Old 05-21-2023, 04:52 PM   #127
RedReplicant
Drives: None
Originally Posted by autoracer86 View Post
wow congrats and sounds like the car is very reliable, usable and fast. Looking forward to hearing about the Xidas
Yeah, I'm excited to drive them. Brock (posted above) bought the very lightly used set that popped up on the forum last week and from what I've heard so far he is happy. I'm sure he will post about them once he has an event on them.
Originally Posted by clu View Post
Wish I went with Xidas. I've been waiting on a set of Nitron R1s since March with no ETA still. Looking forward to the development of the car!
I've heard good things about the Nitrons too, but I've never seen a set in person. Interested in what you think of them when the time comes
Originally Posted by Pat View Post
What an outstanding post. I wish I could like it more than once. Great job gettin' after it!
Thank you, hopefully it stays reliable lol.
Pulled the header and it isn't cracked anywhere, but the flange is very, very slightly warped (1/16" or something) and has a bit of exhaust residue. With any luck having the flange flattened clears up the ticking I noticed yesterday.
RedReplicant is offline   Reply With Quote
Old 05-21-2023, 05:01 PM   #128
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Remflex may be a good option for you. Was the only way I could get the header to seal on my built 22RE. It was pretty warped.
http://catalog.remflex.com/HONDA_Hea...t_p/53-008.htm
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
DocWalt (06-06-2023), Kelse92 (05-21-2023), RedReplicant (05-21-2023)
Old 05-21-2023, 05:02 PM   #129
RedReplicant
Drives: None
Funnily enough, I ordered one of those on Summit before I posted. Nice to have some kind of confirmation
The Following User Says Thank You to RedReplicant For This Useful Post:
NoHaveMSG (05-21-2023)
Old 05-21-2023, 07:00 PM   #130
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
The Nitrons are worth the wait, but the can take a while at times. Their production team is small.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following User Says Thank You to Kelse92 For This Useful Post:
Old 05-21-2023, 07:02 PM   #131
Kelse92
At the track
Originally Posted by RedReplicant View Post
The car never broke causing it to fail to finish an event, which is pretty awesome for a fresh build / swap. Things that I broke over the season:
- Three throttle body bolts, one taking a throttle body adapter with it
- 1x OEM 65mm BRZ throttle body
- 1x Bosch 74mm throttle body
- 1x front Timken wheel bearing
- 1x Jack's built BRZ Transmission
- 1x MAP sensor wire
- 1x Wiring harness power wire
- 1x Exhaust gasket
- 1x Experimental Valve Cover Baffle
- 1x Coilover strut bearing
- 1x Coilover strut bearing to spring hat ... thing
All in all, pretty legit. I do think that I cracked the header this event, so I'll be pulling that tomorrow to see what is up.
Honestly, not bad at all!! Kudos!
Old 05-22-2023, 12:29 AM   #132
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
It's all in the stickers . Nice half a season thus far
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
RedReplicant (05-22-2023)
Old 05-22-2023, 10:57 PM   #133
RedReplicant
Drives: None
I don't usually buy track pictures but I thought these two were kinda interesting, they were one after another.
Whole car sucks down on the brakes instead of front only diving. You can also see I STILL don't have my splitter level or correctly raked yet.
And also, the obligatory two wheel picture.
This was the WHP East video. I actually ran two laps in different sessions that were 1:02:144 and 1:02:145 on official AMB transponder, this was the one faster on AIM timer.
Unfortunately, mistake out of turn 2 cost the 1:01, I shouldn't have lifted from WOT at all through the left hander after the carousel, and I should have carried more speed through the kink where the pit entrance is. Downside of the kink is that there are at least four curbs involved that will eat a wheel if you get it wrong.
The Following 8 Users Say Thank You to RedReplicant For This Useful Post:
autoracer86 (05-22-2023), Irace86.2.0 (05-26-2023), JeffForSale! (12-28-2025), kask2_6.0 (06-05-2023), Kelse92 (05-23-2023), nissanfanatic (06-02-2023), NoHaveMSG (05-23-2023), villainous_frx (05-22-2023)
Old 06-04-2023, 07:09 PM   #134
RedReplicant
Drives: None
I dropped my header off with a local track guy that has a business that does flattening for aerospace / semiconductors, pretty cool setup and when he stuck the header flange on his flat table he just laughed. Still waiting to get it back but I'm not in any real rush.
Finally got around to putting together the ACE radiator ducting that I've had in a box since I bought the car, fits fine with the K intake.
After noticing a bit of melty melty action going on with some plastic on the hot side of the motor and seeing Trip Walker's fire action melting the fuse box I decided to do a bit of heat shielding.
Few nutserts and some aluminum pieces later and I've got this. I'd like to add one more support to the top of the shielding in the back, but there isn't much I'm willing to stick a drill bit into back there. Should be fine, but we will see.
