#5923 | |
Drives: 2013 Scion FR-S 6M Argento
boost alone isnt what blows your motor. its the amount of power, specifically torque, that does that. you could run two turbos or superchargers of different sizes and they will flow vastly different amounts of air at the same amount of boost. you could also put something in your intake path, which would raise the amount of boost but lower the airflow and thus power that you make and your engine wouldnt care. |
#5924 |
Drives: brz 2017 hksv2
if you put something in the intake path, boost and airflow both drop. I.e. the hks supercharger restrictor of 39mm which limits boost to around 0.6, or 43 which then arrives easy to 0.75bar
i agree that too much torque at low rpm will kill rods to the point of snapping (been there) but also 1bar at high rpm can surely contribute to slowly bend rods I saw csg mike claiking up to 360/380WHP with c38 and high boost pulley, with stock internals and e85.. don t you think the ignition timing used to produce the necessary torque to reach those Whp can't create very high internal pressure inside the combustion chamber? it surely does what helps is the e85, because with normal pump petrol there will always some moment where a knock can occur at high rpm high boost and in that moment the pressure inside the cylinder is extreme but also without knocking using only e85, how many people blew the engine anyway even with good reputable tuner? many |
#5925 |
My apologies, I meant between the compressor and the engine regarding having something in the intake path. The HKS restrictor is pre compressor.
#5926 | |
Drives: 2017 BRZ w/PP
Sorry to jump back but even at 8k the most i saw in my logs were 1.95bar absolute. Do I have a boost leak? |
#5927 |
you also reach 8000 rpm with stock internal stock valve springs?
anyway i dont know if you have a leak, boost depends a lot to intake temperature and are you at altitude or sea level? Do you have a log of a pull of your car? |
#5928 | |
If i m not wrong Cosworth did engine dyno test and they stated that anything over 0.65bar of boost and 280-300hp to the crank (250Whp or less) is unsafe.. that 's conservative for sure but here in Europe you don t get e85 in many countries |
#5929 | |
I'm fully built. I'm sure I have logs somewhere from when I got Zach to tune it. Honestly even being built I'm not a huge fan of going that deep into the rpms but it is nice to have if needed. I'm not a good enough of a driver for it to matter I just found it interesting. |
#5930 | |
#5931 | |
https://datazap.me/u/tommbrz/v6-0?lo...-34-38&solo=38 Here the boost a high boost pulley C38 can reach when it s pretty cold outside Mind it's not the RS pulley |
#5932 | |
I have since put vents on my hood due to iat but i checked my last log and it starts the pull at 31c and ends at 44.8c. Pretty sure that would do it |
#5933 |
yep, in that log i provided iat is much much lower, therefore the higher boost
big intercooler apparently works good |
#5934 | |
Drives: Subaru BRZ
#5935 |
that doesnt make sense
the more boost you have, the less the fuel resists 95 ron is so bad that over 0.8 bar the ecu corrects for knock by default all the time basically, ignition timing are so low that the car is just slow and the boost would keep overheating the charge and then it knocks even more there is a point of deminishing return with boost and shitty fuel...in the same car, less boost and more ignition timing can give more power if the fuel can't stand the pressure and heat |
#5936 | |
Drives: 2020 GT86 Hakone
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
