Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-07-2013, 03:24 PM | #71 |
05-07-2013, 03:24 PM | #72 | |
Drives: Some rust bucket
I'll be scheduling an alignment soon. |
05-07-2013, 03:27 PM | #73 |
One thing that Mike mentioned last night was when the oversteer occured. Was there oversteering during a static turn? I didn't really pay attention to that since autox courses generally don't have long sweepers. I'll try to pay more attention next time and see when the oversteer actually occurs.
Edit: I remember there were some short sweepers. If I remember correctly, I didn't have any major oversteer problems during those. It felt pretty neutral. The car broke during quick transitions. It was probably because of my jerky steering inputs, idk. |
05-07-2013, 04:11 PM | #74 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
05-07-2013, 05:09 PM | #75 |
Pick up a camera and a suction mount. Post it up, much of it could be how you are driving. You have anyone close to you to go to an event that has any experience?
Get an alignment soon, camber changes will effect toe. You may have some wacky toe out in back which could cause the snapping oversteer you mentioned.
The Following User Says Thank You to Dezoris For This Useful Post: | 86socal (12-28-2016) |
05-05-2023, 11:56 PM | #76 |
Drives: 2015 Subaru BRZ
We had some big names in this thread. Exactly 10 years later I come to revive it.
Second season racing the 2015 Subaru BRZ on Hoosier R7 and Maxxis RC1. Current Setup: 2,650 lb MCW (Ratio: ~55F/45R). 9LR Wing. MCS 2W-NR. 550F / 600R. Front 22mm WL ARB (soft setting) / Rear 16mm WL ARB Notes from my 2022 NASA TT season: • Notable understeer characteristics at all speeds. • Steering feels precise and sharp. • Confidence inspiring grip but need to resolve understeer state Soon to test: (To combat understeer & maintain steering feedback) • 450F / 550R with same bars • 550F / 600R with softer front bar • 450F / 600R with OEM 14mm rear bar (I have a formula I use to calculate my components motion ratio's and it seems to work well for the setup.)
"The vision manifests the reality." NASA TT5 Silver 2015 Subaru BRZ Limited
05-07-2023, 11:37 AM | #77 |
One thing that's changed in the last 10 years is that a LOT more people are running big wings. Street tires are also a lot better. Also I had more hair. But I did lose some weight!
Is your understeer on entry, exit, steady state? All of the above? How much camber? - Andrew |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | NoHaveMSG (05-07-2023), whataboutbob (05-07-2023) |
05-07-2023, 04:30 PM | #78 |
Drives: None
Also, what is your ride height front and rear? I'm at the opposite end as you are, the car has all the front grip in the world and not enough rear from time of on throttle through exit. I've got a few things to try on my side.
On your list there the last one is probably what I'd be trying, or 500/600 with stock 14mm. Obviously there is a power and weight difference between the two of our cars, but given we're 5 taking the same modifiers it should pretty much even out. I am currently: 2871 MCW w/ 53/47 split 4" flat splitter, vents, Verus HE wing 400/600 Shaftworks 1way with 22mm Perrin on medium / stock 14mm -4.5 / whatever stock rear camber ended up with at 22.5" front and rear bottom of 17" wheel to fender 17x9.5 255 RC1 I have a Mann Engineering rear bar on the car now, but I haven't tested it yet. Gut feeling tells me to go up a bit front rate wise but I am probably buying Xidas next week now that I know they're no points in 5.
05-08-2023, 09:49 AM | #79 |
Drives: BRZ, Miatas and a Land Cruiser
Another "TT5" car here, and it was absolutely peachy perfect at Mid O last month. Literally nothing I want to change. I'll be rolling it right into SCCA STX this weekend as it sits with just a fuel change and passenger/rear seat reinstallation.
949 Racing Xida 500/500lb Whiteline 22mm front, full stiff Mann Engineering rear, middle no 'real' aero, taking NASA penalties for OEM STI/Limited trim lip/spoiler -5.2 front, -2.8 rear, smidge of rake, smidge of rear toe-in. Ride height is up a bit, but not measured recently, just to get it off the front bumpstops and retain the rake it had. 17x9 245/40/17 71RS/AO52
05-08-2023, 10:23 AM | #80 |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Another ST/TT5 car here.
