Old 08-03-2012, 01:03 PM   #15
white86
Drives: Whiteout FRS
Yea it's bad pillowball. But I can't figure out how to back out the top but because there is no Allen key slot up top to stop the shaft from spinning and hitting it with a gun isn't working because there's a nylon lock ring on the 19mm nut. Any ideas on how to stop the shaft from spinning? There's no flat spots in the shaft for an open end or anything
white86 is offline   Reply With Quote
The Following User Says Thank You to white86 For This Useful Post:
Panman (04-09-2014)
Old 08-03-2012, 01:15 PM   #16
Racecomp Engineering
Use a strap wrench.
Old 08-03-2012, 04:27 PM   #17
Norcalscionchamp
Norcalscionchamp's Avatar
Drives: Whiteout 6MT Scion FR-S
hmm interesting
Norcalscionchamp is offline   Reply With Quote
Old 08-03-2012, 04:38 PM   #18
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
which shaft was it that you used an impact gun on? :/
Old 08-03-2012, 05:02 PM   #19
white86
The top nut. It spins the whole piston assembly shaft
Old 08-03-2012, 07:33 PM   #20
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
never, ever, use an impact gun on the SHAFT, tighten the shaft nut by hand tools only. If you can't do it while it's on the car, take it off the car, if you can't do it while it's off the car, that means you don't have the right tools.
otherwise you risk unbolting the shaft inside the body (as told to me by a Koni rep)
Old 08-04-2012, 01:33 AM   #21
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
It's a pleasure to read a post that isn't filled with Vitriolic Crap being thrown at manufacturers but has voices of reason and sensibility. My faith in this website may be restored yet.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 01-18-2013, 04:13 PM   #22
NemeGuero
How did you determine the pillow ball was bad?
Did the manufacturer send you replacements?
NemeGuero is offline   Reply With Quote
Old 01-18-2013, 05:01 PM   #23
Z3D
There is something called soft jaws that aid in the gripping of the shaft for proper removal of the top nut.
Z3D is offline   Reply With Quote
Old 04-16-2013, 07:19 PM   #24
white86
So I thought I would update this thread. I have recently changed my suspension set up to air lift. But the problem persists. Has nothing to do with ride height because it clunks at any height. The clunking is less noticeable on air because of the lack of a spring or less solid objects to transfer the noise into the trunk/cabin. Anyways long story short: new suspension, same problem. Any ideas. I'm about to take it to Toyota and have them look at it because it sounds like the whole rear subframe is loose.
Sh944 (06-27-2014)
Old 04-16-2013, 09:03 PM   #25
NemeGuero
I too believe its my subframe. I can replicate the noise by rocking the car forwards and backwards. Its really difficult to pin point the source though.
But there is some grease on one of the mounting points of my subframe as well as it looks like my diff was opened before I picked it up. Its hard to say that toyota will do anything because the noise isn't there with stock suspension.
Might try some solid subframe spacers? MAX is coming out with them soon.
Old 04-16-2013, 09:13 PM   #26
white86
Are you replicating it with the parking break on? Because that noise is probably the drum parking break slack rocking back and forth. I've never been able to replicate the noise sitting in the driveway. I've tried bouncing the car by jumping in the trunk. It's like it has to be moving which makes me think its a axle noise or maybe the bumps are just knocking the wheel backwards towards the rear of the car a little bit as well as up to make the noise. My dealership has a smart staff and a nice service department to take it to but I fear that it won't fall under warranty and that it's gonna end up costing me 3+hrs at 80$hr rate to diagnose...I have every tool under the sun just no lift or rack to really diagnose the problem and like I said I can't replicate it not driving.
I had the idea of mounting my gopro under the car and trying to get a video that might give me a better idea of the problem. Maybe ill do that now it's warm
Old 04-16-2013, 09:18 PM   #27
white86
And if anyone knows the torque specs for the subframe bolts let me know ill check to see if mine are tight
Old 04-16-2013, 09:38 PM   #28
Scott
Drives: 1971 Datsun 510
Not sure if this was mentioned before but I had a similar clunking in the front (sounded just like yours)and it turned out to be the sway bar end links with the aftermarket kit. Very minute movement but resulted in enormous amount of noise through the chassis. Worth a try!
Scott.
Scott is offline   Reply With Quote
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 06:49 PM
DG-5 Coilover harajukukei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-27-2014 04:42 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 01:10 AM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 12:43 PM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 08:08 PM
