking the pen in a deep socket to keep it upright when you aren't holding it and want to keep it lit.
Another detriment to the heat is that my battery terminals are corroding quite quickly. Also, I can't imagine that amount of heat is good for the paint on the hood or anything else in they bay.
Old 08-19-2023, 11:44 PM   #207
gnarjunkie
Nice. Thanks! I'll give that a try.
Previous cars I've always just felt around the headers for leaks, but these ones get so hot that by the time I start the car and crawl under it they are already almost too hot to hold my hand near.
Old 08-21-2023, 07:17 AM   #208
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Someone on the board had figured out a way to make the small side panels at the top of the fenders (where the boxer logo is) into vents. It does require some cutting though. Technically that's not a hood vent. Would this work?
Otherwise cutting holes into the top of the front bumper? Or using spacers on the hood hinges?
Fabricating a heat shield for the header?
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Spuds (08-21-2023)
Old 08-21-2023, 04:06 PM   #209
Spuds
The Dictater
Spuds's Avatar
I can't do any extra vents that weren't there to begin with per STX rules if I read them correctly. Especially cannot cut holes for cooling. I CAN remove badges and plastic covers which may or may not include those plastic panels, but there's not much ventilation to be gained by that by itself.
I don't think I'm allowed to modify the hood hinges to add cooling holes either. That's not really the best place to put a hole anyway, as it's high pressure when driving.
I could make a heat shield if it only attaches to the header itself, but at that point I'm better off wrapping the headers.
Old 08-22-2023, 09:30 AM   #210
alex87f
Meow
alex87f's Avatar
I was thinking something along those lines https://www.ebay.com/itm/233591412126 (special points for rice look)
Spuds (08-22-2023)
2018 Camaro SS 1LE vs Spuds' FRS Spuds FR-S / BRZ vs.... 13 06-16-2019 10:11 PM
FRS from Vroom - RISKY? Cosa Scion FR-S / Toyota 86 GT86 General Forum 14 10-21-2018 09:27 PM
So my key FOB was put in the washing machine.... Kayzer Soze BRZ First-Gen (2012+) — General Topics 11 06-07-2013 11:43 AM
Vroom! - This week's blipshift shirt blipshift Miscellaneous 1 11-13-2012 10:29 PM
