Old 08-02-2012, 11:52 PM   #15
OrbitalEllipses
Drives: Attitude
Dude, just open the door and jump on the door sill repeatedly.
Actually, strut clearance could change with tire deformation under cornering with compression, no?
Old 08-03-2012, 12:23 AM   #16
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Bias ply tires will, but not radials. These tires especially not as they actually have steel inserts in the sidewalls.
Old 08-03-2012, 01:00 AM   #17
OrbitalEllipses
Drives: Attitude
The more you know.
Old 08-03-2012, 02:05 PM   #18
Draco-REX
Corner Junkie
Draco-REX's Avatar
A couple more cell pics while I'm at work:
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
charged86 (06-27-2013), Spaceywilly (08-03-2012), Surok (09-21-2012)
Old 08-03-2012, 03:01 PM   #19
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Those wheels are awesome and perfect size. I might have to reconsider these.
Old 08-03-2012, 03:19 PM   #20
Draco-REX
Corner Junkie
Draco-REX's Avatar
Just gotta do something about that fender gap..
Help me RaceComp Engineering!
The Following User Says Thank You to Draco-REX For This Useful Post:
stevo_12v (08-10-2012)
Old 08-03-2012, 03:49 PM   #21
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
So torn between these and the OZ Ultraleggeras in 17x8 - these are 2 pounds lighter but almost 600$ more for the set. More pictures are needed.
Khyron686 is offline   Reply With Quote
Old 08-03-2012, 03:59 PM   #22
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Fitment looks excellent man! Coils will make it look amazing. Great job!!
Jeff86 is offline   Reply With Quote
The Following User Says Thank You to Jeff86 For This Useful Post:
Delacruzmd (08-03-2012)
Old 08-03-2012, 06:53 PM   #23
Draco-REX
Corner Junkie
Draco-REX's Avatar
I am really liking these wheels. If only I could do hubcentric rings and center caps at the same time.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
DanMac (08-28-2012), Fly Guy (08-06-2012)
Old 08-03-2012, 06:54 PM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
Aaaaaand.... needs more low.
Old 08-03-2012, 07:56 PM   #25
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Looks great. It's a bit hard to tell...do the fronts poke a little? The +42 looks pretty perfect on the 8" wheel.
Ok for a wheel newb can you explain the need for hub centric rings...and can you not use both rings and center caps?
Phaedrus29 is offline   Reply With Quote
Old 08-03-2012, 08:43 PM   #26
Draco-REX
Corner Junkie
Draco-REX's Avatar
The fronts don't poke, the fender overhangs the tire by a very small amount.
Hubcentric rings fit between the wheel and a raised lip around the center of the hub. Using a hubcentric wheel or rings directs forces acting on the wheel to be transferred directly to the hub rather than the lugs. It a stronger way to mount the wheel than just the lugs.
As for using rings and caps together, normally you can. But from what I understand, these particular wheels are milled in such a way that it is one or the other, but not both.
Old 08-10-2012, 04:50 AM   #27
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
DAMNNN!! Nice choice of wheel.. lightweight and GOOD LOOKS.
Here is a guy who has great taste!!
If your after hubcentric rings and caps check out perfectrun.jp
They also carry the AL-type allow racing nuts too(each nut weighs the same as a AA battery)
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
bazi (09-02-2012), Duo (08-26-2012)
Old 08-10-2012, 08:23 AM   #28
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
+1. Otherwise looks amazing. LOVE the wheels & LOVE black BRZ's
No Limit Motorsport is offline   Reply With Quote
Wheel Directory: SSR Competition 17x8.0 +38 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 08-07-2015 06:38 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 07:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
Pre Order TC105N vividracing Wheels and Tires 27 07-30-2012 03:28 AM
