Old 05-07-2023, 02:42 AM   #155
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I've had a look on MCA's website but I can't see a corresponding mod for the front.
Old 05-07-2023, 12:20 PM   #156
pope
has a funny hat
Drives: 2014 BRZ Limited
The equivalent for the front would be a reduction in anti-dive and I can’t think of any good reason people would want to decrease traction under braking.
Of course I don’t quite see the point of decreasing traction under power in the rear either.
pope is offline   Reply With Quote
Old 05-07-2023, 05:37 PM   #157
Captain Snooze
Drives: Red Herring
Mmmm... seems like someone took my post seriously.
Old 05-07-2023, 06:12 PM   #158
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ummm, the MCA traction mod does the opposite of what you are describing. It reduces rear anti-squat.
Old 05-07-2023, 07:23 PM   #159
Ohio Enthusiast
Drives: 2018 BRZ
It's the other way around - anti- geometry limits weight transfer, hence typically hurts traction on acceleration (anti-squat) and braking (anti-dive) (same as too much anti-roll bars can hurt cornering). MCA reduces anti-squat in the rear and there are a few kits that reduce anti-dive in the front.
Old 05-07-2023, 09:17 PM   #160
pope
has a funny hat
Anti-squat forces the tires down and the body up increasing pressure on the contact patch. Reducing anti-squat, especially if it goes negative, lifts the tires into the body, reducing pressure on the contact patch.
It’s like any aspect of suspension geometry, it’s all trade offs, but independent rears don’t typically have much positive anti-squat and these cars aren’t exactly known for making large amounts of torque where positive anti-squat would result in rigid, non-compliant suspension, so I don’t get it.
I mean I suppose I get it for rough roads or LS swapped cars…
Old 05-07-2023, 09:37 PM   #161
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Unfortunately our parts bin car has too much anti squat since our rear suspension is basically from the Impreza . That’s what this solves and nobody that has run it has ever said it did not improve traction on their car.
Old 06-13-2023, 10:28 PM   #162
whataboutbob
AutoX-10/10ths every run
First autox in 5 years.
Changes since last autox:
MCA traction mod.
Stock powertrain with no tune.
5 year old "new" RC-1s.
New Karcepts front bar on 2nd from softest.
New-ish Essex BBK with new-ish Winmax W3s.
WPC'd Cusco FD.
Nearly ALL the Cusco chassis bracing.
Runs were a hoot, only had to lift to brake late in the corners.
OMG I can brake late. :P
Sweepers were a mild lift on turn in and then on throttle early through corner exit with settled rear end and tons of grip.
Car did not step out, except when induced.
Car would rotate on throttle when desired.
Still 10/10, would do MCA traction mod again.
https://forums.solo2.com/live_results/
Build thread:Here
Old 06-16-2023, 07:51 AM   #163
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Does anyone know if they still make these ? Shows sold out on the site for both black and red
autoracer86 is offline   Reply With Quote
Old 06-16-2023, 10:01 AM   #164
whataboutbob
https://www.carmodsaustralia.com.au/...ion-Mod-BRZ/86
Build thread:Here
Old 06-16-2023, 10:08 AM   #165
autoracer86
Drives: Toyota GT86
Originally Posted by whataboutbob View Post
Nice thanks for sharing. Best to make sure they have them in stock before ordering I would say.
This is their official site for anyone looking
https://mcasuspension.com/traction-m...yota-gt86-brz/
Old 06-16-2023, 10:15 AM   #166
Racecomp Engineering
BTW I got mine from Fensport in the UK which is a bit closer to you...
Out of stock there though.
- Andrew
Old 06-16-2023, 10:25 AM   #167
whataboutbob
- Andrew
I got mine there as well, but it was about 2+ years ago.
Build thread:Here
Old 08-13-2023, 12:08 PM   #168
Finally got my set installed after letting it sit on the shelf for 9 months.
I installed STI pillowball trailing arms at the same time. We've used those a lot in the last 10 years...they're a great non-adjustable arm with a high-quality sealed pillowball. Makes a lot of sense to install at the same time here.
I thought this combo would be good, and it is good. Not a must have world-changing mod for every car, but I'm impressed and should have tried this a long time ago.
The STI trailing arms replace a rubber bushing that squishes and twists on the forward end of the OEM arm for a metal pillowball which does not squish or twist, but does freely and smoothly rotate.
So with this combo it feels like a whole heck of a lot of bind has been removed from the rear (because it has...both bushing and geometric). Hard to explain, but it feels much more natural in the way the rear suspension moves. While arguments can be made for some anti-squat having advantages for certain cars, there's simply too much in these cars.
There's a clear improvement in ride quality on the terrible roads I drive on. More grip under power as expected too. Still have to put more miles on it, but yeah...good stuff.
I've not measured for a change in rear ride height or alignment, sorry. I was planning on doing an alignment and a few other adjustments soon anyway.
I would recommend replacing the front and rear trailing arm bolts/nuts with new OEM pieces as well as the big subframe bolts that go up into the car. Just an easy way to save yourself from a bad day. Use a jack to keep the subframe from dropping too far and to hold it in position. Get the big vertical subframe bolts as far in hand tight as you can before cranking them hard. You don't want to cross thread those big boys.
Also makes sense to do subframe bushing inserts at the same time too. Not required, but feels good.
- Andrew
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
