Old 05-06-2023, 04:35 AM   #57
tomm.brz
Drives: brz 2017 hksv2
Gonna ask ecutek how limitations will work
Can t really try with latest Proecu as I stopped updating it too
Old 05-06-2023, 04:45 AM   #58
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by geraldjust View Post
they must of pushed off the change then because the most upto date proECU still has CPC/o2 as options for inputs.
But do they still have the additional support that would accompany those two settings, such as the ability to disable certain DTC codes that will pop up if you were to use those features? Screenshots would help if you can provide them.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
DarkPira7e (05-06-2023)
Old 05-06-2023, 08:26 AM   #59
tomm.brz
Ok i tried and everything in USDM tunes still works as usual
Only the "nevc" function got blocked as for now
Probably going to reinforce the blocking soon??
Old 05-07-2023, 11:21 AM   #60
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by FR-S2GT86 View Post
The problem is that we don't know if there is a limit on how many days that can go by until the update software recognizes that you have exceeded a limit.
I finally had time to play with it in regeditor, it's very simple.
Upon a fresh install, the LastEcuTekUpdate entry is generated.
Go into regedit, change the name of this entry to whatever you want (I chose to add " old" to the end) and now it doesn't know when the last time it updated was.
Old 05-07-2023, 03:12 PM   #61
PulsarBeeerz
Drives: JRSC BRZ SOLD
So, Ill go on and ask a silly question. Do the new changes affect the ECUtek mobile apps? The last time I used the app for data logging t/s, it asked to update but fearing that if I updated I'd be left with a CEL I denied the update. This was around the April 25th time frame.
PulsarBeeerz is offline   Reply With Quote
Old 05-07-2023, 03:23 PM   #62
geraldjust
Drives: MR2, Sliver BRZ
The concern is mostly for the tuning software.
And i will try and see the DTC list too.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 05-07-2023, 06:12 PM   #63
tomm.brz
it's still fully populated and no change at all in last software version
Old 05-07-2023, 06:15 PM   #64
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
The blutooth module can also flash tunes via PhoneFlash so they are likely forcing any changes like nevc in that software as well no editing on phone flash that I'm aware of though
AussieBRZ is offline   Reply With Quote
Old 05-09-2023, 01:04 PM   #65
tomm.brz
ecutek is pressing hard with the updates, i get a notification often in my laptop and they also try to update the obd interface
Old 05-09-2023, 01:15 PM   #66
FrickingReallySlow
Drives: 2015 FR-S
How can we backup versions of ProECU so that we can do a restore in the future in case something goes wrong? Does windows have a way to do that for specific applications or you need to have an image of the entire drive to restore to
FrickingReallySlow is offline   Reply With Quote
Old 05-09-2023, 01:32 PM   #67
tomm.brz
you cant
as soon as you install an update, the dongle gets overwritten with the last version of proecu so you can t downgrade even if you make a partition image, the dongle will stop the opening and force you to update
You can t also get flash points/license without updating proecu
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
FrickingReallySlow (05-09-2023), RToyo86 (05-10-2023)
Old 05-09-2023, 07:40 PM   #68
Espi
Espi's Avatar
Drives: 17 BRZ
Don't plug in your OFT to your PC - a forced update will appear, even after pressing Skip update. I have no idea why forced update but I can only imagine what's at play. Just sharing my experience. Im going Ecutek EU
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
Clipdat (05-09-2023)
Old 05-10-2023, 08:05 AM   #69
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Edit
For android users you can download an older version proecu app and shut off auto updates.
Old 05-11-2023, 02:17 PM   #70
dragonat112
Drives: 2015 Scion FRS / 1992 Supra T
so when you say this, non CAN flex fuel kits still work and can be tuned? I'm in the middle of getting a tune with a FF kit and I haven't done any updates
dragonat112 is offline   Reply With Quote
Open Flash Tablet Manager Software (problem after internet update) SloS14 Software Tuning 6 10-31-2013 04:33 PM
86 Software Update v3rgil AFRICA 121 10-04-2013 02:45 AM
Gopro 3 Software Update Released Yruyur Electronics | Audio | NAV | Infotainment 1 05-13-2013 07:17 PM
So what ECUtek software do you need to make changes to the ECU yourself? seven Engine, Exhaust, Transmission 30 01-04-2013 12:58 PM
EcuTek preparing to release PRO ECU software for BRZ Visconti Engine, Exhaust, Transmission 335 08-14-2012 12:34 AM
