Old 05-12-2023, 10:04 AM   #15
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
What a timely thread I was just about to get advice on SS2 vs tarmac 2 with 949racing topmounts. I would love something like the Xida but price is a bit too much for my use case.
I would be very interested in this option depending on cost and time frame.
autoracer86 is offline   Reply With Quote
Old 05-12-2023, 11:33 AM   #16
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Originally Posted by ___LUNK View Post
How different would these perform to xidas with the same spring rates? Say 250lb on both or if you put 400lb springs on xidas and adjusted the knob to match?
Tecnas will have about 60% of the total damping range of Xidas. So on the softer settings you wouldn't notice much difference. But if you're running say 255 super200's, 4" splitter and a huge wing out back and are needing the stiffer damping range, Xidas would offer better performance.
Originally Posted by dragoontwo View Post
What might your target camber for the chips look like?
TBD. Possibly the same -6° Xida eccentrics are capable of, maybe a bit less.
949 Racing is offline   Reply With Quote
The Following User Says Thank You to 949 Racing For This Useful Post:
dragoontwo (05-12-2023)
Old 05-12-2023, 01:47 PM   #17
TurboLag23
TurboLag23's Avatar
Drives: 2018 BRZ w/Performance Package
Very interested! Absolutely loving my CSG Teins so far, but always keeping an eye out for other options. Monotube, inverted strut, and helper spring is very alluring, and a market differentiator at this price point.
Will these be designed around a certain swaybar combination or targeted alignment specs, either in Touring or Sport spring rates? If I recall, the CSG Teins were designed around stock front/rear sway bars (this is what I'm running right now).
TurboLag23 is offline   Reply With Quote
Old 05-12-2023, 02:58 PM   #18
949 Racing
949 Racing's Avatar
Blub, our project car set lap records at every track it visited and ran just a 22mm Perrin front and OEM rear on 265/18's. We found that better shocks, more camber and balanced aero obviated huge sway bars. Short answer, we never recommend a larger rear bar on any 86 anyway, 22mm for most, possibly 24mm for Hoosiers and big downforce. For smaller tires and no downforce, still the same bars or maybe 20mm front.
Code Monkey (05-12-2023)
Old 05-18-2023, 11:09 PM   #19
Xed32
Drives: '22 brz Sport-Tech
*starts saving*. 6 to 12 months. Check. Don't forget the "Canada salt" package please.
Xed32 is offline   Reply With Quote
Old 05-19-2023, 08:00 AM   #20
Ohio Enthusiast
Drives: 2018 BRZ
Good call - will these be streetable through winter and salt without concern?
Old 05-19-2023, 10:46 AM   #21
949 Racing
949 Racing's Avatar
As durable as any other high quality coilover on the market. Salt destroys everything it touches. One key feature that separates our Xidas from the rest is that they have standard rubberized nylon shock covers. We found they protect the shocks much better than the traditional rubber boot inside of the spring. Tecnas will have these too.
Here is a pic of one of our Miata Xida kits with included covers.
The Following 3 Users Say Thank You to 949 Racing For This Useful Post:
Ohio Enthusiast (05-19-2023), turbofan (06-13-2023), Xed32 (05-20-2023)
Old 05-19-2023, 07:23 PM   #22
new2subaru
Weight Weenie
Drives: 15 FR-S
Is there any reason you wouldn't change back to the stock suspension for the winter months?
Old 05-19-2023, 07:33 PM   #23
Ohio Enthusiast
Drives: 2018 BRZ
Being lazy and having enough nice days during winter that driving on stock suspension would be a bummer. For folks that have months on end of snow/slush/salt it might make more sense
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Xed32 (06-10-2023)
Old 05-19-2023, 07:35 PM   #24
new2subaru
Weight Weenie
Drives: 15 FR-S
Ah, I assumed you were going to be plowing through salt and snow daily. If that were the case I switch them out when doing snow tires.
The Following User Says Thank You to new2subaru For This Useful Post:
Old 06-09-2023, 09:42 PM   #25
bokehmon
Drives: 2014 DMG BRZ
Specifically engineered coilovers for our platform that'll be nice for the street? Sign me up! I miss being able to carry drinks in the cupholders without spilling.
The BRZ is quickly becoming the daily/occasional track car rather than a dedicated track car, and the monosports aren't the best of compromises. (also, i've tried 3 different sets of endlinks, and they ALL hit the chassis or shock body as soon as I go under -3* camber.
bokehmon is offline   Reply With Quote
Old 06-10-2023, 12:01 PM   #26
949 Racing
949 Racing's Avatar
I think probably 25% of the development time with Xidas was getting the front end links dialed in. Proprietary turnbuckles, brackets and casing offset. All of that geometry will be replicated for Tecna.
We had talked to owners of a few other high-end 86 coilovers and a recurring theme was horror stories about the complete lack of engineering for the end links with high camber settings.
The Following 4 Users Say Thank You to 949 Racing For This Useful Post:
jflogerzi (06-11-2023), RedReplicant (06-11-2023), villainous_frx (06-13-2023), Xed32 (06-10-2023)
Old 06-11-2023, 08:00 PM   #27
jflogerzi
jflogerzi's Avatar
I can attest front end links are a pita with this platform
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 06-12-2023, 05:51 AM   #28
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by turbofan View Post
but a twin tube non-inverted damper. This affects stiffness and durability of the shock. All properly designed high-end aftermarket struts have an inverted damper
I'm thinking Ohlins might want a word with you.
tecna
BC Racing Coilovers, Tax Season Specials! WE stock BC Racing @OAKOS! OAKOS Automotive Brakes, Suspension, Chassis 162 04-17-2017 03:14 PM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 02:15 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