2770lbs 550lbs/600lb (f/r) Stock OEM bar f and 2017 OEM rear APR f splitter and GT250 flat pane rear wing. -3.0 front, -2.2 rear, rake is almost even. Front all way down on MCS 2WNR shocks. Rear matched for corner balance. 17 by 9 ET45 with 225 R7. Car is fairly neutral and the vehicle characteristic changed a lot since I installed the rear OSG LSD. Prior to that, I had 550/650 spring setup and it worked extremely well on the car. Upon installing the LSD, the rear became handful until I reduced the rear rates. Played with shocks/heights, car was a handful. This year installed the rear control arm and dialed out the rear camber to -2.6 and the difference was noticable. Car hooks up much better at exits (rear) but the front needs more bite now. Will report back after getting the fronts sorted (wanted to tweak/test one axle at a time than both with new rules allowing for more camber adjustability).
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
05-08-2023, 10:25 AM | #81 |
Drives: 2022 BRZ; 2014 BRZ
STR car chiming in. I haven't touched any of the knobs since the car feels amazing as is. I bought the "package" from a friend after he sold the car and used the same setup since I knew it worked well. I should record the positions of the knobs in case anything gets messed up. I've considered trying out softer springs to try and improve the ride on the street since it's still my main car.
JRi 2-ways 450F/600R Whiteline 22mm front bar, full stiff Stock rear (I have a Perrin 16mm rear, but haven't found that the car needs it) Alignment is -4* front and -2.2* rear. 0 toe in front and a little in on the rear 17x9 245/45-17 Yoks
05-08-2023, 08:30 PM | #82 |
FNG
Drives: 2013 Subaru BRZ
I just moved my car to XA because I added Flex Fuel. I also added Shaftworks USA coilovers with 6K/9K Swift springs with Whiteline RLCAs (new model) and Whiteline rear toe links. I've only got to do a Test and Tune but the car feels a lot better now than when I ran Feals with 6K/7K springs.
We have an event coming this Sunday and I am doing HPDE and Time Trial this year so we'll see. I also have front camber set to -4 and rear to -3 so that may be another part that's help a lot too. |
05-16-2023, 08:08 AM | #83 |
Drives: '23 BRZ
I still can't wrap my head around why anyone would want the same spring rates front/rear, or worse *stiffer fronts* given motion ratios of ~0.95 front and ~0.75 rear. About to install RCE Supersport-2 coilovers (7 kg/mm front and rear) on the new '23 BRZ and not at all enthusiastic about ~6.3 kg/mm front with 3.9 kg/mm rear spring rates, considering swapping in 5 kg/mm springs up front which would give ~4.5F/3.9R wheel rates.
Anyway, spent the last 5 years running '17 PP street/time-trials car, final/fastest setup: ~2900 lb. with fuel and driver, 53.5F/46.5R 4.4F/5.3R springs (Swift Spec-R), Bilstein B8 Just under 13" hub to fender lip front/rear (-1.5" vs. stock?) Eibach sway bars, front soft, rear stiff (~150% or 2.5x stiffer than stock front and rear) -3.5F/-2.8R camber, zero toe all around 245 RE71RS last year, 245 and/or 235 year before This setup had highly annoying midcorner push, hoping to avoid that in the new '23 with RCE SS-2 coilovers... |
05-16-2023, 04:56 PM | #84 |
Drives: '13 FRS - STX
I think the equal/softer rear main spring comes from a few ideas that some people seem to stick to real hard - zero toe, positive rake, bump stops that basically make the main spring useless, bound up or overly stiff swaybars, weird damping, ride heights. There’s too many variables to really nail down a “perfect” setup or say X/Y is the right combo, for better or worse I find this car to be really spring insensitive, especially if you’re dealing with a particular problem such as alignment issues or a compromise setup like a damper that’s inadequate or set wrong. For instance I’ve tried 325#/425#/500# in pretty much every combo, even 500F/325R, a degree of camber has had a bigger impact on balance then going +/-100# on the spring rate did.
Edit: also with a soft rear vs a stiff one I could see better driver confidence with a rear end that moves vs one that doesn’t move and you have to have a better feel for the tire slip angle as well as anticipate any track bumps/irregularities. |
Similar Threads | ||||
Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 02:56 PM |
Finance Rates on the FR-S? | mickey177 | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 05-10-2012 01:18 AM |
Rates are out !!! | FR | CANADA | 24 | 05-04-2012 04:15 AM |
Finance Rates | Enemies | CANADA | 16 | 05-02-2012 07:01 PM |
Weird GT 86 factory spring rates in GT5? | Spec-Al | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 36 | 03-27-2012 02:30 PM |