Not the best, not the worst, but it'll do the job for right now. The valve cover is off because Charlie / Doryoku made me a new valve cover with the vent on the top of the valve cover instead of the side; having the vent on the side was a dumb idea on my part, it pushes oil through in right hand corners.
I'm waiting on the Xidas to show up, but in the mean time I picked up new bushings for a set of RacerX RUCA that I saved from Hyperblue. TT5 rules changed this year (of course) allowing you to get rear toe, RUCA or RLCA, and front lower control arms for free.
I still have to do something about my wavy splitter, but I'm not really sure what I want to do. The thing is warped up at the front edges from moisture and the front of the splitter should really be raked so it is lower than the rear, so I've got a problem there. This is what it looks like, if anyone was curious.
Four professional awesome splitter rods up front, the aluminum bracket shown in front of the radiator support, and two bolts that come up through the bottom of the radiator support and catch two nuts dropped into the support. Verus air dam bolted onto it and it gets sealed to the bumper with gaffer tape.
I think the real answer is a home made foamcore CF splitter, I just don't know that I really want to deal with the gigantic mess.
Looks like the go-to core material is this in 3/8" or 1/2": https://www.fibreglast.com/product/V...m_3_lb_Density
Far cheaper and easier would be skipping vacuum bagging, but I don't know what the weight / rigidity tradeoff is in real life.
Easy button is sending a template to AJ Hartman or Lang Racing Development, both which are around $1200 or so. Racebred also does their cut wood splitters for $400.
We shall see.
The Following 7 Users Say Thank You to RedReplicant For This Useful Post:
DocWalt (06-06-2023), gt5759 (06-05-2023), Irace86.2.0 (06-07-2023), Jdmjunkie (06-04-2023), KMA KiCKz (06-05-2023), redlined600 (06-06-2023), villainous_frx (06-04-2023)
Old 06-06-2023, 11:19 AM   #135
redlined600
redlined600's Avatar
Drives: Fr-s
That heat shielding looks good!
I have many of the same thoughts about trying carbon fiber for a splitter. :-)
The first splitter I made was up in the front as well (followed the bumper). I found this to produce a lot of drag which showed up at the end of long straights. It might be worth getting the angle correct on your current one and test before going all in on a new one.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
RedReplicant (06-06-2023)
Old 06-06-2023, 02:10 PM   #136
RedReplicant
Drives: None
Yeah, fair point. I have to move the front two splitter rods because of where the intake duct anyway, I think if I chop down my two rear mounts a bit and extend the front rods a bit it'll push the splitter to where it needs to be.
I'll need to beg for a guest pass to one of the private tracks next month to get everything in the right window once I'm done here.
villainous_frx (06-06-2023)
Old 06-09-2023, 05:56 PM   #137
RedReplicant
Drives: None
I ended up doing a piece of 1/8" aluminum L with some elevator bolts through the bottom, it easily passes the stand test so I think we're good for now.
New Doryoku valve cover with a serviceable baffle, front shaved for hood clearance, and a 10an ORB on top installed.
Xidas showed up today Maybe I'll do all of the suspension this weekend.
The Following 6 Users Say Thank You to RedReplicant For This Useful Post:
autoracer86 (06-09-2023), DustinS (04-13-2024), gt5759 (06-21-2023), justinco (06-26-2023), new2subaru (06-09-2023), NoHaveMSG (06-09-2023)
Old 06-09-2023, 08:00 PM   #138
clu
Drives: 2013 Subaru BRZ
Still can't figure out how to "thank" a poster lol. Progress looks great, and those Xidas 😍. Funny enough I got the Nitrons last week
clu is offline   Reply With Quote
The Following 5 Users Say Thank You to clu For This Useful Post:
DocWalt (06-11-2023), doward (06-26-2023), DustinS (04-13-2024), Kelse92 (06-14-2023), RedReplicant (06-09-2023)
Old 06-09-2023, 08:45 PM   #139
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
those Xidas look awesome. Can't wait to hear how they compare to the shaftworks oh and I got the 12mm top bolts you recommend as well. So thanks again for that
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
Old 06-09-2023, 09:51 PM   #140
RedReplicant
Drives: None
Hopefully they help you out
Those Nitrons are beautiful Praise pin style spring collars, haha.
autoracer86 (06-10-2023)
Silviacrazed's FR-S adventure Silviacrazed Member's Car Journals 52 06-01-2021 11:20 PM
Harrop 2015 TVS kit image.. FT86_AU Forced Induction 255 07-25-2016 03:50 AM
SubieBuis BRZ Adventure subiebui Member's Car Journals 13 12-06-2015 05:57 PM
Off The Grid Adventure m.box.design Northwest 8 03-22-2014 01:05 PM
What would you consider an adventure trip in your FRS/BRZ? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 47 04-07-2013 06:54 PM
