| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#15 | |
Drives: 2023 brz limited 6mt red
I did a 200 mile romp up in the mountains allot of 2-3rd gear most of the time tight technical stuff. Then the rest of the tank 75-80mph on highway. Still netted a 25.5mpg I was shocked and impressed. Hand calculated of course.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
#16 |
Drives: 2022 BRZ Limited WR Blue MT
Flat at basically at sea level. 60mph will get 30mpg. 70mph will be 25-26mpg. 80mph will be 22-23. 22BRZ 6sp Limited. Calculated BTW. It drops fast with higher RPM.
| The Following User Says Thank You to H380 For This Useful Post: | Dzmitry (05-18-2023) |
#17 |
That seems a little on the low side. I haven’t taken a long distance trip yet my daily drive to work going 75-80mph 90% of it hwy. I’m at 26mpg and that’s not feather footing it nor fast and furious down shifts. The first 2000 miles on the car off it was a tad less. I’m 350ft above sea level.
#18 | |
Drives: '23 BRZ Limited
285 miles + 10.4 gallons = 27.4 mpg. The only thing I can think of is that turning higher RPMs puts the motor in a happy spot in 6th gear so even though you're turning more RPMs the engine isn't working as hard to maintain speed. EDIT: And now that I think about it, at those speeds, there may also be a marginal draft effect from the cars/semi's as well.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | vindiesel (05-18-2023) |
#19 | |
Drives: 22 BRZ
| The Following 3 Users Say Thank You to AK2112 For This Useful Post: |
#20 |
Drives: '23 BRZ
#21 |
Drives: '23 BRZ
In the '17 PP, I see "10 miles" and at a glance I know I can go 10 miles plus safely another 15 with margin (have gone +20 but pushing it at that point!).
With the NEW car, I see "10 miles" and it could mean that I have 19 miles plus reserve, or it could mean only 10 miles plus reserve. That's a HUGE difference when trying to strategize where to stop for gas! Also, where the old car would tick down from 10 miles to 9 (then on down to 1), the new one just goes from "10" to "--", no more info! Added to that we have the change from super-hi-res fuel gauge to super-lo-res. Maddening! In practice, it means that the formerly useful Range/DTE number is almost no use at all, and I have to keep glancing down to catch when when the fuel gauge goes from 1 chunktastic 8-bit block to zero. Then I can set a trip meter to count up. Traveling from Pawtucket RI to Laurel MS over the past few days, on the last tankful I went +24 miles past the point where the Range/DTE clicked from "10 miles" to "--". This was +15 miles after the last fuel gauge block went off. Then filled filled the tank with 12.06 gallons. 13-gallon tank, so theoretically there was still another ~28 or so miles in there! No intentions of going that far, although I did have a 12.9 gallon fill in the old car once or twice... |
#22 |
Z Dan based off your fuel to empty issue and volume screen popping up issue thread… what have you owned before that lead you to be this sensitive? I’m curious.
| The Following User Says Thank You to vindiesel For This Useful Post: | Jdmjunkie (05-21-2023) |
#23 | |
Drives: '23 BRZ
Just dumb little stuff... Posting here because this is presumably the forum for it. Also on the off-chance there's a way to *fix* these things... Also, it is fun to complain. |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | DriveDriftDogfight86 (03-25-2024), vindiesel (05-21-2023) |
| Camber plate increments. | gen3v8 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 05-19-2022 10:28 PM |
| The return of Aptera? 1000 Mile Range Solar Vehicle | spcmafia | Other Vehicles & General Automotive Discussions | 7 | 02-10-2022 09:21 PM |
| BMW iX coming in 2022 with 500 horsepower and 300-mile range | vh_supra26 | Other Vehicles & General Automotive Discussions | 14 | 11-13-2020 12:05 PM |
| Fuel light range | pushrod | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 09-04-2014 02:20 PM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 08:19 PM |
