Old 05-15-2023, 11:10 AM   #15
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
With our coilovers and KWs, we often use another set of the factory lower bolt in the upper hole...so 2 sets of the lower bolt per side. This helps you get about -2.2 degrees even on stock topmounts, so with camber plates in addition to that it's not difficult to get -3.5.
- Andrew
Thank you for posting... I was a bit curious if the -3.5 value needed anything bolt wise.
Is using the lower bolt in the upper hole the same as "crash bolts" I have not done any research on these things because I was planning on leaving all the bolts OEM and using camber plates.
If I was to keep everything as is bolt wise do you think I could still hit -.3 with the SS2 camber plates.
autoracer86 is offline   Reply With Quote
Old 05-15-2023, 11:28 AM   #16
Yeah that's also referred to as the OEM crash bolt (the crash bolt is just the same part as the lower bolt). It's secure and works well.
All stock yes you can hit -3 degrees.
- Andrew
Old 05-15-2023, 12:37 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ah, just ordered up a pair of the lower bolts for my upcoming install, had forgotten about that! Prefer to maximize negative camber with those to have max range of adjustability up top. Hoping for -3.5...
Old 05-15-2023, 12:39 PM   #18
Yes me too...should have mentioned that it's arguably better to get more of your camber from the lower mount.
- andrew
Old 05-15-2023, 01:05 PM   #19
dreamwonder
Drives: GR86 2022
Double post.
dreamwonder is offline   Reply With Quote
Old 05-15-2023, 01:08 PM   #20
dreamwonder
Drives: GR86 2022
Datapoint, with the kw variants (with kw tophats), I was able to get 4.1 on the passenger side and only 3.5 on the driver side, had to use a spc camber bolt on the lower hole as well to get it to 4.2. When maxing out the top slotted hole check if the solder is in the way, on some of mine, I had to Dremel some off for the bolt to sit clean.
PM me if you want to use oem endlinks that is of proper length and clears the coilovers bottom as well as side wall. These 2 issues usually feel like power steering is lost when binding happens on turn 7 at the glen.
Old 05-15-2023, 03:06 PM   #21
autoracer86
Drives: Toyota GT86
Speaking of end links I ordered whiteline ones today. Whiteline UK were running a sale so I pulled the trigger.
Old 05-15-2023, 03:23 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks, will see how it goes. Planning to use the '23 factory links. Worked on the '17, with some rubbage of the inner wheelwell, more so in parking maneuvers than at the track.
Old 05-15-2023, 03:25 PM   #23
autoracer86
Drives: Toyota GT86
What is the reason behind sticking with stock end links ? It is just to save money
Old 05-15-2023, 03:41 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
To flip this question over, what is the reason to use aftermarket end links, is it just to spend more money?
I tend to take a minimalist approach, if the factory stuff works fine, I use it.
Old 05-15-2023, 04:02 PM   #25
autoracer86
Drives: Toyota GT86
Remove preload off the swaybar and if you run a aftermarket bar its easier to make adjustments as removing the stock end links can be a pain.
Old 05-15-2023, 04:13 PM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
I observed "preload" to be pretty much nil when I installed Eibachs on the '17. some of the factory links were pretty rusted on tho... Installed Eibachs set soft front stiff rear and still had understeer so no need to adjust...
Old 05-15-2023, 04:20 PM   #27
autoracer86
Drives: Toyota GT86
Well for under 300 bucks for a set of end links I am not going to complain if the benefit is small. I already saved a bunch not getting the toe arms/LCAs but I get the feeling I will get the LCAs at some stage. We will see how the alignment goes.
Old 05-15-2023, 04:34 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are going to get toe arms just get the SPC's. They are almost half price of the SPL's and do the job just fine.
BUYING PARTS JoeyMarch Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2015 03:05 PM
What should I know when buying new suspension? WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-30-2014 10:09 AM
buying used parts dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 2 07-18-2014 07:27 AM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
Buying Parts brzzz Scion FR-S / Toyota 86 GT86 General Forum 3 10-04-2012 12:15 AM
