Old 05-15-2023, 04:49 PM   #29
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
If you are going to get toe arms just get the SPC's. They are almost half price of the SPL's and do the job just fine.
Thanks for the suggestion. They look a lot like what superpro and whiteline make.
My main reason for wanting to switch was to deal with the eccentric bolt possibly slipping. After some more research and chatting with friends it seems that the stock eccentric bolt setup is fine. So I really have no need for toe arms.
autoracer86 is offline   Reply With Quote
Old 05-15-2023, 05:24 PM   #30
dreamwonder
Drives: GR86 2022
There is a 30mm-ish difference in height on the endlink mounting point of the KWs compare to factory strut, hence why a shorter endlink is desired (if factory endlink is used, it will hit the lower control arm), of all the after market links I tried they have clearance issue for running high camber (say -3.5ish or more). They bind on the lower body of the shock or against the side wall. Oem-styled (non adjustable) endlinks tends to be more form fitting. I don't corner weight balance and set my coilovers the exact height side to side so pre-load is negligible, the rubber bushings in the suspension is good enough for me.
Something like a JRZ where it retains the same endlink mounting location can use the factory endlink just fine.
dreamwonder is offline   Reply With Quote
The Following 2 Users Say Thank You to dreamwonder For This Useful Post:
autoracer86 (05-15-2023), ZDan (05-15-2023)
Old 05-15-2023, 06:57 PM   #31
autoracer86
Drives: Toyota GT86
Yeah I see there is a lot of information out there on what end links to use depending on the sway bar you run with the KWs
I just went with KLC179 which is 225-250mm in length. Seems to match the OEM endlink at max height. I plan to run the OEM bar so I think these should work. We shall find out lol
Old 05-15-2023, 07:25 PM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
Is this true for the RCE Supersport-2? So perhaps my plan to run factory endlinks might not work...
Yeah, that's the route I'd want to go for max clearance for max camber...
Old 05-15-2023, 07:40 PM   #33
ZDan
ZDan's Avatar
Drives: '23 BRZ
Just got feedback from RCE that '23 endlinks will work fine with Superstreet-2 coilovers.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
autoracer86 (05-15-2023), Racecomp Engineering (05-16-2023)
Old 05-15-2023, 07:44 PM   #34
autoracer86
Drives: Toyota GT86
I might just have to ask them myself but do you have any idea if the GR86 end links are different to the GT86 endlinks ?
Old 05-15-2023, 07:48 PM   #35
ZDan
ZDan's Avatar
Drives: '23 BRZ
I do not know...
Old 05-16-2023, 09:09 AM   #36
Front endlinks are the same for 1st and 2nd gen.
I used OEM on my own 1st gen with SS1s. We've also used Whiteline, SPL, and a custom set I made for myself.
Clearance is tight no matter what, so keep an eye on it! There are a couple of variables that make things different car to car (ride height, camber at the hub, camber from the top mount).
- Andrew
ZDan (05-16-2023)
Old 05-16-2023, 09:57 AM   #37
autoracer86
Drives: Toyota GT86
- Andrew
Thanks for updating the thread. Whiteline makes a few different sizes but I feel confident the ones I got will work especially if OEM does.
Thanks again
BUYING PARTS JoeyMarch Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2015 03:05 PM
What should I know when buying new suspension? WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-30-2014 10:09 AM
buying used parts dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 2 07-18-2014 07:27 AM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
Buying Parts brzzz Scion FR-S / Toyota 86 GT86 General Forum 3 10-04-2012 12:15 AM
